Pacemaker and Wire with Current
In summary: The magnitude of the magnetic field created by I1 and at the location of I2 is .000034 T. The force per unit length exerted by I1 on I2 is .000011 N.
myersb05
A cardiac pacemaker can be affected by a static magnetic field as small as 1.7 mT. How close can a pacemaker wearer come to a long, straight wire carrying 27 A?
I know that F=ILBsin(theta). I attempted to solve using I=27, L as unknown, F=1.7, and Bwire=mupi*I/2pir with an unknown r that would be equal to the L.
I don't think there is a need to convert the 1.7mT to Teslas because my answer should be in mm.
Hi myersb05,
There's no need to deal with the force equation; the question just asks at what distance is the field of a long straight wire equal to 1.7mT.
I think you will need to convert to T, since B is in the numerator and r is in the denominator.
Also, it might just be a typo, but your B equation does not look right. It should be:
[tex]
B = \frac{\mu_0 I}{2\pi r}
[/tex]
Worked perfectly. Thanks again Al. That was the same problem I had last night. My equation was written improperly in my notes. I am stuck on another one if you have time.
Two long parallel conductors separated by 14.0 cm carry currents in the same direction. The first wire carries a current I1 = 3.00 A, and the second carries I2 = 8.00 A. (Assume the conductors lie in the plane of the page.)
(a) What is the magnitude of the magnetic field created by I1 and at the location of I2?
(b) What is the force per unit length exerted by I1 on I2?
C and D are the opposites of those.
I found the F/L by using uI1I2/2pid. So that came out as .000034 which is correct and applies to both wires.
I attempted to use Bwire=u8.0/2pi.14=.000011 and that was incorrect. I tried the same for the 3 amp wire and got .000004 which is also incorrect.
Are you saying that 0.000004T is not the correct answer for part a? That's what I am getting; maybe you need to keep more digits (that results is roughly 6% to 7% or so off from the non-rounded answer), or maybe they want different units?
WebAssign is telling me that .000004 is close but that I should keep more digits. I can't come up with an answer that is any less rounded than .000004.
You found that result by calculating,
[tex]
\frac{4\pi \times 10^{-7} (3)}{2 \pi (0.14)}
[/tex]
right? The factors of [itex]\pi[/itex] will cancel; do you mean your calculator only gives you one digit?
I was thinking you rounded some answers to get your result, and to get the right answer you should not round at all.
Yea, that is exactly what I typed into my TI-89 and I got exactly .000004
Well let's try to factor it out some:
[tex]
\frac{4\pi \times 10^{-7} (3)}{2 \pi (0.14)}\to \frac{4 \times 10^{-7} (3)}{2 (0.14)} \to \frac{6}{.14} \times 10^{-7}
[/tex]
So do 6/.14, and then add on the exponential part after you have more than one digit. Does that give the right answer?
I didn't even notice that you had a TI-89. Here's what you can do:
As soon as you get the answer of 0.000004, hit the up arrow, and then hit enter. That will bring the value down to the input line, with all the digits you need.
(You can also go into the mode menu and set it to show differing numbers of digits, but the above is what I usually do.)
Got it, thanks again Al
Glad to help!
It wasn't until after I posted the algebra in post #8 that I finally thought about the fact that I had a TI-89 and have the same issue quite often, so I end up doing the little key dance from post #9 all the time without even thinking about it.
Yea, I'll have to remember that
1. What is a pacemaker and wire?
A pacemaker is a small device that is implanted under the skin of the chest to help regulate the heart's rhythm. It uses electrical pulses to keep the heart beating at a steady pace. The wire, or lead, is a thin insulated wire that connects the pacemaker to the heart.
2. How does a pacemaker and wire work?
The pacemaker sends small electrical signals to the heart muscle through the wire, which stimulates the heart to beat. It can sense when the heart is beating too slowly or too quickly and adjust the pacing accordingly to maintain a consistent heart rate.
3. Why is a pacemaker and wire needed?
A pacemaker and wire may be needed if a person's heart is not beating at a normal rhythm or if it is beating too slowly. This can be caused by conditions such as bradycardia, heart block, or sick sinus syndrome. A pacemaker can help improve symptoms and prevent serious complications.
4. What are the risks associated with a pacemaker and wire?
While pacemakers and wires are generally safe, there are some potential risks, including infection, bleeding, and damage to blood vessels or nerves during the implantation procedure. There is also a small risk of complications such as lead dislodgement or fracture, which may require additional procedures to fix.
5. How long does a pacemaker and wire last?
The lifespan of a pacemaker and wire can vary depending on factors such as the type of device, the individual's activity level, and any underlying health conditions. On average, a pacemaker battery can last 5-15 years before needing to be replaced, while the wire can last for several decades.
