Electric field of a uniformly polarized sphere
In summary, the conversation discusses finding the electric field of a uniformly polarized sphere using the formula V(\vec{r}) = \frac{1}{4 \pi\epsilon_{0}} \oint_{S} \frac{\sigma_{b}}{r} da' + \int_{V} \frac{\rho_{b}}{r} d\tau'. The solution involves using the surface charge density \sigma_{b} = P \cos\theta and the distance \tilde{r} = \sqrt{R^2 + r^2 - 2Rr\cos\theta} to calculate the potential, with integration limits for \theta from 0 to pi
stunner5000pt
1,461
Find the electric field of a uniformly polarized sphere of radius R
[tex] V(\vec{r}) = \frac{1}{4 \pi\epsilon_{0}} \oint_{S} \frac{\sigma_{b}}{r} da' + \int_{V} \frac{\rho_{b}}{r} d\tau'[/tex]
well obviously there is no volume charge density rho
but there is a surface charge density
[tex] \sigma_{b} = P \cos\theta [/tex]
now to calculate the potentail we got to use that above formula
Suppose r > R
then
[tex] V(\vec{r}) = \frac{1}{4 \pi\epsilon_{0}} \int \frac{P \cos\theta}{r} da' [/tex]
now the squigly r is found using the cosine law right...?
[tex] r = \sqrt{R^2 + r^2 - 2Rr\cos\theta} [/tex]
and
[tex] da' = R^2 \sin\theta d\theta d\phi [/tex]
is that right?
and the limits of integrate for the theta would be from 0 to pi
and for the phi is 0 to 2pi??
thanks for your help
(o by the way how do i put the squigly r??)
Squigly r ??
Did you mean [tex]\tilde{r}[/tex] ?
Your solution is basically correct, but you have abuse the usage of [tex]\theta[/tex]. Notice the [tex]\theta[/tex] in [tex] \tilde{r} = \sqrt{R^2 + r^2 - 2Rr\cos\theta} [/tex] is represecting the angle between r and R. It is not the same [tex]\theta[/tex] in the rest of your equations... you should not treat it like a variable and integrate over it...
chanvincent said:
Squigly r ??
sorry about the slopppy notation...
i shouldve put the primes
What is the electric field of a uniformly polarized sphere?
The electric field of a uniformly polarized sphere is the electric field that is generated by a charged sphere that has a uniform polarization in its material. It is a vector field that describes the force that a charged particle would experience at any given point in space around the sphere.
How is the electric field of a uniformly polarized sphere calculated?
The electric field of a uniformly polarized sphere can be calculated by using the formula: E = (1/4πε₀) * (3P·r - r³) / r⁵, where E is the electric field, ε₀ is the permittivity of free space, P is the polarization vector, and r is the distance from the center of the sphere.
What is the direction of the electric field of a uniformly polarized sphere?
The direction of the electric field of a uniformly polarized sphere depends on the direction of the polarization vector. If the polarization vector is pointing towards the center of the sphere, then the electric field will be directed towards the center. If the polarization vector is pointing away from the center, then the electric field will be directed away from the center.
How does the electric field of a uniformly polarized sphere change with distance?
The electric field of a uniformly polarized sphere follows an inverse square law, which means that as the distance from the center of the sphere increases, the strength of the electric field decreases. This relationship is described by the formula: E ∝ 1/r², where E is the electric field and r is the distance from the center of the sphere.
What is the significance of the electric field of a uniformly polarized sphere?
The electric field of a uniformly polarized sphere has various applications in physics and engineering. It is used to study the behavior of charged particles in electric fields, and it is also used in the design of electronic devices and materials with specific electrical properties. Understanding the electric field of a uniformly polarized sphere is crucial in many fields of study, including electromagnetism, materials science, and nanotechnology.
