Classical Electromagnetism: Question on Ampere's Law and Displacement Current
In summary: The question I posed was whether every time-varying E-field would be associated with a displacement current. nicksauce said no, so how about those cases whereby we have a time-varying field but no displacement current or current flow? Are there such cases, and is any B-field induced?There are cases where a time-varying E-field is present but no current flow. In these cases, no displacement current is present, so the B-field cannot be induced.
  • #36
cabraham said:
The "driver" is energy, not I or V. Now with the photodiode, I mentioned it to show that I, the photocurrent, is NOT driven by a voltage. You then proceed to lecture me on exactly what I originally said. Read my previous post. When you said that V drives I, I brought in the photodiode to demonstrate otherwise. Now you're telling me that I and V (and E as well) can be "de-coupled", the exact opposite of your original premise. Once again, what "drives" I in a photodiode is *energy* in the form of photons. In a pd, photons incident on the surface transfer energy to the lattice and electrons are elevated from valence to conduction. In an LED, the opposite takes place. The forward current is set up, and electrons dropping from conduction to valence incur an energy decrease. Energy is conserved in the way of photon emission. Once again, the driver is energy.
This is partly incorrect. First off, an electric potential difference (i.e. voltage) implies an energy difference (energy is directly proportional to electric potential). However, when one speak of currents, it is customary to speak of electric potentials as opposed to energies.
More importantly, your description of light incident on a photodiode is correct up to the point where photons elevate an electron into the conduction band. It is customary to say that you are creating excess minority carriers on either side of the junction. These minority carriers, however, are then swept to the opposite side of the junction by the built-in potential of the junction. So, as you see, it is still a voltage that drives the current.
Your mention of the LED seems to add nothing to the conversation and implies an effort to confuse and draw attention away from the topic at hand.
In reading these last few post, it seems as if you come up with complicated scenarios that are highly convoluted in their explanation. You then go on to mention "On the Electrodynamics of Moving Bodies." Great.
Can you come up with ONE example where current is the ultimate driver? Don't get cute, don't confound the problem. Just present one example where current is the ultimate driver.
  • #37
I never said that current is the ultimate driver. I said that I and V are both driven by energy, or work W. Do you read my posts at all?
Regarding photodiodes, did you ever take and pass a course on semiconductor physics? I took a senior undergrad course from the physics dept, then a grad level course from the EE dept in the latter '70's. Then I took 2 more in 2007-2008 in grad school. You just blind sided me with your theory:
"It is customary to say that you are creating excess minority carriers on either side of the junction. These minority carriers, however, are then swept to the opposite side of the junction by the built-in potential of the junction. So, as you see, it is still a voltage that drives the current."
How can a minority carrier be swept by the built in potential? The built-in potential, herein referred to as Vbi, is a barrier that must be overcome. It doesn't drive carriers anywhere. Recheck your references. In order to change the potential across a junction, the charge distribution must change, i.e. carriers must be increased or decreased. So if charges are increased or decreased, current takes place. The change in current chronologically preceded the change in voltage. The junction voltage does not drive the current, NOR VICE-VERSA. The Vbi is due to minority carrier distribution. Thermally generated hole-electron pairs transit across the junction. When they arrive in the new material, they are minorities, holes in the n material, and electrons in the p material. When new e-h pairs are generated, they cannot be swept across the barrier by Vbi. Vbi consists of the same polarity carriers as the new carriers. I.E. the holes in the n material cannot sweep holes from the p side over to the n side. Like charges repel not attact. Vbi must be overcome. An external source must provide an E field to move the carriers across the barries. This E field must overcome the Vbi since Vbi tends to oppose the migration of carriers. Vbi OPPOSES charge being "swept" across the barrier. Vbi does NO SWEEPING! Take any p-n junction. The barrier Vbi is due to holes in the n side, and electrons in the p side. To move holes from p to n, and electrons from n to p, an E field is needed. This E field points from the p to the n side. But the E field associated with Vbi points from the n to the p side, exactly OPPOSITE that needed.
Regarding an example where current is the ultimate driver, take a lossless inductor shorted. It carriers an non-zero current I, and has inductance L. A switch across it keeps current steady. A cap is placed across the switch. It is uncharged. The energy in the inductor is L*(I^2)/2, and in the cap it is 0.
If the switch is opened, current from the inductor enters the cap and charges it. After the inductor is completely emptied, the cap energy is C*(V^2)/2, and inductor has 0 energy. Then the cap transfers energy back to the inductor, etc. etc.
The reason that the cap was charged, and that the voltage went from non-zero to zero is due to the inductor transferring energy. This energy is in the form of a magnetic field / current. Of course, the instant the switch opened, the inductor began generating an increasing voltage. But at t = 0, V = 0, with non-zero I. Hence the cap voltage is 0 with current entering it. As current charges the cap its voltage increases. Likewise, the cap voltage maxes out, then returns energy to the inductor. The voltage in non-zero while the current is 0.
