Understanding transistor Ptot in data sheet
In summary, the different thermal resistances for TO-92 and TO-39 packages allow for different levels of heat dissipation and maximum power ratings. The Tc based Ptot refers to zero thermal resistance to 25C, which is purely theoretical. The derating factor shows how the power rating decreases as the case temperature rises. Heatsinks can help dissipate heat and increase the power rating, but there are still limits for the transistor's safe operation.
SwedishWings
Hi,
Reffering to the attached image, I wonder how total power dissipation is defined in each case; "Tamb < 25C" and "Tc < 25C" respectively. I suspect that Tc is referring to usage with a heat-sink , but it makes no sense as the TO92 case is not well suited for heat sinks.
Thanks in advance!
SwedishWings said:
Hi,
Ta = ambient temperature, Tc = case temperature.
I suspect that Tc is referring to usage with a heat-sink, but it makes no sense as the TO92 case is not well suited for heat sinks.
Really?
http://uk.rs-online.com/web/p/heatsinks/7124320/
http://www.rapidonline.com/electronic-components/to-92-heatsink-77178
Or make your own from a small metal plate held onto the transistor with heat-shrink tubing!
It's unlikely a heat sink would keep the case temperature down to 25C, but the data sheet should give the derating factors for higher temperatures, as in http://www.onsemi.com/pub_link/Collateral/P2N2222A-D.PDF
SwedishWings said:
Hi,
Thanks in advance!
Were those numbers for the TO-92 package version, or maybe for a different package option (like metal can)?
There's a "Thermal resistance to case" and a different "Thermal resistance to ambient".
Many transistors have their collector bonded right to the metal case for good heat transfer.
As you observed - with a heatsink you'd add 'to case' thermal resistance to heatsink's thermal resistance to get thermal to ambient...
I like the metal can (TO39?) for troubleshooting.
The one on the left had its base wire melted off inside, emitter too if i recall. We attributed that one to human error not aging. Probably a 'scope ground probe got plugged into the wrong test point.
Yeah, i think i might have mixed up the data sheets, that would be the TO-18 case. But are there any heat-sinks for TO-18?
Really?
I totally missed the fact that there are heat-sinks for those casings. Thanks!
Thanks for clarifying, think i understand now. But does the Tc based Ptot refer to _zero_ thermal resistance to 25C? That would be purely theoretical, right?
Great idea, never thought about it =)
What does "Derate above 25°C - 5.0 mW/°C" actually mean? Is it the SOA that falls with 5mW/C?
Zero thermal resistance case to ambient, yes. If you could keep the case at 25 deg you could dissipate 3 watts.
Take a look at the thermal resistances given here for TO-39 case
http://www.st.com/web/en/resource/technical/document/datasheet/CD00003223.pdf
compare to the plastic case...
try the numbers and see if both conditions get you to max junction temperature at max power dissipation.
I would take the Ta values as meaning the device was on a circuit board in air, without any heat sink.
If you have a heat sink, you should know the thermal resistance between the case temperature and the air. For example the RS link gives the thermal resistance as 60 degrees C per watt.
So if you were dissipating 0.5W with that heatsink and Ta = 25C, Tc would be 25 + 60 x 0.5 = 55C.
The derating parameter tells you how the power rating decreases as the case temperature rises. If the max power rating is 1.5W at Tc = 25C and the derating is 12mW/C, at Tc = 55C it would be 1.5 - 0.012*(55-25) = 1.14W.
If you increase the actual power dissipated, Tc will rise and the max power rating will fall. When the actual power = the max power, that is the operating limit for the transistor with that type of heatsink.
1. What does Ptot stand for in a transistor data sheet?
Ptot stands for "total power dissipation" and it represents the maximum amount of power that a transistor can handle without getting damaged.
2. Why is it important to understand Ptot in a transistor data sheet?
Ptot is an important parameter because it determines the maximum amount of power that a transistor can handle, and therefore, it helps in selecting the appropriate transistor for a specific application.
3. How is Ptot calculated in a transistor data sheet?
Ptot is calculated by multiplying the maximum collector current (Ic) with the maximum collector-emitter voltage (Vce) and adding the power dissipation of the base-emitter junction (Pbe) and the power dissipation of the collector-emitter junction (Pce). Ptot = Ic x Vce + Pbe + Pce.
4. What factors can affect the Ptot of a transistor?
The Ptot of a transistor can be affected by the ambient temperature, the supply voltage, the collector current, and the thermal resistance of the package.
5. How can Ptot be used to compare transistors from different manufacturers?
Ptot can be used as a standard parameter to compare transistors from different manufacturers. A higher Ptot means that the transistor can handle more power, making it more suitable for high-power applications.
  • DIY Projects
  • Classical Physics
  • STEM Academic Advising
