Maximum Load on Beams: Formula & Share/Bend Moment Diagrams
In summary, there are formulas available for calculating the maximum load that can be supported by a beam, regardless of its orientation or end conditions. These formulas can be found in textbooks or online resources such as Roark's Equations for Stress and Strain. Additionally, there are formulas for finding the equations for shear and bending moment diagrams, as well as for determining the maximum deflection and corresponding stresses in different types of beams. However, it is important to design with a safety margin to avoid failure due to uncertainties in dimensions and material properties.
topito2
37
Do you know if there is a formula for the maximum load that can be supported by a beam? The beam could be a simply supported beam, cantilevered, or fixed on both ends.
By the way, is finding the equations for share and bending moment diagrams an undetermined problem?
Yes there are. Are you talking horizontal or vertical orientation of the principal axis? There are load-deflection formulae for any number of beams, load and load distributions, and end-point or boundary conditions.
There are already standard formulas.
Thank you for your answer. Do you recommend any book or website where I could look for further info regarding this topic?
"Roarks Equations for Stress and Strain" is the most comprehensive book you'll ever find for stress and strain equations, but the information you seek can be found in any Mechanics & Strengths of Materials textbook. Solve for static equilibrium and find the maximum moment in the beam in terms of force. Plug it into your stress bending equation stress=M*y/I, and solve for force with stress = to yield strength or UTS (depending on which is defined as failure). y=furthest distance from neutral axis of the beam, M is your maximum moment, and I is the moment of inertia of the beam cross section about the neutral axis. It's slightly more difficult if the beam cross section is not uniform throughout but not by much.
Likes Frames123
Roark's is one possiblity.
Then many textbooks and on-line resources have forumulas.
For example - buckling of a column (efunda has a limited number of samples, then one has to register, but there is a lot of valuable information there)
http://www.efunda.com/formulae/solid_mechanics/columns/columns.cfm
http://www.tech.plym.ac.uk/sme/desnotes/buckling.htm
http://www.diracdelta.co.uk/science/source/b/u/buckling load/source.html
Then there are more complicated systems - http://www.ce.washington.edu/em03/proceedings/papers/84.pdf
And of course, for horizontal beams and distributed load, there are formulas for maximum deflection and corresponding stresses in various types of beams and cross-sections. The peak load would be such that some location in the beam would exceed UTS and the beam would progress to failure. However, in practice, given various uncertainties in dimensions and material properties, and tolerances, one normally designs to some safety margin in order to avoid inadvertent failure.
Likes Frames123
Thanks for all your answers. You have been very helpful.
1. What is the maximum load that a beam can withstand?
The maximum load that a beam can withstand is determined by its material properties, dimensions, and how it is supported. It can be calculated using the formula: Maximum Load = Yield Strength x Cross-sectional Area.
2. How do you calculate the maximum bending moment on a beam?
The maximum bending moment on a beam can be calculated using the formula: Maximum Bending Moment = Maximum Load x Distance from the Support. This formula takes into account the weight and dimensions of the beam, as well as the location of the load.
3. What is the significance of a shear/bending moment diagram?
A shear/bending moment diagram is a graphical representation of the internal forces acting on a beam. It helps engineers and designers determine the maximum load a beam can handle and identify critical points that may require reinforcement.
4. How does the shape of a beam affect its maximum load?
The shape of a beam, specifically its cross-sectional area, plays a significant role in determining its maximum load. A beam with a larger cross-sectional area can handle a higher load than a beam with a smaller cross-sectional area, all else being equal.
5. Can the maximum load on a beam be increased?
Yes, the maximum load on a beam can be increased by changing its material properties, dimensions, or supporting conditions. For example, increasing the thickness or changing the material of the beam can increase its maximum load capacity. However, it is important to ensure that any changes made do not compromise the structural integrity of the beam.
  • Mechanical Engineering
  • General Engineering
  • Mechanics
  • Materials and Chemical Engineering
