Find all groups of order 9, order 10, and order 11
  • Thread starter nhartung
  • Tags
    Groups
In summary, Homework Equations states that a group of order 9 is isomorphic to Z/9, and that if there is no element of order 9, the (non-identity) elements must all have order 3. G is isomorphic to Z/3 x Z/3, and a3 = e, b3 = e, ab = ba, and (ab)2 = (ab)2. Groups of order 10 are stated to be cyclic and isomorphic to (Z/10, +). Groups of order 11 are stated to be non-identity elements that must all have order 3.
nhartung
56
Find all groups of order 9, order 10, order 11.
None
We have already done an example in class of groups of order 4 and of order 2,3,5, or 7.
So I'm going to base my proofs on the example of groups of order 4 except for the group of order 11 which I suspect is acting like the groups of order 2,3,5 or 7 since it is also a prime number.
Here is my attempt at groups of order 9, I'm a little unsure about the final part.
Let G be a group of order 9, every element has order 1, 3, or 9. If there is an element g of order 9, then <g> = G. G is cyclic and isomorphic to (Z/9, +).
If there is no element of order 9, the (non-identity) elements must all have order 3.
G = {e, a, a2, b, b2, c, c2, d, d2}
a3 = e
b3 = e
c3 = e
d3 = e
Now i'll show the mappings of G onto Z/3 x Z/3:
e -> (0,0)
a -> (1,0)
a2 -> (2,0)
b -> (0,1)
b2 -> (0,2)
c -> (1,1)
c2 -> (2,2)
d -> (1,2)
d2 -> (2,1)
Did I do everything correctly here, and is this sufficient to find all groups of order 9 as the problem is asking?
Uh, yes, this is sufficient.
but you constructed a map from G to Z3 x Z3. I don't find it very obvious that it is an homomorfism. For example, is ab being sent to (1,1). (i.e. do you know for certain that ab=c?)
Maybe it would be better to describe the group as G = {e, a, a2, b, b2, ab, (ab)2, ab2, a2b} ?
Or am I getting myself into more trouble here?
Yes, you could do that, but the problem remains. Like, what does (ab)a equal? (I know it should equal a²b, but you need to prove it)
Yeah I was just thinking about that, I'm a little stuck on it. I can't assume this group is abelian can I? That would make for a pretty simple proof. Otherwise I guess I can try to use some sort of associativity proof.
Suppose (ab)a ≠ a2b
= (ab)a ≠ a(ab)
= a ≠ a (this is actually true a = a) which contradicts our original supposition which means (ab)a = a2b
(for some reason I have a feeling I can't just divide each side by (ab) like I did. hah). I'll keep trying other methods.
No, you can't just divide by ab sorry.
Maybe you should look back to the proof of the group of order 4. How did you show there that the map was a homomorphism. Maybe you could copy that...
Honestly, I don't know any elementary methods for finding the groups of order 9. I guess only a bit of trial-and-error could do the job...
The group of order 4 uses the theorem that if the square of every element in the group = e then the group is Abelian which I can't use for groups of order 9. I did find an example in my book for groups of order 6 which includes an element of order 3. I'll take a look at this
Do you know p-groups have a nontrivial center? If not, use the class equation. It's a pretty common group theory exercise to show all groups of order p^2 are abelian.
Ok my professor did an example of groups of order 8 in my last lecture which helped a lot so I think I have it figured out now:
Groups of order 9:
Let G be a group of order 9, every element has order 1, 3, or 9. If there is an element g of order 9, then <g> = G. G is isomorphic to Z/9.
Now let's assume the following relationships:
a3 = e
b3 = e
ab = ba (so we are abelian)
Lets check that our assumptions hold true:
aoddbodd = ab OR a OR b OR e
aoddbeven = ab2 OR b2
aevenbodd = a2b OR a2
aevenbeven = a2b2 = (ab)2
Our assumptions hold and I believe this is isomorphic to Z/3 x Z/3. Let's check the mappings:
e --> (0,0)
a --> (1,0)
a2 --> (2,0)
b --> (0,1)
b2 --> (0,2)
ab --> (1,1)
(ab)2 --> (2,2)
ab2 --> (1,2)
a2b --> (2,1)
I think this should be enough to prove that these are the 2 groups of order 9. What do you guys think?
When checking if my assumptions hold true I should also check them with the a and b values flipped to check the ab = ba assumption, I won't write them out here but I know they hold, just assume I wrote them up there.
You already assumed ab=ba in deriving the group structure. There's not much use in 'checking' it now. As I said before, you can prove a group of order 9 is abelian before you start.
What is the significance of finding all groups of order 9, 10, and 11?
Finding all groups of a certain order allows for a better understanding of the structure and properties of those groups. It can also help in classifying and identifying different groups.
How many groups of order 9, 10, and 11 exist?
The number of groups of a certain order can vary, but for orders 9, 10, and 11, there are 5, 14, and 34 groups respectively.
What methods are used to find all groups of order 9, 10, and 11?
There are various methods used, such as the Lagrange's theorem, Sylow's theorems, and the use of group generators. These methods involve studying the elements and subgroups of a group to determine its structure.
Are there any patterns or similarities among the groups of order 9, 10, and 11?
Yes, there are some patterns and similarities among the groups of these orders. For example, all groups of order 9 are abelian, meaning that their elements commute with each other. Additionally, some groups of order 10 and 11 have similar structures.
What are the applications of finding all groups of order 9, 10, and 11?
The applications of this research include cryptography, chemistry, and physics. Group theory is used in these fields to understand the behavior and properties of molecules, crystals, and symmetries.
  • Linear and Abstract Algebra
