Unlocking Limitless Green Energy: Harnessing Earth's Rotational Kinetic Energy
In summary, the conversation discusses the idea of using the Earth's rotational kinetic energy as a source of power. However, it is concluded that this would not be feasible as it would require reducing the Earth's angular momentum, which would have negative consequences for the planet. Instead, alternative sources of energy such as tidal power are suggested. It is also mentioned that tapping tidal energy would have a small but quantifiable effect on the Earth's rotation.
GRDixon
249
The Earth rotates in inertial space. The amount of rotational kinetic energy is enormous ... millions of mankind's annual consumption. Is there any kind of apparatus, perhaps one based on gyros, that could tap into this energy?
I don't this can work at all. To use the kinetic energy of the Earth we must slow it down, and that can only be done by transferring the angular momentum of the Earth to something else (the moon for tidal energy).
Gyros? Well, the energy required to sustain their action exceeds the energy able to be extracted from this or any other arrangement.
From an engineering perspective, I think it would be rather difficult to get the other portion of the contraption to stand still (i.e. you have to have something that's not rotating with the Earth to take advantage of the Earth's rotation). Good luck with that!
Addendum:
I hadn't considered Foucault. Neat idea.
Anyway, if you change the period of rotation of the Earth, many species wouldn't adapt and die.
Well, I wouldn't deny that's true for a significant change in the period. But at what point do we consider it significant?
What about conservation of angular momentum?
Try tidal power.
Try tidal power.
Another good one! This one is already being used too! There's several different engineering approaches to it.
Don't imagine that there would be any significant change in the period of rotation if you consider the mass of the Earth.
It might actualy be speeding up at present due to the amount of hydro electric scheems in the northern hemisphere.
I imagine any slowing would be counteracted by rainfall, by angular momentum when it falls or dams.
...anyone going to attempt to quantify the issue...?
If you do not use the moon in some way, the energy you can gain is exactly zero, since there's no way to reduce the angular momentum of the earth.
How's that? doesn't driving a car give angular acceleration the the earth?
And it takes it away again as soon as you stand still again. The angular momentum of the Earth with the car remains the same.
As the Earth rotates, the tidal bulge follows a bit behind the Earth-Sun line (neglecting the moon) and so there is a tidal torque on the Earth reducing its rotational angular momentum and converting some of that to orbital angular momentum. You can alter the angular momentum of the Earth but not of the Earth-Sun or Earth-Sun-Moon system except by exterior effects (e.g. Jupiter).
As mentioned tapping tidal energy is tapping the rotational kinetic energy of the Earth. Tapping tidal energy would imperceptibly but quantifiably increase the lag of the tidal bulge, increasing the rate of tidal slowing of the Earth's rotation.
What is "Limitless Green Energy"?
"Limitless Green Energy" refers to energy sources that are renewable and do not produce harmful emissions. These sources include solar, wind, hydro, geothermal, and biomass energy.
How is "Limitless Green Energy" different from traditional energy sources?
"Limitless Green Energy" is different from traditional energy sources because it is renewable, meaning it will never run out, and it does not produce harmful emissions that contribute to climate change. Traditional energy sources, such as fossil fuels, are finite and produce greenhouse gases when burned.
What are the benefits of using "Limitless Green Energy"?
The benefits of using "Limitless Green Energy" include reducing our dependence on finite resources, decreasing our carbon footprint, and improving air and water quality. It also has the potential to create new jobs and stimulate economic growth in the renewable energy sector.
What are the challenges of implementing "Limitless Green Energy"?
The main challenges of implementing "Limitless Green Energy" are the initial costs of infrastructure and technology, as well as the need for government policies and incentives to encourage the shift to renewable energy. There may also be resistance from industries that rely on traditional energy sources.
Is "Limitless Green Energy" truly limitless?
While "Limitless Green Energy" sources are renewable and will not run out, they still require careful management and planning to ensure their sustainability. Additionally, certain factors such as weather conditions can affect the availability of some renewable energy sources. However, with advancements in technology and efficient use, "Limitless Green Energy" has the potential to meet our energy needs for generations to come.
  • Classical Physics
33K
