banerjeerupak
- 123
- 1
could someone let me know the problems being faced while using disc brakes in any sort of vehicles?
SRode said:PML built an electric car that took a neat spin on braking:
http://www.treehugger.com/files/2006/08/the_hybrid_mini.php
reverseing the motors spin to create a braking force.
Disc brakes offer better stopping power and are more efficient at dissipating heat compared to drum brakes. They also have a longer lifespan and are less prone to brake fade, providing a more reliable braking system.
Yes, disc brakes tend to be more expensive than drum brakes due to their more complex design and the use of additional components such as calipers and rotors. However, the cost difference is often offset by the longer lifespan and improved performance of disc brakes.
Disc brakes generally require less maintenance compared to drum brakes. They have fewer moving parts and are less susceptible to wear and tear. However, regular inspection and replacement of brake pads and rotors is still necessary for optimal performance.
One major disadvantage of disc brakes is that they are more sensitive to water and dirt compared to drum brakes. This can cause reduced braking performance in wet or muddy conditions. Additionally, disc brakes can be more difficult to service and repair without proper tools and knowledge.
While disc brakes are commonly used in most modern vehicles, they may not be suitable for all types of vehicles. For example, heavy-duty trucks and off-road vehicles may benefit more from the simplicity and durability of drum brakes. The type of vehicle and its intended use should be considered when deciding between disc and drum brakes.
