New Reply
Dipole interaction
Share Thread Thread Tools
Feb25-13, 01:02 PM   #1
Dipole interaction
1. The problem statement, all variables and given/known data
See attachment
2. Relevant equations
3. The attempt at a solution
Thus far I believe I am supposed to use calculate the interaction with kQq/Δr? I have tried summing over interactions so that 1/4∏ε*[(-Q)(-q)/(r-d/2+D/2) + (-Q)(q)/(r+d/2+D/2) + (Q)(-q)/(r-d/2-D/2) + (Q)(q)/(r+d/2-D/2)] , but this doesn't work, could someone point me in the right direction.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Feb25-13, 05:05 PM   #2
mfb
Mentor
With taylor series for those factors of 1/(r+d/2) and similar (and assuming d/2 << r), you should get the correct result.
Feb25-13, 06:23 PM   #3
Quote by mfb View Post
Ok, thanks, is kQq/Δr the correct expression for the interaction energy between 2 charges, and more importantly is that what i'm supposed to be using? Because if so I don't see how I get any 1/(r-d/2) terms, I just get stuff like 1/(r-d/2+D/2) unless I neglect the D/2 because r >> D?
Feb26-13, 07:10 AM   #4
mfb
Mentor
Dipole interaction
This is correct.
And right, you do not get "exactly" 1/(r+d/2), but you get similar expressions.
Feb26-13, 11:51 AM   #5
Ok thanks for the help, I can't seem to figure out what point i'm supposed to be taylor expanding about? For instance for the interaction between -Q and -q, 1/4∏ε*[(-Q)(-q)/(r-d/2+D/2)] take r = 1/(r-d/2+D/2) and that r >> D & d, d/2 vanish & D/2 vanish? Then I am just left with 1/r, bit confused, even if i try to expand that without making the approximation mentioned I still am not quite sure about what point I am expanding about.
Feb26-13, 12:32 PM   #6
mfb
Mentor
The difference between 1/r and your terms is the point of the expansion.
$$\frac{1}{r+x} = \frac{1}{r} \cdot \frac{1}{1+\frac{x}{r}} \approx \frac{1}{r} (1 \pm \dots)$$
Feb26-13, 12:55 PM   #7
Yeh I got that bit but I mean if f(x) = 1/r * 1/(1 + x/r) and this expands to 1/r [f(a) + f'(a)(x-a) . . .] what is "a" supposed to be?
Feb26-13, 01:04 PM   #8
mfb
Mentor
That is the point where you develop your taylor expansion. It depends on the definition of the f you choose, but I would expect 1 there.
Feb26-13, 01:38 PM   #9
Sorry I think I'm confused because I'm not entirely sure what the point is i'm developing the taylor expansion from, because if r = (r-d/2+D/2) that's over a length not a point :S? so kQq/(r-d/2+D/2) where i take f(x) = 1/r*(1/(1-x/r)) where x = d/2-D/2, still can't see what the point i'm expanding about is? Is it a=d/2 or a=D/2 or even a=r? so f(x) ≈ 1/r*[1/(1-a/r) + 1/r*(1/(1-a/r)2)*(x-a)] but so confused about the a :(.
Feb26-13, 02:46 PM   #10
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
You're expanding about x/r = 0. To be a bit more explicit, the function you're expanding is ##f(z) = \frac{1}{1-z}## about ##z=0## and then plugging in ##z=x/r##.
Feb26-13, 02:47 PM   #11
Quote by vela View Post
Yey, thanks very much to both of you for the help.
Feb26-13, 03:15 PM   #12
Actually I just tried that and my expansion ≈ 1/r + (d/2 + D/2)/r^2, then i tried for the remainder terms and the final result came to (2rQq - 2rQq)/r^2 = 0, i imagine my expansion came out wrong, is it wrong?
Feb26-13, 03:19 PM   #13
Recognitions:
Nope, that's fine. If you look at the result you're trying to arrive at, you should notice it has r3 on the bottom, so you want the 1/r and 1/r2 terms to cancel out.
Feb26-13, 03:22 PM   #14
Ok brilliant, thanks a bunch for the help, I'll take it from here just got to get the manipulation right :D.
New Reply
Thread Tools
Similar Threads for: Dipole interaction
Thread Forum Replies
Why is there no constant magnetic dipole-dipole interaction? Quantum Physics 4
Dipole-Induced Dipole Interaction Advanced Physics Homework 6
Dipole-dipole interaction Classical Physics 6
Nuclear magnetic resonance dipole dipole interaction Quantum Physics 0
Derivation of dipole-dipole interaction energy Advanced Physics Homework 2
