Electric potential constant within a conductor?
In summary, the conversation discussed the electric potential inside a conductor and outside a coaxial cable. It was questioned how the potential can be constant while the electric field is zero, and if the same holds true for a coaxial cable. The conversation also touched on the concept of potential difference and its relationship to the integral of the electric field.
Plamo
1. Electric potential inside a conductor / outside a coaxial cable
Electric Potential inside a conductor(spherical) is a constant, although electric field is zero. How does that make sense given:
Given [itex]V=- \int E \cdot dl[/itex]?
The integral should be 0. Even if you consider constants of integration, shouldn't they drop off because the integral is from the radius to 0?
Given that potential is non-zero inside a conductor, does the same hold true outside a coaxial cable? A Gaussian surface around the cable shows that the electric field outside the cable is 0. Do we have the same case where the potential is non-zero outside of the cable?
The problem statement is my attempt at the solution. More of a lack of confusion than an actual problem.
Edit:
To clarify, this makes sense in reverse: E = del(V). Derivative of a constant is 0. How did that constant get there in the first place though?
That integral is certainly 0 within the conductor. With the limits of integration:
[tex]V_2-V_1=\int__1^2 \vec{E}dl=0[/tex]
Obviously it's true since E is 0 inside the conductor...therefore the potential must be constant inside.
I guess I don't quite get what the problem is.
The issue is that I don't see why it's non-zero inside. More importantly, I can't decide on whether or not it's 0 outside a coaxial cable.
What's non-0 inside? The electric field is definitely 0 inside a conductor (for electro-statics anyways).
How is your coaxial cable set up? Current moving in one direction inside and current moving in the opposite direction outside?
Consider two thick conducting plates connected to a battery so they have distinct constant potentials. If one is at potential zero the other is certainly not zero.
The potential equation you've given is more properly written:
[tex] \Delta V = V_2 - V_1 = -\int_{p_1}^{p_2} E\cdot dl[/tex]
In short it defines a potential difference.
1. What is electric potential?
Electric potential is a measure of the electric potential energy that a unit charge would have if placed at a specific point within an electric field.
2. What is an electric potential constant within a conductor?
The electric potential constant within a conductor refers to the fact that the electric potential remains constant at all points within a conductor when it is in a state of electrostatic equilibrium.
3. How is electric potential constant within a conductor related to electric field?
The electric potential constant within a conductor is directly related to the electric field within the conductor. In a state of electrostatic equilibrium, the electric field within a conductor is zero, resulting in a constant electric potential throughout the conductor.
4. What is the significance of electric potential constant within a conductor?
The electric potential constant within a conductor is significant because it ensures that the charges within the conductor are in a stable state and do not experience any net force. This is important for the proper functioning of electrical devices and systems.
5. How is the electric potential constant within a conductor affected by the shape and size of the conductor?
The shape and size of a conductor do not affect the electric potential constant within it, as long as the conductor is in a state of electrostatic equilibrium. This is because the electric potential remains constant throughout the conductor, regardless of its shape or size.
  • Electromagnetism
