How does positive feedback works in opamp circuits?
In summary, positive feedback in opamp circuits can be used for oscillators and to add hysteresis to a comparator circuit. The key feature of an opamp is its high gain, which causes Vn = Vp in negative feedback scenarios. However, in positive feedback, the + input is locked at a certain voltage determined by the output and the resistor divider. For more information, you can refer to the MIT lecture on positive feedback in opamp circuits.
esmeco
144
I was wondering,how does positive feedback works in opamp circuits?Like is there any formula for calculating positive feedback?I know that with negative feedback we have Vp=Vn but I don't know how it works with positive feedback!Thanks for the reply!
The only times that I know of that you use positive feedback would be for oscillators and to add hysteresis to a comparator circuit. And with the oscillator, it's still feedback to the - terminal, but with a 180 degree phase shift.
Here is a good explanation of positive feedback for comparator hysteresis:
http://www.maxim-ic.com/appnotes.cfm/appnote_number/3616
As for your specific question, just remember that the key feature of the opamp is its high gain from input to output. For the situation of negative feedback, that forces Vn = Vp. But for positive feedback, it just locks the + input at some voltage, determined by which way the output pins, and what the resistor divider looks like from Vo back to the + input.
Go to http://ocw.mit.edu/OcwWeb/Electrical-Engineering-and-Computer-Science/6-002Circuits-and-ElectronicsFall2000/VideoLectures/index.htm"
and watch the postive feedback lecture.
1. How does positive feedback work in opamp circuits?
Positive feedback in opamp circuits occurs when the output signal is fed back to the input with an amplification factor greater than 1. This results in an increase in the input signal, which in turn increases the output signal. This cycle continues until the output reaches its maximum value, creating a stable state of oscillation.
2. What is the purpose of using positive feedback in opamp circuits?
Positive feedback is used in opamp circuits to create an amplifier with a larger gain than what is possible with negative feedback alone. It is also commonly used in oscillator circuits to generate a stable oscillating signal.
3. How does positive feedback affect the stability of opamp circuits?
Positive feedback can have a destabilizing effect on opamp circuits, as it can create a feedback loop that amplifies noise and causes the output to oscillate uncontrollably. In order to maintain stability, careful consideration must be given to the design and implementation of positive feedback in opamp circuits.
4. Can positive feedback be used in all opamp circuits?
No, positive feedback is not suitable for all opamp circuits. It is most commonly used in inverting amplifiers and oscillators, but not in non-inverting amplifiers or differential amplifiers. Additionally, positive feedback must be carefully designed and implemented to avoid stability issues.
5. How can positive feedback be used to improve the performance of opamp circuits?
Positive feedback can be used to improve the performance of opamp circuits by increasing the gain and bandwidth, reducing distortion, and increasing the speed of the circuit. However, it must be carefully designed and implemented to avoid stability issues and unwanted oscillations.
  • Electrical Engineering
