oneplusone
- 127
- 2
Suppose you have a system of charges on the xy plane. Am i correct in saying that the place where you have zero volts, is the place where you can put a charge and it WONT move?
oneplusone said:Suppose you have a system of charges on the xy plane. Am i correct in saying that the place where you have zero volts, is the place where you can put a charge and it WONT move?
The force on a charge is zero at a specific spot when the electric field at that spot is zero. This can occur when there are equal and opposite charges cancelling each other out, or when the electric field lines are parallel and the charge is perpendicular to them.
The voltage at a spot where the force on a charge is zero can be calculated using the formula V = -∫E * dr, where E is the electric field and dr is the displacement vector from the reference point to the spot where the voltage is being calculated. This integral can also be simplified to V = -ΔV, where ΔV is the change in voltage from the reference point to the spot where the force is zero.
No, the voltage at a spot where the force on a charge is zero is not always zero. While the electric field may be zero at that spot, the voltage can still be influenced by the electric potential of nearby charges.
Yes, the voltage at a spot where the force on a charge is zero can change over time. This can happen when the charges creating the electric field are moving, when new charges are introduced, or when the distance between the charges and the spot changes.
The voltage at a spot where the force on a charge is zero does not directly affect the movement of charges. However, the electric field at that spot can determine the direction and magnitude of the force on a charge, which in turn can affect the movement of the charge.
