Fluid with laminar flow going through a constriction in a pipe has low
In summary, the fundamental reason why a fluid with laminar flow going through a constriction in a pipe has lower pressure is due to the conservation of energy. This is because the average velocity in the constricted cross-section must be higher than in a non-constricted section, causing an acceleration in the fluid particles. In an inviscid fluid, this acceleration can only be achieved if the pressure in the non-constricted region is higher than the pressure in the constricted region. Therefore, the pressure in the constricted region must be lower in order to maintain this acceleration and conservation of energy.
Beetroot
Hi
What is the fundamental reason why a fluid with laminar flow going through a constriction in a pipe has lower pressure?
Pressure is defined as force per unit area so the fluid particles must be hitting the pipe wall in the constriction with less force.
Beetroot
Beetroot said:
Hi
Beetroot
1. The conservation of mass tells us that the average velocity in the constricted cross-section must be higher than in a non-constricted section.
2. Thus, those fluid particles traveling along, must have experienced an ACCELERATION
3. In the inviscid fluid, this acceleration can only be achieved if the pressure in the non-constricted region is higher than the pressure in the constricted region.
4. Suppose that somehow the pressure in the constricted region were to increase to the level in the non-constricted region (say, a plug was inserted),. What would happen?
Well, the water prior to the constriction might try to squeeze itself through the wall (not likely to happen..), yet in that case, the actual pressure there would go up, leading either to a reversal of the flow direction, or by the collapse of the cause for the pressure increase in the constricted region (for example by expelling the plug).
The conservation of mass flow ... Assuming mass isn't continously accumulating at a point in the pipe, the mass flow along the pipe is constant, so the fluid velocity is inversely proportional to the cross sectional area.
Flow doesn't have to be laminar. The ideal case is when there is no viscosity or friction with the pipe walls, so that the pipe doesn't perform any work on the fluid. Otherwise, the pressure decreases with distance traveled in the pipe as the fluid flows towards a low pressure exit point at the end of the pipe, even with a constant diameter pipe.
That's another way of looking at it. The total energy of a volume of fluid or gas is related to the speed and mass density of the molecules. Pressure is related to the momentum of the molecules as they collide with the pipe. If no work is done, and if the molecules have net increase of component of speed^2 in the direction of flow, then that corresponds with a net decrease in the component of speed^2 perpendicular to the direction of flow, and vice versa, assuming that temperature hasn't changed.
Although not directly related, here's a link to a web page discussion the relationship between the Kelvin temperature scale, kinetic energy, heat, and potential energy (Van der Waals force):
http://id.mind.net/~zona/mstm/physics/mechanics/energy/heatAndTemperature/gasMoleculeMotion/gasMoleculeMotion.html
Hi
So the particles in the constriction are hitting the pipe wall with less force, that has been established. But is the reduction in force due to:
1) The particles hitting the wall less often, due to their increased velocity, or
2) The particles hitting the wall with less force because the velocity component in the direction of flow is greater than the axial component.
Beetroot
The others said why the velocity changes, but you asked why the pressure changes. Velocity changes due to conservation of mass - pressure changes due to conservation of energy.
Mass flow is constant, so the rate of collisions with the wall is also constant.
Correct, the average speed of the molecules is constant in this case, so if there's a net flow in a particiular direction, the velocity perpendicular to that flow is a bit less.
1. What is laminar flow?
Laminar flow is a type of fluid flow in which the particles of the fluid move in parallel layers with little to no mixing between them.
2. How does a constriction in a pipe affect the laminar flow of a fluid?
A constriction in a pipe can cause a decrease in the cross-sectional area, which leads to an increase in the velocity of the fluid. This increase in velocity can disrupt the laminar flow and create turbulence.
3. Why does a fluid with laminar flow have low pressure in a constriction?
In laminar flow, the particles of the fluid move smoothly and in a uniform manner, which leads to a decrease in friction and pressure. However, in a constriction, the velocity of the fluid increases, causing a decrease in pressure due to Bernoulli's principle.
4. What factors can affect the laminar flow of a fluid in a constriction?
The viscosity of the fluid, the size and shape of the constriction, and the velocity of the fluid are all factors that can affect the laminar flow in a constriction.
5. Can laminar flow be maintained in a constriction?
It is possible to maintain laminar flow in a constriction by controlling the velocity and properties of the fluid, as well as the size and shape of the constriction. However, if the velocity exceeds a certain threshold, turbulence may occur.
  • Classical Physics
  • Classical Physics
  • Classical Physics
12K
14K
  • Mechanical Engineering
14K
  • General Engineering
