Siracuse
- 23
I'll describe this without the numbers, values and such. The issue here is to understand the logic worked on this problem...well any problem is like that. Anyhow, this is the situation:
A block of mass m1 is stacked on the surface of another block of mass m2 of width L, where m2>>m1. There is kinetic friction between those two blocks, static friction coefficient is not given. Block m2 is on a frictionless surface. An horizontal, constant force F is applied on block m1. The whole system of blocks moves.
Sum of forces in x,y components;
First thing: since there is a friction force, calculating the normal force in this case is important. For block m1,
Fn_m1 - Fg_m1 + Fn_m2 = 0 -> Fn_m1 = Fg_m1 - F_m2;
For block m2,
Fn_m2 - Fg_m1 - Fg_m2 = 0 -> Fn_m2 = Fg_m1 + Fg_m2;
The rest should just involve basic algebra, to obtain Fn_m1 and, therefore, the value of the kinetic friction force.
Now, to work on the second part, the x-axis. Block m1:
F - F_kin = m.a
For block m2...here's where I think I don't know what I am doing. The picture of my Halliday book shows block m2 moving, so what kind of forces are acting on m2 in the x-axis? Is there a resulting force derived from the friction between the blocks? I've thought about this for a while and I'm just clueless. Not even sure if my logic for the forces on the y-axis is correct...
