What is Code/binary portability ?(computer science)
  • Thread starter goksvr
  • Tags
    Science
In summary, the conversation discusses code and binary portability. Code portability refers to the ability to run the same code on different systems, while binary portability refers to the ability to run compiled code on different platforms. Conditional compiling can be used to solve code portability, but the real solution is to use standard functions that are supported by all platforms. Java and .NET use bytecode to achieve binary portability.
goksvr
Hi,
This is Gokul. Can anyone explain me what is Code/binary portability..?
Technology news on Phys.org
Imagine a program that starts:
#include <linux.h>
It's obvious that it is not portable. You can't just compile the code on a different system (Windows, Mac, ...)
This is code portability. Most of the times its "solved" using conditional compiling like this:
#ifdef WIN32
#include <windows.h>
#elseif
#include <linux.h>
#endif
This works because most of the compilers define the variable saying for which platform it is running.
The real solution is using functions that are standard and all platforms support.
Binary portability is another problem. After compiling a program to machine code, that code will run only on that specific platform. Examples:
x86, the standard intel & amd 32 bits processors
em64t, the new intel & amd 64 bits
powerpc, the old processor type used on Mac's
alpha, sparc, arm, itanium are other types
You can have for instance Linux on x86 or Linux on em64t. If you compile code for em64t it won't run on the x86 platform; you need to recompile it.
To avoid this, some languages like Java and .NET use bytecode, an independent binary form that gets translated to machine code at runtime using a virtual machine.
Hi..thank u very much
What is code/binary portability?
Code/binary portability is the ability of a computer program or code to be executed on different systems or platforms without any modifications. This means that the code can be transferred or "ported" from one system to another and still work correctly.
Why is code/binary portability important?
Code/binary portability is important because it allows software to be used on a variety of different devices and systems, making it more versatile and accessible to users. It also saves time and resources for developers by reducing the need to rewrite code for each platform.
How is code/binary portability achieved?
Code/binary portability is achieved through the use of standardized programming languages and protocols. These languages and protocols are designed to be compatible with different systems and can be interpreted or compiled to run on different platforms.
What are some challenges of achieving code/binary portability?
One of the main challenges of achieving code/binary portability is the differences in hardware and operating systems across different devices and platforms. This can lead to compatibility issues and require additional resources to make the code portable. Another challenge is ensuring that the code is efficient and optimized for each platform.
How can code/binary portability be tested?
Code/binary portability can be tested through a variety of methods, such as cross-platform testing, unit testing, and compatibility testing. This involves running the code on different systems and checking for any errors or discrepancies. Automated testing tools can also be used to detect any potential issues with portability.
