| New Reply |
Sequence resulting from evenly dividing a line |
Share Thread |
| Feb14-13, 02:05 PM | #1 |
Hi, I'm new here and, as will become obvious from my question, neither a phycisist nor a mathematician. This is not a homework question, so I post it in this forum and hope that's okay. (I've aready asked on stack exchange but as far as I can see the answers given to me there were describing a different sequence.)
I need to find a non-recursive formula for determining the members of the sequence that starts as follows: [itex]a_1=0,\; a_2=\frac{1}{2},\; a_3=\frac{1}{4},\; a_4=\frac{3}{4},\; a_5=\frac{1}{8},\; a_6=\frac{3}{8},\; a_7=\frac{5}{8},\; a_8=\frac{7}{8},\; a_9=\frac{1}{16}, ...[/itex] Imagine a line that is subsequently divided into more fine-grained segments by dividing all of the previous segments, going from left to right. (For the record, it's in fact a programming problem. I need to split up a large chunk of memory into seperate areas on the basis of a given number of tasks, and this number may change dynamically at runtime.) I cannot even find a proper recursive definition. So far I've only come up with this: If [itex]n-1[/itex] is a power of two, then [itex]a_n=\frac{1}{2n-2}[/itex]. But I simply can't figure out how to get the values in-between like 3/4, 3/8, 5/8, 7/8, 3/16, ... and combine everything into one simple formula. It's driving me nuts. ![]() P.S.: In case this is really the wrong place to ask (it's not exactly about top-notch research in theoretical physics), I'd be happy for pointers to other places to ask these kind of questions. |
| Feb14-13, 02:23 PM | #2 |
I personally cannot understand your question. The sequence given makes no sense to me at all. An illustration of what you are actually trying to do on the line might help.
| Feb14-13, 04:06 PM | #3 |
Hello, 3ToedSloth,
you want a fraction a/p, with p=2^ceiling(ln(n) / ln(2)) and a=2n-p-1. (The "^" represents exponentiation here.) How to translate that into a computer program without precision problems is another story. If the calculation of ln(n) / ln(2) gives you 3.00001, for example, when 3 was the theoretical result, you don't want the ceiling function moving 3.00001 to 4. "p" (the denominator) is meant to represent the smallest power of 2 that is larger or equal to "n". Rather than using floating-point logarithms, in a computer language that can handle bitwise operations you will be better served by the following algorithm: * count how many right-shifts it takes to make "n" become 0; call that count "c". * shift the number 1 by c-1 positions to the left; call the result "p". * if p=n, then n was a power of 2 to begin with, and you want that value of "p". Otherwise, you want twice that value (left-shift "p" one more time). Here is a C++ example (port to your favorite flavor): given a value for "n", Code:
int c = 0;
for (int b = n; b > 0; b >>= 1)
c++;
int p = 1 << (c-1);
if (p != n)
p <<= 1;
int a = 2*n - p - 1;
cout << a << "/" << p << endl;
| Feb14-13, 04:22 PM | #4 |
I've drawn an image an hope that makes it clearer. Blue numbers are input, green numbers are output. It's looks like a binary search tree.
http://postimage.org/image/byt1pn8s7/ Edit: The last line got messed up a bit. The distances should always be the same, of course. |
| Feb14-13, 04:44 PM | #5 |
Python example, if C++ or bit manipulation are not your thing. (If Python isn't either, it is easier to read as pseudo-code.)
Code:
#!/usr/bin/python
class Fraction:
def __init__(self, n):
c = 0
b = n
while b > 0:
b /= 2
c += 1
c -= 1
p = 1
while c > 0:
p *= 2
c -= 1
if p != n:
p *= 2
self._p = p
self._a = 2*n - p - 1
def __str__(self):
return '{0}/{1}'.format(self._a, self._p)
for n in range(1, 18):
print n, Fraction(n)
| Feb14-13, 05:10 PM | #6 |
Or, lastly, hack around the eventual precision problems.
Code:
from math import *
for n in range(1,18):
p = int(pow(2, ceil(log(n)/log(2) - 0.001)) + 0.5)
a = 2*n - p - 1
print n, a, '/', p
| Feb15-13, 12:06 PM | #7 |
Thanks a lot, Dodo!
I'm still interested in the actual formula for the sequence, but your great code examples have solved my practical programming problem.
| New Reply |
| Tags |
| sequences and series |
Similar discussions for: Sequence resulting from evenly dividing a line
| Thread | Forum | Replies | ||
| 90% done with this "evenly dstrbtd chrg on infinite line" problem. PLEASE help 10% | Introductory Physics Homework | 10 | ||
| Determien the resulting function of the line with points (1,2) and (3,3) and.... | Precalculus Mathematics Homework | 5 | ||
| Next line in the sequence... | Linear & Abstract Algebra | 5 | ||
| When does natural become man made? What's the dividing line? | General Discussion | 18 | ||
| Field resulting from line charge | Introductory Physics Homework | 1 | ||
