If diamonds are made of carbon? and coal is made out carbon
In summary, diamonds are transparent due to their crystaline structure, which differs from the crystal structure of coal. This structure also affects other properties such as strength and density. The process of creating diamonds is expensive, but synthetic diamonds are still produced in large quantities. Some companies are able to create large, transparent diamonds for use in jewelry or as substrates in industries such as semiconductors. The band gap in diamonds is larger than that of coal, making diamonds transparent while coal absorbs all frequencies of light.
Sammyg
If diamonds are made of carbon? and coal is made out carbon, why are diamonds transparent and coal is not transparent?
Crystaline structure?
Diamonds are carbon put into high amounts of pressure and heat.
The whole process is very expencive, too expencive for any practical use in making them. The quantity of diamond you get out of any amount of carbon is too costly to be beneficial, therefore, this process is rarely used, if ever.
What Phrak said. It is the crystal structure that is different, i.e. how the carbon atoms are arranged.
Note that it isn't just the optical properties that's different due to the crystal structure difference. The physical strength of the material is also different. Compare the hardness of graphite versus diamond.
This is a good example on why many of the properties of solids depends NOT on the "atomic" properties of the individual atoms making up the solid, but on the "collective" property of the atoms, i.e. how they behave as a whole group. This is why how the atoms of the material are arranged and how they behave collectively are extremely important.
Zz.
Diamond density is about 3.5 to 3.53 grams per cubic cm, while graphite is only 2.0 to 2.25 grams per cubic cm.
And what does that have to do with transparency?
[Bob S] Diamond density is about 3.5 to 3.53 grams per cubic cm, while graphite is only 2.0 to 2.25 grams per cubic cm.
Diamond is one of several carbon allotropes, which include fullerenes {buckyballs), nanotubes, graphite, graphene, and coal (not really an allotrope). Graphite is a good electrical conductor, while diamond is a good insulator. Diamond is a very good thermal conductor but at the same time an electrical insulator (doesn't obey the Wiedeman Franz law). If sulfur can have red, yellow, and black allotropes, why can't carbon have one that is transparent?
Yes, but the industry produces in the region of 3 billion carats, or 600 metric tons of synthetic diamonds a year.
Indeed, diamonds are much more common that most people think; the reason you don't see more often them is simply that most of the diamonds are quite small (e.g. the ones used on tools such as drills etc).
That said, there are "simple" methods that can be used to grow quite large diamonds but the ones I've seen have all been almost pink so they weren't exactly something you would make jewelry of; but they are still as hard as a "proper" diamond so they have their uses.
There are some companies that can grow large, transparant, diamonds that can be used in jewellry; the ones from e.g. Apollo Diamond are apparently very good.
There are also companies that are trying to make large diamond substrates for e.g the semiconductor industry. Large diamonds can actually also be used as a substrate for growing YBCO thin films (a high temperature superconductor) although there aren't many people doing that:tongue:
Maybe we can explain using semiconductor concept. Semiconductor has a band gap which is the difference between valence band and conduction band, and photons of larger energy than this band gap can be absorbed. In diamond the band gab is larger than visual light I think, but in silicon it is not. So silicon can be used as a infrared light pass filter blocking visual light. Coal is obviously mixture of many crystal like forms so the overall band gap is almost zero, meaning that all frequency light will be absorbed.
1. How can diamonds and coal both be made of carbon?
Diamonds and coal are both forms of carbon because they are both made of the same element, carbon. However, the difference lies in the way the carbon atoms are arranged. In diamonds, the carbon atoms are arranged in a tightly bonded, crystalline structure, making it the hardest naturally occurring substance. In coal, the carbon atoms are bonded more loosely, resulting in a softer, more brittle substance.
2. Why are diamonds more valuable than coal if they are both made of carbon?
The value of diamonds is determined by a combination of factors including rarity, durability, and demand. Diamonds are much rarer than coal, which is abundant and widely used for energy production. Additionally, the unique qualities of diamonds, such as their brilliance and hardness, make them highly sought after for use in jewelry and industrial applications.
3. Is the process of forming diamonds and coal the same?
No, the process of forming diamonds and coal is not the same. Diamonds are formed deep within the Earth's mantle under intense heat and pressure, whereas coal forms from the remains of plants and trees that were buried and subjected to heat and pressure over millions of years.
4. Can coal be turned into diamonds?
Technically, yes, coal can be turned into diamonds through a process called "synthetic diamond production." This involves subjecting coal to high temperatures and pressures in a laboratory setting, mimicking the natural conditions that form diamonds. However, this process is expensive and not economically feasible on a large scale.
5. Are diamonds and coal the only forms of carbon?
No, diamonds and coal are not the only forms of carbon. Graphite, for example, is also a form of carbon. It has a layered, hexagonal structure and is used in pencils and as a lubricant due to its slippery properties. Other forms of carbon include fullerenes, nanotubes, and graphene, which have unique properties and potential applications in various industries.
  • Atomic and Condensed Matter
  • General Engineering
