New Reply
why does Earth have an axial tilt
Share Thread Thread Tools
Dec19-12, 06:15 AM   #18
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Quote by Jobrag View Post
And given that there are 360 degrees in a circle, the odds were 360:1 against the tilt rounding to zero.
Do all cultures divide a circle into 360 degrees?
Quote by Whovian View Post
And some mathematicians. The Radian, as it turns out, for some purposes, is a lot more convenient. For instance, the length of a circular arc is (the angle in radians)*(the radius of the arc), no constant needed. It's also nice for differentiating and integrating trigonometric functions.
I think the whole "360 degrees in a rotation, 60 seconds in a minute, 60 minutes in an hour" deal comes from the Babylonians' base 60 number system. And, actually, 60's a fairly beautiful number in Number Theory. (In calculus, the pretty one's e.)
Actually, the Babylonian base 60 number system comes from 360 degrees in a circle. 360 was the important part and 60 happens to work very well with 360.
There's 360 degrees in a circle - and how many days in a year? Each night, the stars shift approximately 1 degree (slightly less). 360 is pretty close to 365.25, but 365.25 would be a horrible number to build a numbering system around.
But, to answer the original question, only civilizations that came into contact with Babylon, or came into contact with someone who had come into contact with Babylon, use 360 degrees in a circle. That winds up being a pretty big percentage of civilization, but not everyone.
Dec19-12, 11:29 AM   #19
D H
Mentor
Quote by lpetrich View Post
Faster??? It would still orbit at very close to its original rate.
Faster.
A tiny little planetesimal will orbit at essentially a Keplerian rate. For an Earth-sized object, the velocity is 5 centimeters/second faster than that for a test particle. For a Jovian body, it's a difference of several meters per second.
This is admittedly a tiny effect. There is a much larger effect, though. The gas and dust in the protoplanetary disk orbits at less than a Keplerian rate. The density of that gas and dust decreases with increasing distance from the central plane and with increasing distance from the protostar. For stuff in the central plane, that density gradient makes for an outward pressure. This outward pressure counters the centripetal force of gravity, making the unincorporated gas and dust orbit a bit slower than Kepler's law would indicate.
Dec22-12, 07:40 AM   #20
Quote by D H View Post
Faster.
What about radiation pressure? A smaller object will have a higher surface area to mass ratio making radiation pressure more influential for smaller objects. How does this effect compare to the ones you mention?
Dec22-12, 10:36 AM   #21
D H
Mentor
Quote by mrspeedybob View Post
First I'll examine what radiation pressure does in our transparent and nearly empty solar system. The radial component of radiation pressure dominates over gravitation for very small particles, making the net radial force be outward. This causes these very small particles to be ejected from the system. Acceleration due to radiation pressure decreases as particle size increases. Beyond some critical size, the net radial component of acceleration will still be inward. If the only effect of radiation pressure was radial, all that this would mean is that smallish (but not too small) particles would orbit at less than a Keplerian velocity. There is, however, a tangential component to radiation pressure thanks to the finite speed of light. This is the Poynting-Robertson effect. This tangential component is directed against the motion of the orbiting particle, making small (but not too small) particles fall inward toward the Sun.
The protoplanetary disk changes things a bit, but the end result is still the same. The point at which a protostar begins emitting a significant amount of radiation spells the beginning of the end of the protoplanetary disk.
Dec24-12, 10:21 AM   #22
Quote by xzardaz View Post
//offtopic
To continue that:
Let the angle be λ and half* a circle be β (0≥λ≥β and β≠0)
The mesuring unit for λ and β must be the same - doesn't matter radian, degrees or other - see almost all used
If we chose some λ, the chance C that λ is some constant a (0≤a≤β) is 1/(all possible choices for λ)
If we assume that λ∈ℝ, then all possible choises for λ are ∞ (all the real numbers between 0 and β) ⇔ C=1/∞ ⇔ C→0 for any a for any β for any mesuring unit.
So for a=0° C→0. The same is for a=(the actual tilt of the Earth's axis).
* if you do a full rotation, there will be two points at wich the axis will lie on one line - just in opposite direction (so if the initial rotation is clockwise and we rotate the axis by half a circle the rotation will be counter clockwise). That's why β is half a circle.
Except that you forgot about the quantization of space in this "proof"...
New Reply
Thread Tools
Similar Threads for: why does Earth have an axial tilt
Thread Forum Replies
History of the Earth's Axial Tilt General Astronomy 2
History of the Earth's Axial Tilt Earth 1
Difference between axial tilt and inclination General Astronomy 7
Where does the sun rise, w/ axial tilt? General Physics 9
