Register to reply
Low Voltage Power Inverter
by tommycaiden
Tags: inverter, power, voltage
Share this thread:
tommycaiden
#1
Feb21-14, 05:02 PM
P: 2
Hey guys, I need to make a power inverter that will take in .1-.3 volts, and the output needs to be as high as possible.
Phys.Org News Partner Engineering news on Phys.org
Tricorder XPRIZE: 10 teams advance in global competition to develop consumer-focused diagnostic device
Study shows local seismic isolation and damping methods provide optimal protection for essential computing equipment
New filter technology uses inert gas to bore holes in high-quality steel
NascentOxygen
#2
Feb21-14, 06:40 PM
HW Helper
Thanks
P: 5,341
Quote Quote by tommycaiden View Post
Is that the output voltage or current you'd like to allow be as high as possible? If output voltage, what do you consider acceptably high, and at how many milliamps? What is the application you have in mind?
You really do need to be less vague in framing requests for advice here, to encourage those who may be able to help you. You'll discover that mind-reading is not everyone's specialty.
meBigGuy
#3
Feb21-14, 10:10 PM
P: 1,084
best I know of the the joule thief (search for it). Not sure how low it actually goes though.
Mike_In_Plano
#4
Feb28-14, 11:08 PM
P: 560
If you're converting any significant amount of power, you'll have a lot of current. MOSFETs designed for synchornous rectification and a highly specialized transformer with a copper strap primary are probably the best bet.
I don't think there's anything like that off the shelf.
Some converters, like the NCP1400 series, will operate down to .3 volts if you raise their output to a couple of volts first.
Register to reply
Related Discussions
Inverter low voltage high current 5-12v in 13.8v out 30 amps Electrical Engineering 2
What to do with a DC to AC power inverter? Engineering Systems & Design 8
Modify computer inverter to accept power from house inverter Electrical Engineering 0
