Does twinklingdepends on the star or the distance?
  • Thread starter Astro.padma
  • Tags
    Star
In summary: So if you had two stars of the same magnitude but one was 10x bigger than the other and much further away, then the bigger star would twinkle 10x more than the smaller one.
Astro.padma
80
I am here with another silly doubt...Is twinkling because of the star or the distance? What matters here?
For example...If the stars Sirius and Proxima Centauri were at the same distance from earth, which star would twinkle more?
As they are at the same distance, would they twinkle equally?
Um...am sorry if my questions are a bit silly but please try to answer them as I am really a beginner :)
Astronomy news on Phys.org
As far as your naked eye can determine all stars are point sources of light and twinkling is due to atmospheric disturbances of the light path. A brighter star would probably seem to twinkle more only because it stands out from the background better. And the brightness I am referring to is the brightness as perceived here, not the absolute brightness of a star. Planets don't twinkle because they subtend a very small, but noticeable arc. The atmospheric disturbances are not great enough to make a planet twinkle.
Subductionzon said:
A brighter star would probably seem to twinkle more only because it stands out from the background better. And the brightness I am referring to is the brightness as perceived here, not the absolute brightness of a star. .
Sir...then is it that both the Proxima and Sirius twinkle equally as they are assumed to be at same distance and thus having same background...am I right?
And what about the absolute brightness of a star? Wouldnt it contribute anything to our present context?
It has nothing to do with the distance, only the visible (apparent) brightness. All stars are far enough away that they effectively act as point sources, so the distance doesn't actually matter.
then do they twinkle equally?
If they are the same apparent brightness yes. And I am sure that an astronomer could come up with the correct term, but when I say apparent brightness I mean the brightness that your eye perceives, not the brightness at the star itself.
Subductionzon... what do u mean by same apparent brightness, when it is the single person viewing both the Proxima and Sirius, at same time?
I mean...the eye would perceive, same brightness, right?
umm :( aint understanding...which answer is right? Is it yes or no?
What I understand here is...One says that They don't twinkle equally because both of them are at almost large distances so only their individual brightness matters.
and the other says that Yes, they do twinkle equally because they would be of same background and there wouldn't be any atmospheric disturbances.
Am I right or gone wrong somewhere...Excuse me if it is but someone please get me some clarification:)
There are two ways to talk about how bright a star is. The first is to talk of its "magnitude" that is how bright it appears here on Earth. The second would be to talk about how bright it is from some set distance from the star.
For twinkling we are using the first definition of how bright a star is. So yes if both stars are of the same magnitude, that is they appear to be the same brightness here on Earth, then they will twinkle the same amount. I hope that answers your question. We really don't car how bright they are at the source, only how bright they appear here on the Earth.
Subductionzon said:
For twinkling we are using the first definition of how bright a star is. So yes if both stars are of the same magnitude, that is they appear to be the same brightness here on Earth, then they will twinkle the same amount. I hope that answers your question. QUOTE]
No...I think I've confused you ... See, they are Proxima and Sirius of magnitudes 11.05 and (-1.46) , respectively.They are at different distances from the earth. My question is if they are at same distance, would they twinkle equally?
Here, in this case, both Proxima and Sirius are entirely different in their magnitudes...but they are at same distance...now would they twinkle equally?
The distance to all stars is so huge that distance does not matter. All stars that you can see with your eye are effectively point sources. So they all twinkle. If they are of the same magnitude they will twinkle the same regardless of how far away the star is. Whether a brighter or dimmer star "twinkles" more would be a matter of opinion. But if you had two stars that were equally bright as seen from Earth but one was one thousand times bigger than the other and much further away so there magnitudes here were equal they would twinkle in the same fashion.
Twinkling is caused by the Earths atmosphere so the perceived twinklyness(?? :S) would probably depend on the apparent magnitude, as it would be easier to see the twinkling of a bright star, and which was seen through a more distorting atmosphere
Sorry... :( any other?
1. Does the color of a star affect its twinkling?
No, the color of a star does not affect its twinkling. Twinkling is caused by the Earth's atmosphere and the movement of air, not the star itself.
2. Are some stars more prone to twinkling than others?
Yes, some stars may appear to twinkle more than others due to their location in the sky and the atmospheric conditions at that time. Stars closer to the horizon may appear to twinkle more because their light has to pass through more of the Earth's atmosphere.
3. Does the distance of a star from Earth affect its twinkling?
Yes, the distance of a star from Earth can affect its twinkling. Stars that are closer to Earth may appear to twinkle more because their light has to travel through more of the Earth's atmosphere. However, the brightness and size of the star also play a role in how much it appears to twinkle.
4. Can we see stars twinkle in space?
No, stars do not appear to twinkle in space because there is no atmosphere to cause the light to bend and create the twinkling effect. However, other celestial objects such as planets may appear to twinkle when viewed from space due to their reflective surfaces.
5. Why do stars appear to twinkle at night but not during the day?
Stars appear to twinkle at night because we are viewing them through the Earth's atmosphere, which causes the light to bend and create the twinkling effect. During the day, the light from the sun is much brighter and overpowers the faint light from the stars, making them appear steady.
  • Astronomy and Astrophysics
