Register to reply
Simple supported round shaft deflection
Share this thread:
AQUAPOP
#1
Mar19-14, 02:42 PM
P: 4
Hello.
I'm looking for the deflections of a 1.938" dia. steel shaft at different lengths.
Supported in bearings at both ends.
150lbs. per foot of length, with all of the weight in the center of the rod.
I.E. how much does the rod deflect of there is 450lbs. pushing down between 36"...
I'm looking for 300 lbs. for 24", 450 for 36", and 600 for 48".
Thanks in advance,
Frank
Phys.Org News Partner Physics news on Phys.org
Step lightly: All-optical transistor triggered by single photon promises advances in quantum applications
The unifying framework of symmetry reveals properties of a broad range of physical systems
What time is it in the universe?
SteamKing
#2
Mar19-14, 03:56 PM
Emeritus
Sci Advisor
HW Helper
Thanks
PF Gold
P: 6,546
Quote Quote by AQUAPOP View Post
Hello.
Thanks in advance,
Frank
For a simply supported beam, the max deflection for an evenly distributed load is
δ = 5wL[itex]^{4}[/itex]/(384EI)
where:
L - distance between supports, in inches
w - distributed load, in pounds / inch
E - Young's modulus for the shaft material
(for example, for steel, E = 29*10[itex]^{6}[/itex] lbs/in[itex]^{2}[/itex])
I - second moment of area for the shaft, in inches[itex]^{4}[/itex]
I for a circular shaft is πD[itex]^{4}[/itex]/64, D - diameter in inches
δ - shaft deflection, in inches
π - constant = 3.14159
Make sure you use the correct units and you are good to go.
Register to reply
Related Discussions
Deflection simply supported beam Engineering, Comp Sci, & Technology Homework 5
Slope and Deflection of a Simply Supported Beam Academic Guidance 1
Moments of deflection/ curvature of radius of a supported beam Engineering, Comp Sci, & Technology Homework 4
Deflection in a simply supported beam with a rigid arm underneath Engineering, Comp Sci, & Technology Homework 3
Round Table Supported by 3 Legs Introductory Physics Homework 3
