Help How to get green function of Bessel's differential equation?
In summary, the conversation discusses a project that involves a Bessel's differential equation with a stochastic source. The equation is given and the parameters are defined. The main question is how to obtain the green function for this type of differential equation. However, it is suggested that the green function may not be necessary and the general solution can be found if one can solve the homogeneous linear DE. A generalized solution for the non-homogeneous linear DE is also given. If the green function is still desired, a substitution can be made to obtain it. The conversation ends with a compliment to the expert summarizer.
inflaton
In my project, we enconter such kind of bessel's differential equation with stochastic source, like
[tex]\Phi''+\frac{1+2\nu}{\tau}\Phi'+k^2\Phi=\lambda\psi(\tau)[/tex]
where we use prime to denote the derivative with [tex]\tau[/tex], [tex]\nu[/tex]
and [tex]\lambda[/tex] are real constant parameter.
how to get the green function of bessel's differential equation?
I do not think that you need the Green function to solve your problem.
If you can solve homogeneous linear DE, then you can easily write out the general solution to the corresponding non-homogeneous linear DE (see http://arxiv.org/abs/math-ph/0409035" ).
In your case
[tex]\Phi(\tau) = \tau^{-\nu}J_\nu}(k\tau)\,C1+\tau^{-\nu}Y_\nu(k\tau)\,C2-\frac{1}{2}\tau^{-\nu}\pi\lambda[\int\,-\tau^{\nu+1}J_\nu(k\tau)\psi(\tau)\,d\tau\,Y_\nu(k\tau)+\int\,\tau^{\nu+1}Y_\nu(k\tau)\psi(\tau)\,d\tau\,J_\nu(k\tau)][/tex]
If you nevertheless do like the Green function, substitute [tex]\psi(\tau)=\delta(\tau-\tau_0)[/tex] to the above expression.
In your case
Thanks! You are master!
1. What is a green function?
A green function is a mathematical function that is used to solve differential equations. It represents the response of a system to an impulse input.
2. How is the green function related to Bessel's differential equation?
Bessel's differential equation is a type of second-order linear differential equation that is commonly used in physics and engineering. The green function for Bessel's equation helps to solve the equation and find a particular solution.
3. How do you obtain the green function of Bessel's differential equation?
To obtain the green function of Bessel's differential equation, you can use integral transforms such as the Laplace transform or the Fourier transform. These transforms will convert the differential equation into an algebraic equation, making it easier to solve for the green function.
4. What are the applications of the green function of Bessel's differential equation?
The green function of Bessel's differential equation has many applications in physics and engineering, including solving problems related to heat transfer, electromagnetism, and fluid dynamics. It is also used in signal processing and image processing.
5. Are there any resources available to help understand the concept of the green function of Bessel's differential equation?
Yes, there are many resources available, including textbooks, online tutorials, and videos, that can help you understand the concept of the green function of Bessel's differential equation. You can also consult with a math or physics tutor for personalized help.
  • Differential Equations
