Is there such a thing as lumens/m^3?Would you have to be measuring
  • Thread starter ABHoT
  • Tags
    Measuring
In summary, there is no such thing as lumens per cubic meter and there is no equivalent to lumens per square meter for electromagnetic energy. Lumens per square meter is a measure of perceived brightness and the closest thing to making it meaningful would be to measure the light scattered by a fog or volume of fluid.
ABHoT
33
Would you have to be measuring incoming light/energy from every (infinite) direction at the same time?
Can it be estimated or got from lumens/m^2?
Astronomy news on Phys.org
Not really a meaningful unit. Light that moves through space without reaching a human eye has 0 lumens. Lumens/m^2 is a measure of perceived brightness.
The closest thing to making it meaningful would be to measure the light being scattered by a fog or volume of fluid. That could be described as lumens per unit volume.
Aha, thanks. I think I'm confusing lumens/m^2 as a measure of electromagnetic energy. Is there an equivalent to lumens/m^2 for em energy?
1. Is there such a thing as lumens/m^3?
Yes, there is such a thing as lumens/m^3. Lumens per cubic meter (lm/m^3) is a unit of measurement for luminance, which is the amount of visible light per unit area emitted or reflected from a surface. It is commonly used in lighting design and calculations.
2. How is lumens/m^3 measured?
Lumens/m^3 is usually measured using a device called a luminance meter, which measures the amount of light that passes through a specific area in a given direction. It can also be calculated by multiplying the luminance (in cd/m^2) by the solid angle (in sr).
3. What is the difference between lumens/m^3 and lumens?
Lumens/m^3 measures luminance, while lumens measures luminous flux, which is the total amount of visible light emitted from a source. Luminance takes into account the area and direction of the light source, while luminous flux does not.
4. Why is lumens/m^3 important?
Lumens/m^3 is important because it helps determine the amount of light that is perceived by the human eye and how bright a surface appears. It is also used in lighting design to ensure that the desired level of lighting is achieved in a space.
5. Can lumens/m^3 be converted to other units of measurement?
Yes, lumens/m^3 can be converted to other units of measurement such as lux, which measures illuminance, or foot-candles, which is also a unit of illuminance commonly used in the United States. The conversion factor will depend on the specific units being converted.
  • Classical Physics
  • Electrical Engineering
  • Other Physics Topics
  • Astronomy and Astrophysics
  • Electromagnetism