Thus the current can charge the cap and change the voltage, and the voltage can energize the inductor and change its current. Either I or V can come first. It is energy that is the ultimate driver. If an observer arrives after the switch has been opened, they see the energy bouncing back and forth. If asked, "Which came first, the I or the V?", they couldn't answer. Either can "come first".
This is well known. "Eli the ice man" has been known for nearly 2 centuries. The notion that "voltage drives current" is just a misconception easily acquired since batteries, generators, and electronic power supplies are almost always designed, optimized, and built for *constant-voltage* mode of operation. We can easily lose sight of the fact that the constant voltage and variable current mode of operation is a man-made thing. Mother Nature is neither constant I nor constant V. I hope this explains my position. If anything needs clarified, I'll be glad to do so. Comments are always welcome and appreciated. BR.
Claude
  • #38
Clearly I have taken such a course. I would question your own claims though as it seems that you simply looked up some definitions but never actually performed any rigorous analysis. As I said once before, EE is not the same is EET.
Anyway, if your claims are true, then I will encourage you to draw the band diagram of a pn-junction under sufficient illumination. Then you can see how the built-in potential sweeps photogenerated minority carriers thus inducing current.
Yes, but you still need to have a source present. The source will be fundamentally a voltage driver.
Charge builds up on the capacitor because, initially, the plate is at a different potential than the end of the inductor. So when you make a connection, current flows because of that potential difference.
This is a phase relation and not a causality relation.
So then how would one make a "true" current driven source? (as opposed to a current source that is fundamentally driven by a voltage.)
  • #39
cmos, this is absurd. First of all, why do you keep referring to me as "EET" and not "EE". My profile explicitly states my EE status, as well as PhD candidacy. I know that EET is not the same as EE.
Regarding the inductor, NO, a source (voltage or current) need NOT be present. An energized inductor will charge up a cap without any other source(s) present. Elementary circuit theory that is. The cap is initially uncharged w/ zero voltage. Yet current immediately exists at t=0. There is zero voltage and non-zero current. Current flows because the inductor is transferring energy to the cap. No voltage is driving said current. The plate is NOT at a different potential than the inductor.
Regarding "Eli the ice man", I never said it was about causality. I've been inferring that there is no causality between I and V and Eli is proof. Since I can lead V, or V can lead I, that is prima facie evidence that neither causes the other. I brought Eli in just to demonstrate the non-causal relation between I and V. You are now arguing my case.
How to make a true current driven source. Run a generator (ac) at constant torque. Imagine a bicycle type ac generator. If you pedal with constant torque, and the load resistance can change, the current remaons fixed while the voltage and speed vary with load.
A photodiode is a current source. I just took an advanced semiconductor physics course spring 08. The Vbi built in potential in the energy band diagram is a barrier that must be overcome. I covered that previously. If the built in potential could sweep minority carriers, light wouldn't be needed. Minority carriers are constantly being generated by thermal energy. The Vbi opposes charge migration across the junction.
Nothing personal, but you're batting 0. BR.
  • #40
Because your tactless side comments, absurd claims, and misuse of fundamental concepts leads to me suspect.
So the inductor spontaneously became charged? Splendid, you've just overthrown conservation of energy. In less sarcastic words; the source will be necessary to charge the inductor in the first place.
Now let your clock run. A voltage will be dropped across the capacitor; this will reach a steady-state at which point no more charge builds up on the capacitor plates. This means no more current is running from inductor to capacitor. So the two adjacent end nodes must be at the same potential. This implies that this were not originally the case (i.e. the plate was at a different potential than the inductor initially - this drove the current to charge the capacitor).
This does not follow. This relation says nothing for or against your argument. It speaks oly of the phases and nothing else.
I don't quite follow this. Maybe you can cite some source?
Really, what it comes down to is Maxwell's equations. None of the four equations say that current may be induced but that it is simply an inducer. The fact that current (i.e. the movement of charge) may occur is given by Coulomb's law. This explicitally demands that an electric field (voltage) be present to move the charge (drive the current).
What you are describing is a non-illuminated diode or an LED in forward operation. An illuminated photodiode as a current source (sometimes commonly called a solar cell) runs a current that is negative with respect normal diode operation. This is because the built-in potential in the photodiode drives the current the opposite way with respect to normal diode operation. Pay better attention in class.
Nothing personal, but you are still batting 0.
  • #41
cmos, you've raised *getting it wrong* to an art form.
