Relation between suspension switching frequency and body eigefrequency
In summary, slow-active suspensions realize small switching frequencies to control low-frequency body movements,such as roll pitch and lifting motions.Fully-active suspensions reach switching frequencies,like semi-active suspensions,greater than the natural eigen-frequencies of the vehicle. This allows the suspension to control the response of the system,preventing it from occurring at frequencies that would be harmful to the car.
marellasunny
255
'Slow-active suspensions realize small switching frequencies to control low-frequency body movements,such as roll pitch and lifting motions.Fully-active suspensions reach switching frequencies,like semi-active suspensions,greater than the natural eigen-frequencies of the vehicle.'- an excerpt from a book.
I have 2 questions:
1.If body roll,body pitch and lifting make-up for the low frequency body motions,what would be classified as high frequency vibration?
2.Looks like active suspensions just provide a counter force. How does having a switching frequency greater than the natural eigen-frequency of the vehicle help? Does the author mean to imply that the suspension has to think faster than the rate at which bumps come-up on the road?
I'm slightly guessing here. In aircraft design the crossover between "high" and "low" is fairly arbitrary but it is often taken as 20 Hz, since the frequencies of the main structural vibrations like bending and torsion of the wings in flight, or the plane on its undercarriage when landing, are below that frequency.
I suppose for auto design the same principle applies, i.e. "low" means below the natural frequencies in roll, pitch, yaw of the vehicle and its suspension - in other words the frequency you would see if you push down on a car body and "bounce" the suspension.
The frequency of the applied forces from bumps in the road, engine vibration, unbalanced wheels, etc would be higher than the largest frequency components of the response. An active suspension could either try to control the response (low frequencies) and more or less ignore what caused it, or counterbalance the forces (high frequencies) to prevent the response developing at all.
The use of the word 'response' complicated things for me.Response is what here exactly? You classified response under low frequencies in your text.I'm thinking in terms of the body of the car 'responding' to vibrations.
I am thinking in terms of principle of functioning of a damper. When damping is very small,the resonant frequency is almost equal to the natural frequency of the system. Here, the system is split into 2 parts:high natural frequency of vibration,low natural frequency of vibration.
So,in the odd case that speed bumps equal the natural frequency of any of my system components,I am in trouble. What happens when this is not the case? my active suspension is actually wasting energy. Am I right?
1. What is the relationship between suspension switching frequency and body eigefrequency?
The suspension switching frequency refers to how often the suspension system of a vehicle responds to changes in the road surface, while the body eigefrequency is the natural frequency at which the vehicle's body vibrates. The two are related because a higher suspension switching frequency can lead to a higher body eigefrequency, resulting in a smoother and more stable ride.
2. How does the suspension switching frequency affect the handling of a vehicle?
The suspension switching frequency directly impacts the handling of a vehicle. A lower switching frequency can result in a more comfortable ride, but it may also lead to a decrease in stability and control. On the other hand, a higher switching frequency can improve handling and responsiveness, but may also cause a harsher ride.
3. Can the suspension switching frequency be adjusted?
Yes, the suspension switching frequency can be adjusted through various means such as changing the stiffness of the suspension components, altering the damping rate, or using active suspension systems. These adjustments can help optimize the suspension system for different road conditions and driving preferences.
4. What factors influence the body eigefrequency of a vehicle?
The body eigefrequency is primarily influenced by the mass and stiffness of the vehicle's body, as well as the suspension system's characteristics. Other factors such as the type of tires and the weight distribution of the vehicle can also play a role.
5. How does the relation between suspension switching frequency and body eigefrequency impact vehicle performance?
The relation between suspension switching frequency and body eigefrequency is important for achieving optimal vehicle performance. A well-matched suspension system with a suitable switching frequency and body eigefrequency can provide a smooth and comfortable ride, while also improving handling, stability, and overall performance of the vehicle.
  • Mechanical Engineering
  • Differential Equations
  • Other Physics Topics
