Help finding propeller thrust.
In summary, the conversation discusses the calculation of thrust for a propeller on a moving aircraft using various equations and theories. The equation for thrust is provided, but it is not very useful without knowing propeller characteristics and aircraft speed. Suggestions are given for finding a thrust calculator or using blade element theory to calculate thrust.
unethikal
Hello, I am working on a project regarding truss analysis on a plane and I need to find all the forces acting on the truss in order to produce static equilibrium (note that I have not yet taken fluid mechanics and I wanted a challenge).
From what I have found, propeller thrust is:
Thrust = Mass airflow X (slipstream velocity-aircraft velocity).
The aircraft is moving at a true airspeed of 120km/h. Do you guys have any idea how to calculate mass airflow and slipstream velocity with these variables? The propeller being used is this:
http://en.wikipedia.org/wiki/Bristol_Pegasus
Thank you.
The short answer is that thrust will be roughly equal to the aircrafts drag (some asumptions have to be made). Google the four forces of flight.
I don't think you can calculate thrust from the data you have. I suppose you could have a stab at calculating the thrust if you knew how much power was required to go at 120km/h and made some assumptions about prop efficiency.
PS You could look up data for the top speed of a Vickers Wellington powered by two of those engines. Knowing the power and that the prop might be say 80% efficient you could take a stab at the thrust needed to fly at that top speed.
That's similar to the equation for rocket thrust. The term "exit velocity" is used to describe the velocity of the affected air at the moment its pressure returns to ambient. Nasa article:
propeller_analysis.htm
This thrust equation isn't very useful, since it's essentially just two ways of expressing thrust after you've already calculated what the thrust is.
What you want is a "thrust calculator" that uses propeller characteristics (blade shape, blade size, number of blades), rpm, and aircraft speed. You can try a web search for thrust calculator, but most of these will be for "static" thrust, where the aircraft is not moving. You can also try searcing for "blade element theory", which will provide more mathematical based articles. Here is one web article that goes through the math, but I don't know if it will provide the answer you're looking for, or how accurate it is (not sure if it takes into account the induced flow effect on a prop with more than 2 blades):
prop1.htm
You may be able to find other and more useful articles.
1. What is propeller thrust and why is it important?
Propeller thrust is the force generated by a propeller that allows a vehicle, such as a boat or airplane, to move forward. It is important because it provides the necessary propulsion for the vehicle to move efficiently and effectively through air or water.
2. How is propeller thrust measured?
Propeller thrust is typically measured in pounds (lbs) or Newtons (N). It can be calculated by multiplying the propeller's torque by its rotational speed. Alternatively, it can be measured using a dynamometer or thrust stand.
3. What factors affect propeller thrust?
The main factors that affect propeller thrust include the size and shape of the propeller, the number and angle of the blades, the speed and direction of rotation, and the density of the surrounding fluid (air or water). Other factors such as altitude and temperature can also have an impact.
4. How can I increase propeller thrust?
There are a few ways to increase propeller thrust, including increasing the rotational speed, increasing the angle of attack of the blades, and increasing the number of blades. However, it is important to note that increasing thrust may also lead to increased drag, which can affect the overall performance of the vehicle.
5. How can I find the right propeller for my vehicle?
Finding the right propeller for your vehicle will depend on several factors, such as the type of vehicle, its weight and size, the intended use, and the engine specifications. It is best to consult with a propeller specialist or conduct thorough research to determine the most suitable propeller for your specific needs.
  • Aerospace Engineering
  • Mechanical Engineering
  • Other Physics Topics
