What is the Speed of Changes in Gravitational Fields?
In summary: Whatever that means.)In summary, the conversation discusses the speed of gravity and how it is affected by finite propagation, as well as the concept of mass and its relation to acceleration. Theories of gravity and mass are mentioned, and the conversation ends with a discussion about the speed of gravity waves and its relation to electromagnetism. Ultimately, the question of why some objects have more mass and are harder to accelerate remains unanswered.
ParamTv
I am confused some people are saying Gravity has speed of light and some are talking about infinite speed.
Friends tell me what exact is speed of gravity.
If you have any way to demonstrate it please share with me.
ok
and my new question is why matter has mass??
tHANKS
From the Frequently Asked Questions section of our relativity forum:
https://www.physicsforums.com/showthread.php?t=635645 [Broken]
Many, if not all, solar system simulators assume instantaneous speed of gravity, and apparently that just works. Like this one for example: http://www.orbitsimulator.com
However, author of that simulator himself said on his forum that's not completely accurate, even though he also claims the simulator stays stable/accurate for thousands if not millions of simulated years. Hmmm. On the other hand I've seen on some Wikipedia-talk page some people supposedly made similar simulation but limited speed of gravity to the speed of light and that simulation then became unstable and planets flew away. Response to that was that they failed to account for many other effects given by SR/GR that would counter the error and that if you take all the effects into account they would balance out so that simulation taking into account all the SR/GR effects would produce the same result as if you don't account for any them and just assume the speed of gravity is instantaneous. Go figure!
tHANKS
You tell me why would any matter, or space even, or anything at all, exist in the first place, and then I'll tell you why matter has mass. Ok?
Finite propagation of gravitational influence does change the orbits a bit, but the dominant effect (emission of gravitational waves) is already negligible for planets (~200 W for Earth I think). The modified effective potential is more interesting, as it causes a measurable perihelion shift of mercury - something you won't get in a (proper) simulation with Newtonian gravity.
All I know about it is what I wrote above, so please tell me more about what you just said. Like about that "modified effective potential", does that include finite gravity propagation is or is it just modification to Newtonian gravity? Also, if you could explain what is the difference about Mercury orbit with and without that correction.
mfb said:
It is a modification to Newtonian gravity which can be calculated in General Relativity. See Perihelion precession of Mercury and relativistic two-body problem at Wikipedia for details, or try to find some book about GR (there are many).
It is not clear to me is that correction related to finite gravity propagation or something else. The article only says: "In general relativity, this remaining precession... is explained by gravitation being mediated by the curvature of spacetime."
However other articles on the internet seem to suggest the correction is about Lienard-Wiechert retarded potentials, which I'd think belongs more to Special than General relativity, but in either case it's about finite propagation of gravity rather than curvatures of space-time, unless curvatures of space-time somehow imply finite propagation of gravity.
Basically, people noticed that some objects took more force to accelerate. They then decided to define mass as "how hard it is to accelerate something."
Until Newton and Galileo came along, the theories of motion, despite being somewhat wrong, still used the same definition. It remained the same after Newton and Galileo.
So, I guess you're asking why some stuff is harder to accelerate? No one really truly knows why (though there would be a few mathematical weirdnesses otherwise,) but the bottom line is that every experiment or observation so far agrees with the current theories of mass. All physical theories are, in a sense, guesses; just because one experiment agrees with it doesn't mean all will. (An interesting parallel would be that the sequence 2, 4, 6, 8, ... doesn't necessarily have to have 10 next, it could be the sequence of even numbers that don't have a 0 as their last digit.)
The current theories are just absurdly well-tested; no observations thus far contradict them. No one really knows "why" they're true, we just know (or, rather, are really, really, really close to being absolutely sure) they're true. Let's imagine there are two answers to the question you asked. I doubt there would be any experiment that could distinguish between them.
It's probably better to ask what the speed of gravity waves are. Asking what the speed of gravity is is like asking what the speed of electromagnetism is.
I think that question is meaningless. Both the finite propagation speed and the modified potentials are results of GR.
SR alone gives wrong results for orbiting objects. This should not be surprising, as SR is the special case of GR without gravity (and without expansion/contraction of space).
ok
tHANKS
In the case of one body orbiting another there is nothing propagating so speed is meaningless. The gravitational field is just there, just as an electric field is just there around a charged body. Changes in the field is a different story, in both cases changes in the field propagate at c.
This can be conceptualized as two people swinging around each other holding a tense rope.
The tension in the rope is felt by both parties all the time they swing. But if one person tugs or let's go, it will take some amount of time for this to be felt by the person on the other end. Now, for short ropes the changes will seem instant because our perceptions are limited, but if you watched on high speed film, you could actually see the change propagating down the rope.
What is the Speed of Gravity?
The speed of gravity refers to the rate at which the force of gravity travels through space. This is an important concept in physics and astronomy, as it helps us understand how objects interact with each other and how the universe behaves.
1. How is the speed of gravity measured?
The speed of gravity is measured using mathematical equations and observations of celestial bodies. Scientists use the laws of gravity and motion to calculate the speed at which objects are attracted to each other. This speed is commonly referred to as the speed of gravity.
2. Does the speed of gravity change?
No, the speed of gravity does not change. According to Einstein's theory of general relativity, the speed of gravity is constant and is equal to the speed of light, which is approximately 299,792,458 meters per second.
3. How does the speed of gravity compare to the speed of light?
As mentioned earlier, the speed of gravity is equal to the speed of light. This means that both forces travel at the same rate through space. However, the effects of gravity can be felt instantaneously, while the effects of light take time to travel from one point to another.
4. Can the speed of gravity be faster than the speed of light?
According to current scientific understanding, the speed of gravity cannot be faster than the speed of light. This is because the speed of light is considered to be the maximum speed at which anything can travel in the universe. Any force, including gravity, cannot exceed this speed.
5. Why is the speed of gravity important?
The speed of gravity is important because it helps us understand the behavior of objects in our universe. It also plays a crucial role in fields such as astronomy, space travel, and satellite communication. Understanding the speed of gravity is essential for unlocking the mysteries of our universe and making advancements in science and technology.
