Register to reply
Thermal White Noise - Johnson–Nyquist noise
Share this thread:
meBigGuy
#55
Feb6-14, 08:36 PM
P: 1,072
A simplified block diagram of an analagous system would allow us to talk about it coherently. As it is, it is all arm waving and mis-understanding. You words can be interpreted in many ways, and we (well, they, actually) are slowly honing in on the narrow set of assumtions you are unconsciously making. The field is very broad, and you are viewing it with a set of hidden assumptions. An architectural diagram would help immensely.
Mechatron
#56
Feb6-14, 08:40 PM
P: 38
Quote Quote by meBigGuy View Post
Come on man, I'm almost there. Look at what I posted just recently.
Mechatron
#57
Feb6-14, 08:48 PM
P: 38
This problem really hertz
the_emi_guy
#58
Feb6-14, 09:23 PM
P: 585
Quote Quote by Mechatron View Post
This is not academic exercise. I'm researching and developing a transmitter.
So far I know that I'm looking for the flicker noise generated from thermal radiation.
I have found an equation for spectral phase noise:
http://s27.postimg.org/y8m7mo68j/Frequency.png
The flicker noise has a cut-off at the flicker corner frequency of 1/f.
So the corner frequency is measured in 1/f; 1/Hz; Hz ^ - 1 ? Yet is says the unit for corner frequency is in Hz.
But then I read on the following link:
http://en.wikipedia.org/wiki/Corner_frequency
The cutoff frequency or corner frequency is given by angular frequency.
Angular frequency is measured by 2∏¸f in Hz and not 1/Hz.
So I'm thinking the flicker noise has a frequency similar to the 20kHz signal, with a cut off frequency. So the frequency I'm interested is the difference between the flicker noise and the desired signal. So if the oscillator measures 20400 hz, the cut off frequency is 400 hz. I am thinking correctly?
Reference:
http://www.ieee.li/pdf/essay/phase_noise_basics.pdf
You need to understand that noise does not "have" a frequency. Look at the diagram in your first link. It is showing you the frequency distribution of flicker noise; extending from DC up to the point where other noise sources dominate (and beyond). The typical process is to integrate the phase noise over a frequency band of interest to obtain total noise power (in that band). That can then be converted to, say, picoseconds *RMS* of phase deviation of your clock (emphasis on RMS, the instantaneous phase deviation will be bouncing all over the place since it is caused by noise).
You have a 20KHz clock, and it is measuring 20400Hz with a frequency counter?
Have you tried replacing the suspect "hot" battery with a bench power supply?
Mechatron
#59
Feb6-14, 09:28 PM
P: 38
Quote Quote by the_emi_guy View Post
Distortion and phase noise are not typically characterized in Hz. Lets say you have a frequency drift caused by some white/pink battery noise. The amplitude of this noise will be random. The corresponding frequency drift to be random, the frequency is bouncing all over the place. We typically characterize this in units of time-rms (ps rms, ns-rms, UI-rms).
Is this an academic exercise, or are you trying to fix something that isn't working?
Have you tried powering your device from a clean bench power supply?
Tell me something. This noise voltage. Don't you agree that it's AC voltage? AC noise voltage? And AC voltages are generated with frequencies? Yes?
berkeman
#60
Feb6-14, 10:01 PM
Mentor
berkeman's Avatar
P: 40,634
I haven't been following this thread for the last page or so. Have you posted o'scope pictures of the ringing/noise and a schematic of your setup?
berkeman
#61
Feb6-14, 10:02 PM
Mentor
berkeman's Avatar
P: 40,634
Mechatron
#62
Feb6-14, 10:05 PM
P: 38
New theory:
The flicker noise is carried on the 20 kHz signal, so the signal is a carrier signal. In addition to try to calculate the cut off frequency of the flicker noise. From a different think-outside-the-box perspective;
If you can calculate the noise voltage using Johnson's equation for every instance (a unit of time):
If the noise voltage is 0 at 0 ms, 1 V at 250 ms, 0 V at 500 ms, -1 V at 750 ms and 0 V at 1000 ms, don't you agree that the frequency is 1 Hz? So since the thermal radiation generate random noise and generate a noise voltage, and the noise voltage vary, then we can say that the thermal radiation actually does have a frequency on the carrier signal.
the_emi_guy
#63
Feb6-14, 10:22 PM
P: 585
You can't calculate the noise voltages, it is a random function. It would be like calculating ahead of time rolls of a dice.
No. Because maybe the voltage at 100ms was 4V, and at 101ms was -6V etc. Get it?
Or maybe yes if for this one particular second this random noise voltage just happened to trace out a sine wave.
How likely would you expect this to be?
berkeman
#64
Feb6-14, 10:28 PM
Mentor
berkeman's Avatar
P: 40,634
Thread locked for technical Moderation
Register to reply
Related Discussions
Signal to noise ratio for thermal and shot noise Introductory Physics Homework 4
Level of johnson-Nyquist noise in analog voltmeter Electrical Engineering 3
Resistor Nyquist-Johnson noise formula question Electrical Engineering 0
Thermal Noise (Johnson–Nyquist) Classical Physics 5
Johnson noise & Shot noise Advanced Physics Homework 4
