mohanrajs26
- 1
Can we built the small passenger car body using ANY WOOD which is STRONGER and CHEAPER?
If so, name the wood.
mohanrajs26 said:Can we built the small passenger car body using ANY WOOD which is STRONGER and CHEAPER?
brewnog said:Morgan have been doing a good job making sports cars using ash frames for one hundred years. They're still good by today's standards.
Mech_Engineer said:Let's be honest- the Morgan cars are bought for their styling, not because of their competitive performance or impressive Ash frame technology...
brewnog said:Nonsense, I've been successfully campaigning one this season and don't even like the look of the thing! Although if by "competitive" you mean "with other marques" then you may have a point. Still, faster round a track than lots of stuff made solely from 'modern' materials!
odmart01 said:realize that these cars won't absorb as much energy from collisions like a metal does. malleability of metals are critical for this.
Borek said:Lightning struck is so rare it can be safely ignored as a problem.
Mech_Engineer said:The OP's original question was if a "car's body frame" could be made out of a wood which is stronger and cheaper. In my opinion, the answer is still "no."
Wood is a lightweight and strong material, making it ideal for use in car body frames. It is also readily available and cost-effective compared to other materials, such as steel or aluminum. Additionally, wood has natural shock-absorbing properties, making it a safer option in the event of a collision.
While wood has many benefits, it also has some drawbacks when used in car body frames. Wood is susceptible to rot and decay when exposed to moisture, so it requires proper treatment and maintenance. It is also not as rigid as other materials, which can affect the overall stability and stiffness of the car.
Wood used in car body frames undergoes a process called "seasoning," which involves drying the wood to remove excess moisture and prevent decay. It is then treated with preservatives to protect against rot and insect damage. Some woods, such as ash or oak, are naturally more resistant to decay and may not require as much treatment.
While wood can be used for car body frames, it is not suitable for all types of cars. It is commonly used in vintage or classic cars, as well as in some modern sports cars, where weight and aesthetics are important factors. However, it is not commonly used in mass-produced vehicles due to the challenges of production and potential safety concerns.
Using wood for car body frames can have a positive impact on the environment. Wood is a renewable resource, meaning it can be replenished through sustainable forestry practices. It also has a lower carbon footprint compared to materials like steel or aluminum, which require more energy to produce. However, the transportation and processing of wood may still contribute to the overall environmental impact of car manufacturing.