You twist everything I say. First, of course the inductor is not spontaneously charged. It has been charged by another source, but that source is decoupled, leaving an energized inductor terminated in a short. Then a switch opens with a cap across the inductor. Current from the inductor charges the cap at t=0. The voltage at t=0 is *zero*, with non-zero current. Any EE prof will explain this to you. The voltage builds up until the current is zero. t this point the voltage maxes out. Then energy is returned from the cap to the inductor. Pretty straightforward. Of course, a charged cap can be the original source of energy, and the inductor gets switched in. The voltage is non-zero at t=0, and the current is zero. The current builds up, and when the voltage is zero, the current maxes out. Then the inductor returns energy to the cap.
Energy is transferred between the 2, with no pecking order.
Eli the ice man demonstrates the futility of trying to establish a pecking order. Since I can lead V, V is not the cause of I. Since V can lead I, I is not the cause of V. Eli disproves causality.
Regarding ac generators, you ask for a reference. Any machines book will confirm that torque and current are strongly related, as are speed and voltage. The reverse holds w/ motors. Anyone experienced with motor drives will affirm that to control torques you use current drive, and to control speed you use voltage drive. Any text will affirm.
I'll see if I can scan the photodiode diagrams and post them.
Regarding Maxwell's equations, you keep equating E field with voltage, which is not equivalent. Of course, charges are moved by an E field. But the voltage is not what moves charges. F = qE. The Coulomb force is observed and the finite velocity of field propogation is observed. Thus when the field arrives, the force is felt. Charges move due to the presence of other charges. Potential is derived from force distance and charge.
To establish an E field, you need volts and amp-seconds both. E fields exist when charges are separated, but separating requires moving them. Moving charges are what is called current. So, charges move, i.e. current, in an E field, but it takes current (and voltage) to establish an E field.
There is no pecking order.
  • #42
cabraham said:
cmos, you've raised *getting it wrong* to an art form. You twist everything I say.
Well this just isn't true. I believe all my statement thus far have been correct. And my recent style has been to quote exactly what you have said and respond accordingly; no twisting anything you say in that.
I feel like any attempt to do this would result in a shorted inductor and no current; similar to taking a piece of wire and making a ring out of it.
Assuming that your "decoupled inductor" works: well the voltage is actually zero at t=0- and then steps to some value at t=0+. The point that I have been driving is that the current tends to zero as the adjacent ends of the inductor and the capacitor equilibrate in potential. This is clearly a voltage-driven phenomenon.
Similar arguments to the two I just made.
As I keep saying, the term "lead" is in reference to the phase and not cause and effect.
You speak of Faraday induction. In this, it is the electric field that is induced, not the current. When we speak of the electric field in circuits, it is convenient to speak of voltages. As a result, voltage again drives the current.
If you need help drawing them out, just ask.
The negative gradient of voltage is the electric field. Whichever one is used is more of a matter of convenience. This is similar to formulating mechanics in terms of energy or in terms of forces.
But the potential energy is U=qV. The movement of charge can thus be analyzed by the mechanics of Hamilton and Lagrange.
All it takes is a single charge to create an electric field. You may then place a test
Sadly, I think that at this point we are going in circles and more or less repeating ourselves. Unless you have a specific question or something genuinely new to add, I will let you have the last word on this one and leave it at that.
  • #43
Defennder said:
I'm getting the impression from some of the sources that I've read (Wikipedia and others) that this results in an electromagnetic wave. Does this explain why wires heat up or something? I guess not, since clearly Joules heating occurs in DC current flowing in wires. But if not, what happens to the EM waves?
I'm not certain on this, but I believe that the radiative loss (heating of a resistor) is correctly taken into account by circuit theory. The main place where circuit theory should fail with respect to energy conservation is radiative loss from a capacitor or an inductor. A related thing is "stray capacitance" - there is no such thing as a pure resistor or pure inductor or pure capacitor. Any "pure resistor" that you can buy is only an approximation, and if it has significant capacitance that you don't take into account, then your circuit may not work as planned.
In the most general terms, there is no such thing as capacitance. Capacitance as a property of a conductor, as opposed to being a property of the conductor and field configuration, is defined only if no charge is moving, so that we can predict everything using a potential (a scalar field) instead of an electric field (a vector field). cabraham made the same point above:
cabraham said:
I and V cannot exist independently under dynamic, or time-varying conditions.
cabraham said:
For induction in time changing case, E = -dA/dt, where B = curl A.
As he points out (I think there may be a minor typo in his equation, but the sense is correct), under general conditions, if we insist on using a scalar electric potential, we must supplement it with a vector magnetic potential. The scalar and vector potential together form the electromagentic four-potential. In classical field theory, the E and B fields are primary, and the potentials secondary (a physical state can be labelled by anyone of many four-potential configurations). But in quantum field theory the four-potential is primary, and the multiple labels for the same physical state can cause lots of confusion in complex equations.
  • Electromagnetism
