Chemistry: Henry's law of partial pressure of gas.
In summary, Henry's Law states that the pressure of a gas in solution is directly proportional to the mole fraction of that gas in the solution, with a constant of proportionality known as the Henry's constant. When x=1, it represents a pure substance and k is equal to the pressure of the gas at that temperature, volume, and number of moles. The value of k for helium dissolved in water is 144.97, indicating the pressure of helium in a solution where it is the only gas present.
Mr Virtual
218
This is not a textbook question.
Henry's Law states that:
p=kx
where p=pressure of gas
x=mole fraction of gas in solution
k= Henry's constant
and k=p/x
So, we can say that k tells us the pressure of gas per unit x.
Which means k tells us the pressure of the gas when its mole fraction, x is unity.
But what does x=1 mean, since
x=no. of moles of solute/(no. of moles of solute + no. of moles of solvent)
if x=1
then this means: moles(solute)>>moles(solvent)
Am I wrong?
What does it mean?
Please explain...
Mr V
When x=1, it means that only that substance is present. I.e., its a pure substance. Hence, when only that gas is present, k is its pressure at that temperature/volume/per mole.
it is important to fully understand the concepts and equations we use in our work. Let's break down Henry's Law and address the questions you have raised.
First, Henry's Law states that the amount of gas dissolved in a liquid is directly proportional to the partial pressure of that gas above the liquid. In other words, the higher the partial pressure of a gas, the more of it will dissolve in the liquid.
Now, let's look at the equation p=kx. As you correctly stated, p represents the pressure of the gas and x represents the mole fraction of the gas in solution. The constant k is known as the Henry's constant and it varies depending on the gas and the solvent being used.
Next, you asked about the significance of x=1. This means that the mole fraction of the gas in solution is equal to 1, or 100%. In other words, all of the molecules in the solution are of the gas in question. This is a hypothetical scenario and not usually seen in real life, but it helps us understand the relationship between pressure and mole fraction.
Lastly, you asked about the value of k for helium dissolved in water being 144.97. This means that for every unit of mole fraction of helium in water, the pressure of the gas will be 144.97 units. This value is specific to the system of helium in water and may differ for other gases and solvents.
I hope this explanation helps clarify Henry's Law and its applications. Keep asking questions and seeking understanding in your studies of chemistry!
1. What is Henry's law?
Henry's law is a gas law that describes the relationship between the partial pressure of a gas in a liquid and the concentration of that gas in the liquid. It states that at a constant temperature, the amount of gas dissolved in a liquid is directly proportional to the partial pressure of that gas above the liquid.
2. Who discovered Henry's law?
Henry's law was discovered by English chemist William Henry in the early 19th century.
3. How is Henry's law used in real life?
Henry's law has many practical applications in everyday life. It is used in the production of carbonated beverages, where the concentration of carbon dioxide gas in the liquid is determined by its partial pressure in the container. It is also used in scuba diving, where the solubility of nitrogen in the blood is important for preventing decompression sickness.
4. What is the formula for Henry's law?
The formula for Henry's law is C = kP, where C is the concentration of the gas in the liquid, k is a constant, and P is the partial pressure of the gas. This formula assumes that the temperature remains constant.
5. What factors affect the application of Henry's law?
The temperature and the nature of the gas and liquid are the main factors that affect the application of Henry's law. Higher temperatures generally result in lower solubility of gases in liquids, while certain gases have different solubilities due to their molecular properties. Additionally, the presence of other substances in the liquid can also impact the solubility of gases according to Henry's law.
  • Materials and Chemical Engineering
  • Thermodynamics
  • Mechanical Engineering
