Chemistry - Calculating moles, mass and percentages
In summary: That way you're not accidentally converting something.Yeah Borek that must be it they expect precise answers. For matters like this is it best to go 2 spaces after the decimal... and make sure to at least use the same units when doing calculations. That way you're not accidentally converting something.
MadmanMurray
76
One area of chemistry I seem to make a lot of mistakes on is the mathematical side. Calculating moles and grams and percentages and that kinda stuff. Heres a few questions on my last test I got wrong
Q1.) Copper reacts with concentrated sulfuric acid according to the equation:
Cu + 2H2SO4 -> CuSO4 + SO2 + 2H2O
If 12.7g copper was used calculated:
a) The number of moles of copper involved
b) The mass of copper sulfate produced
c) The number of moles of water produced
d) Volume of sulfur dioxide formed at stp
I just redid them there to see if I am still making errors. Heres my methods and answers
a) since there are 63.5g in a mole of copper I just divided 12.7/63.5 and got 0.2 moles
b) For this I just added up the mass of a mole of CuSO4 (160) then since 1 mole Cu makes 1 mole CuSO4 I multiplied 0.2 by 160 and get 32 grams
c) For this one since 1 mole Cu produces 2 moles H2O I assume 0.2 Cu produces 0.4 moles H2O
Q2) What is the empirical formula for the compound with the compisition, Copper 34.6%, Iron 30.5%, Sulfur 34.9%
I was lost on that one. I assumed I find out the AMU of each of the elements but from there I didn't know how to assign coefficients to each element
... snip snip...
...snip..
[/I]
Q2) That is the correct idea, of the AMU, because you want number ratios of atoms in the compound. You then want to simplify the ratios as closely as possible to integer values (basic mathematics for fractions).
Assume for simple arbitrary purposes, you have 100 grams of compound. Look for "formula weight" of element; divide the percent (NOT in the form of decimal fraction but as percentage units) by element's formula weight. Now you have the relative atom ratios, but you need to simplify this set of ratios.
Thanks that explains the percentages question. I just looked back over my old test results and I noticed I answered 32 grams for the second question but the teacher marked it wrong. Was that a mistake on the teachers part? I just multiplied the mass of copper sulfate by 0.2 since it was 0.2 moles of copper put in.
I got 31.9g.
A good idea when working with chemical quantity calculation it is always a good idea just to calculate the units of the end result, to check up if the result is right. And this is always a good idea. When you calculate diffusion potential through various gasses or liquids or for instance when calculating equilibrium constants. Just always check your formula, if the units you put in, match the ones you want in the end. That also corrects factor errors, when putting in for example enthalpy in kJ/mol, and entropy in J/mol*K, then the unit is not going to be right in the end, unless you correct for it along the calculation.
Vunde
No idea how it is related to the question in question, but I agree it is a good idea to check units to be sure of units.
The relation is, for the questionasker to obtain a good tool to ensure results, and to make it a habit to take units in consideration when asking him/herself these questions. So not so much a 2+2=4 solution, but more a good tool to ensure the results.
And since you guys had already helped sufficiently with the questions in question, then why not organize the questioneer's thoughts regarding all concepts and shades of calculating anything regarding physics and chemistry.
Vunde
Yeah Borek that must be it they expect precise answers. For matters like this is it best to go 2 spaces after the decimal point and round off or should you just throw in every single number?
That depends how many digits you've been using for your calculation.. This is the bottleneck for how many digits your result should be in..
It gives no point to calculate your result with nine decimals or something, and then giving the result with just one decimal. However this has never been my forza..
1. What is a mole in chemistry?
A mole in chemistry is a unit of measurement that represents the amount of a substance. One mole is equal to Avogadro's number (6.02 x 10^23) of particles, such as atoms, molecules, or ions. It is often used to convert between the mass of a substance and the number of particles it contains.
2. How do you calculate the number of moles in a substance?
To calculate the number of moles in a substance, divide the mass of the substance by its molar mass. The molar mass is the mass of one mole of the substance expressed in grams. This can be found by adding together the atomic masses of all the elements in the substance's chemical formula. The resulting quantity will be in units of moles.
3. What is the difference between molar mass and molecular weight?
Molar mass and molecular weight are often used interchangeably, but they have slightly different meanings. Molar mass is the mass of one mole of a substance, while molecular weight is the average mass of one molecule of the substance. Molecular weight takes into account the natural abundance of different isotopes of an element, while molar mass assumes all atoms of an element have the same atomic mass.
4. How do you calculate the mass percentage of an element in a compound?
To calculate the mass percentage of an element in a compound, you need to know the mass of the element in the compound and the total mass of the compound. The mass percentage is then calculated by dividing the mass of the element by the total mass of the compound and multiplying by 100. This will give you the percent composition of the element in the compound.
5. What is the relationship between moles, mass, and volume in the ideal gas law?
The ideal gas law, PV = nRT, describes the relationship between pressure (P), volume (V), temperature (T), and the number of moles (n) of gas present. According to this law, the volume of a gas is directly proportional to the number of moles present and the temperature of the gas, and inversely proportional to the pressure. This means that as the number of moles increases, the volume also increases, while the pressure decreases. Additionally, as the temperature increases, the volume also increases, while the pressure remains constant.
