DavidLiew
- 16
How to prove that if A is upper triangular and B is the matrix that results when the ith row and jth column of A are deleted, then B is upper triangular if i<j.
An upper triangular matrix is a square matrix in which all the elements below the main diagonal (from top left to bottom right) are zeros. The elements on or above the main diagonal may be nonzero.
In this proof, A being upper triangular means that the elements below the main diagonal are all zeros. This allows us to use the property of upper triangular matrices, namely that multiplying two upper triangular matrices results in another upper triangular matrix.
It is important that B is a matrix because we are proving a property that involves matrix multiplication. Without B being a matrix, we cannot use the properties and rules of matrix multiplication to prove the statement.
Yes, for example, let A be the following 3x3 upper triangular matrix:
A = [2 1 0; 0 4 3; 0 0 5]
And let B be the following 3x3 matrix:
B = [1 2 3; 4 5 6; 7 8 9]
Then, AB is also an upper triangular matrix:
AB = [2 5 9; 16 20 24; 35 40 45]
Notice how all the elements below the main diagonal in AB are zeros, proving the property that if A is upper triangular and B is a matrix, then AB is also upper triangular.
This proof is relevant in many real-world applications, such as engineering, physics, and computer science. Upper triangular matrices are used to represent systems of linear equations, and the property being proved helps to simplify and solve these systems more efficiently. This proof also has applications in computer graphics and data analysis, where matrix operations are frequently used.
