Hot water is heavier than cold water.
In summary, liquid water is most dense at 4 C, and above this temperature, hot water is heavier than cold water. This is because as the temperature of water increases, its density decreases causing it to expand and take up more space for the same mass. However, this difference in weight is extremely small and only becomes significant when considering relativistic effects. Additionally, when considering the environment and energy exchange, the difference in weight between hot and cold water becomes even smaller and may not be detectable.
neduet
64
If density is decreasing means its cover area is also increasing, and weight is irrelative to the area body occupies. Isn't it?
W=mg, to vary the weight we have to cop with its mass and gravity.
As gravity is constant then is it the mass of the water that is varying?
If you tried to measure it with typical scales and instruments you'd find hot and cold water weigh the same. But all energy has an equivalent mass which participates in gravitatational attraction. Therefore the heated water is a very tiny bit heavier than cold water.
Liquid water is most dense at 4 C.
so your statement "Hot water is heavier than cold water." if you mean a certain volume of water is true only from 0 C to 4 C.
This is also true,
W = density x volume x g, where density x volume = mass
So you can state either of the following:( increasing temperature above 4 C )
and neglecting the very tiny energy increase as per Antiphon
1. I start with a container of volume V containing water. Increasing the temperature will decrease the density of the water. Therefor, as I increase the temperature of the water, the water will expand and less mass of water will fill the volume V, due to the density decrease, and the water in volume V will now weigh less than before the temperature increase.
2. I start with a container of volume V containing water. Increasing the temperature will decrease the density of the water. Therefor, as I increase the temperature of the water, the water will expand and I need a larger volume V2>V to contain the water, which has the same mass and thus the same weight as before the temperature increase.
Water is made of tiny pieces called molecules. Heat makes molecules excited. They jump around and move quickly! They need space to do this. Cold, on the other hand, makes molecules slow down and it can make them nearly stop. They don’t need as much room to move around and the space between them shrinks, It would seem that cold water would have to be denser than warm water
This is true above 4°C. Below that, water forms more and more hydrogen bonds, which increase the volume and therefore reduce the density.
Only if you want to include relativistic effects, which are extremely small here.
However, if you put real hot and cold water (of the same amount) on a very precise scale, you might measure a smaller value for hot water, as it needs more volume and therefore gets more buoyancy due to the air.
We should really get this thread in proportion I think.
It starts off with a very ill defined statement "Hot water is heavier than cold water." and, instead of dealing with that, the thread leaps into relativity. I think that the OP may need to be expanded and clarified; it really doesn't mean a lot of sense to me, as it stands. Could we start walking before we try to run?
If we look to what Einstein uncovered where mass is proportional to energy we can see that as we heat the cold water to a higher temperature giving the water a higher thermal energy this would give us a larger mass in theory and in experimentation. But you would need a very precise measuring system because the difference in mass would be extremely small compared to the overall weight. So yes, it makes sense that hot water is heavier than cold water but in normal/every day practices it's not very practical to even consider it or take it into consideration.
Yes, I was thinking the same. But then you realize hit water evaporates. Shouldn't that affect the mass? Even if you put a lid on top of the hot water container, the condensation that occurs means that some energy is lost in that transition.
p.s. I don't think I need to clarify, but I'm talking about mass not weight.
If you remove water, the mass goes down, of course.
Evaporation->condensation is just a re-distribution of energy and water, it does not change the total energy content.
my logic is this: for water to evaporate it needs to be heated up, energy needs to be added. we've already done that by heating up the water to make it hot for our experiment. so that amount of energy is no longer relevant because we only care for the water after it became hot. however, when water condensate it loses energy, doesn't it? As far as I remember vapor becomes liquid because it cools down. Shouldn't that cooling down affect the overall energy level of the water?
On second thought I think I'm overly complicating things when I consider the water's interaction with the environment. Because I have to consider the effects of the environment on the cold water as well.
So, to recap: if we take relativistic effects into consideration (and I see no reason not to) hot water has more mass than cold water. even if that difference is undetectably small.
Those relativistic effects are *tiny*. You are ignoring the classical effects which are multiple orders of magnitude larger. You only take relativistic effects into account when you have already accounted for everything else.
Well, it releases heat to the environment, the energy is not lost.
To give an idea about the effect size: To bring 1kg of room temperature (20°C) water to the boiling point, you need an energy of ~320kJ. This leads to a mass increase of 3.6ng or 0.0000000000036 kg.
At the same time, if pressure is constant, the volume increases by 41.6cm3, replacing air with a mass of 53mg or 0.000053kg. Buoyancy is 7 orders of magnitude stronger than relativistic effects.
thank you for these calculations :) I didn't mean "lost" like destroyed. I meant it in the sense you mean it. And I thought lawyers were picky about words :biggrin:
If we repeat this experiment with volume as constant i.e. putting same amount of water at same temperature in two closed containers so that they are full without any air gap, then heat one of those. After the heated one has gained enough energy, its mass will be more, even though its weight on Earth is same?? (If it is correct, can we generalize that objects having same weight on Earth can have different mass?)
No we can't. The energy added to a water would add to stronger gravitational attraction, therefor weighing more
Right, increasing the mass also increases the weight.
By the way: those 7 orders of magnitude for buoyancy effects would put unrealistic constraints on the stiffness of the container.
Not true. Both liquid water and ice will undergo net vaporization whenever the overlying vapor pressure is less than the equilibrium pressure. The process is completely spontaneous. You don't have to add heat. If no heat is added, the enthalpy of vaporization will be provided by the water (or ice) itself, thereby reducing its temperature.
Please pay closer attention. This is 'June' thread. Launched in June 2012, sustained in June 2013, and now you've messed everything up by posting in December!
Edit by NSA: Please ignore comment by TumblingDice. There is nothing out-of-the-ordinary, unusual, or otherwise significant about the timing and content of the posts in this thread. Carry on!
It's wrong to say that cold water is heavier than hot water, it's just heavier per unit volume, but both have same mass so according density=mass/volume, mass is constant therefore when density increases the volume will decrease, Cold water has a higher density and less volume but same mass and same weight, in another way W=pvg there is an inverse relation between p and v when mass is constant so weight will always stay the same
this is based on very simple physics,
At an advanced level you can say that hot water is greater in mass "According Einstein" as there is a direct relation between energy and mass but that isn't practically taken in consideration as it has a mere effect
There is nothing new coming, just repetitions of old posts, so it is pointless to continue this thread.
Closed.
1. Why is hot water heavier than cold water?
Hot water is heavier than cold water because hot water molecules are more spread out and take up more space, making the overall volume of the water larger. This results in a higher density and therefore a heavier weight.
2. How much heavier is hot water compared to cold water?
The difference in weight between hot and cold water can vary depending on the temperature difference and the amount of water being compared. However, on average, hot water is about 4% heavier than cold water.
3. Does this mean hot water is more dense than cold water?
Yes, hot water is more dense than cold water due to the increased spacing of its molecules. This means that the same volume of hot water will have a higher mass than the same volume of cold water.
4. How does the temperature affect the density of water?
The density of water is inversely related to its temperature. This means that as the temperature of water increases, its density decreases. This is due to the fact that as water molecules gain energy and move faster, they take up more space and decrease the overall density of the water.
5. Are there any practical applications of knowing that hot water is heavier than cold water?
Yes, this is the reason why hot water rises and cold water sinks, creating convection currents in bodies of water. This can also be seen in hot water heaters, where the hotter water rises to the top of the tank. Additionally, knowing the density of hot and cold water is important in industries such as food and beverage production, where precise measurements are needed for consistency in products.
  • Mechanical Engineering
