Solving a first-order nonlinear differential equation.
In summary, Latex was a bit grumpy, it should be okay now..Looks to me like an easily separable equation: get all "v"s on one side, all "t"s on the other and integrate.
swbluto
[Differential equation at the end; All the intermediary stuff is the problem behind it.]
I was curious about finding the velocity function for a free-falling object using solely Newton's equations. Using the force diagram, I've deduced that
m-mass
g-gravitational constant
f_net - net force
A - cross-sectional area
v - velocity
f_net = mg-1/4Av^2
ma = mg - (Av^2)/4
a=g-(Av^2)/4m
v'=g-(Av^2)/4m and g, A and m are constants. In this case, I simplified by assuming A=1, m=1 so the equation becomes the nonlinear first-order differential equation
v'=9.8-.25v^2. How do you... solve this kind of equation?
We might tidy up your problem as follows:
Set [tex]\epsilon^{2}=\frac{A}{4mg},w(t)=\epsilon{v}(t)[/tex]
Multiplying your diff.eq with [itex]\epsilon[/itex], we get:
[tex]\frac{dw}{dt}=\epsilon{g}(1-w^{2})[/tex]
Agreed so far?
Agreed so far?
Agreed so far?
Took quite some time to mentally process(This format is extremely unfamiliar) and sure. I'm not really sure where you go from here(My experience with differential equations is practically nothing, beyond several glimpses on wikipedia.) but I guess I can shoot off into several random directions and hope one hits the target.
Have you done separable diff. eqs yet?
So I see how this might solve a problem that I *think* I was having earlier.
So,
e-epsilon
dw/(1-w^2) = eg dt
Then the left side would be integrated in respect to initial and final "w", which then could be converted into v terms post-integration(or would be it better to do it pre-integration? I'm not immediately seeing how that would simplify things since the current form seems to be an immediately integrable form, I just need to look up the charts.), and the right side could be integrated in respect to initial and final t, and then velocity can be straightforwardly solved for algebraically? Is this a fruitful direction?
(Where do I learn how to use LaTeX(Wrong capitalization sequence? baha) on the forums, by the way?)
Ok. So I think I've found a definite way to solve it.
w = ev
dw = e dv
dw/(1-w^2) = e dv/(1-e^2v^2) (So pre-integration conversion seems to be better).
Looking at the table of integrals, it appears that the last form integrates to an inverse hyperbolic tangent which then the function v can be solved for.
Implicit differentiation about 3 years ago in Highschool is about the closest(That I know of). I didn't actually do "Calculus 2"(Differential equations included, looking at the book) but I did complete a system of differential equations sometime ago in a Calculus 3 test. But I think that was simply an initial value differential equations problem and did I struggle trying to complete it having only seen examples of it in Stewart's calculus book. But I solved it. :D
So,
e-epsilon
dw/(1-w^2) = eg dt
Quite right.
You should get, starting from rest:
[tex]w(t)=Tanh(egt)[/tex], where a positive velocity means a downwards velocity, due to the sign choice you made at the start.
Tanh is the hyperbolic tangent function.
Really?
So w(t) = tanh(egt)?
Then ev(t) = tanh(egt)
v(t) = tanh(egt)/e
When I tried solving it by pre-converting w in terms of v before integrating, I ended up
v(t) = tanh(e^2gt)/e. I'm thinking that I superfluously inserted an e somewhere, but I don't know where.
if
w = ev
then
dw/dt = e dv/dt (Right?)
dw = e dv(right? Imagine another "Right?" to each step hereafter.)
dw/(1-w^2) =
e dv/(1-e^2v^2)
...(integrating)...
= e tanh...
Hehe... nevermind... I forgot to multiply the e in front of the integral by the e in the denominator of the evaluated integral(Which cancels out all tanh^(-1)-external e's on the left side). So, yeah, pre-integration works as well as post-integration. Sweet.
Even cooler; The graph ACTUALLY looks realistic!
(I just realized another method to solve this problem could be done by using an energy approach. It seems like it wouldn't have to involve differential equations, either.)
Anyways, thanks! This has been extremely informative! So... with differential equations like this, just basically restate the equation so that one side could be completely expressed as products and the other side as the derivative and... divide and conquer.
(Perhaps there's a quicker more "standard" way, but this seems to get the job done.)
Note that 1/e is the "steady-state" velocity as time goes to infinity.
Also:
We ASSUMED that we let the object from rest, falling freely.
But, we may ask:
If we throw the stone upwards, how will that affect the motion?
In this case, BOTH gravity and air resistance work against the motion, we will get a (trigonometric) tangent relationship between velocity and time, rather than a hyperbolic one.
Try it out! (assume some initial velocity V>0)
All;
I have encountered a nonlinear first-order differential equation in my research. It appears rather simple yet I have been unable to solve it. Any clues/tips would be highly appreciated. First I state it in the original form:
y'[x] - 1/y[x] = - Exp[-1/x] / x^2
Next I state it written in the form of an Abel equation, obtained by setting q[x]=1/y[x]:
q'[x] + q[x]^3 = q[x]^2 * Exp[-1/x] / x^2
Thanks in advance for any thoughts!
Pete
1. What is a first-order nonlinear differential equation?
A first-order nonlinear differential equation is an equation that contains at least one variable and its derivative, and the derivative is raised to a power other than one. It cannot be written in the form of a straight line and its solution involves finding the relationship between the dependent and independent variables.
2. How do you solve a first-order nonlinear differential equation?
To solve a first-order nonlinear differential equation, you can use a variety of methods such as separation of variables, substitution, or integrating factors. These methods involve manipulating the equation to isolate the dependent and independent variables and then integrating both sides to find the general solution.
3. What are some applications of first-order nonlinear differential equations?
First-order nonlinear differential equations have many applications in various fields such as physics, engineering, and economics. They can be used to model population growth, chemical reactions, heat transfer, and many other real-world phenomena.
4. Can a first-order nonlinear differential equation have multiple solutions?
Yes, a first-order nonlinear differential equation can have multiple solutions. This is because the general solution of a nonlinear differential equation typically contains one or more arbitrary constants which can be assigned different values to obtain different solutions.
5. Are there any computer programs that can solve first-order nonlinear differential equations?
Yes, there are many computer programs and software packages available that can solve first-order nonlinear differential equations. Some popular examples include Mathematica, MATLAB, and Maple. These programs use numerical methods to approximate the solution of the given differential equation.
  • Differential Equations
