Explaining Why Electrons Lose Energy While Orbiting Nuclear
  • Thread starter Morton
  • Tags
    Energy
In summary, the original planetary model of the electron orbiting the nuclear did not make any sense due to the electron losing its energy quickly and the atom collapsing. However, the Earth also loses energy while orbiting the sun, but at a very slow rate. This can be explained by the emission of radiation from accelerated charged particles and the transfer of energy through tidal forces. In quantum mechanics, orbitals do not involve movement, but rather stationary solutions that do not emit radiation. Superpositions of these states can result in radiation due to oscillating dipole expectations. Geodesics are curved paths that can be straight lines depending on the perspective and coordinate system. They are related to the concept of shortest path and are affected by factors such as gravity and
Morton
The original planetary model of the electron orbiting the nuclear did not make any sense because the electron would lose its energy so quickly and the atom would collapse within a tenth of a second. But I can not see an obvious reason why electron loses its energy while its orbiting the nulear.
And it seems that the Earth which is orbiting around the sun is losing its energy every second(a extremely small amount of energy though) as well. Can someone come up with an equation to explain this?:uhh:
Do you know that a charge particle under acceleration will emit radiation,this is not the case with things accelerating with no charge.In case,it is having centripetal acceleration.see here
http://en.wikipedia.org/wiki/Larmor_formula
There is a similar loss for planets. Accelerated mass emits gravitational waves. But the rate at which a planet loses energy this way is very, very low.
A larger contribution, for a planet, is due to tidal forces. Deformation of massive bodies due to tidal forces results in slightly uneven gravitational field, which gives rise to an interaction similar to viscosity. This is why Earth's rotation is transferred to the Moon, causing the Moon to drift away from Earth very, very slowly. Similarly, planets' rotation can be transferred to parent star, resulting in loss of energy.
Equivalently to the electron accelerating, you can view the classical orbit as an antenna, where the current due to the electron movement would radiate light.
In QM, orbitals are not movement, because they are stationary solutions, not evolving over time, so they don't radiate. More detailed: the wave's envelope does not spin around the nucleus, hence no radiation, but the phase does - which is possible because the amplitude is complex - and this permits a rotation momentum and a magnetic momentum for the orbitals P, D, F... that have no S symmetry.
If you add several stationary solutions (orbitals) you still get an acceptable amplitude for the electron but which isn't stationary. The envelope vibrates over time, at a frequency equal to the energy difference between the levels, and equal to the photon that is presently being absorbed or emitted.
Photon interaction supposes certain relations between the orbitals, especially the spin difference must match a photon, to make an "allowed" transition. This is equivalent to the electron vibration in the non-stationary amplitude producing an efficient field, essentially a dipolar field rather than non-polar (S to S orbital), quadripolar, or other forbidden transitions, which radiate inefficiently.
Perhaps, a more precise statement would be that electric dipole expectation for pure states is zero. Superpositions of states will have an oscillating dipole expectation, resulting in radiation.
Where did you get that?
I always found it peculiar thing to say there is some acceleration where the object is moving at uniform speed. From another point of view you could say it is moving in a straight line along curved geodesic. After all, acceleration is change in speed or change in direction, but if the speed does not change and if the distance between the objects does not change, then relatively speaking there is neither change of speed nor change of direction between the two.
Write down the x and y coordinates as x = r cos(ωt), y = r sin(ωt). What is d²x/dt² and d²y/dt²?
And geodesic is only curved if there is gravity involved. On the scale of an atom, all geodesics are straight lines.
I know, but that is relative to coordinate system, and if you look at the interaction from the point of either orbiting body or the body that is being orbited, then relatively speaking it is somewhat paradoxical to say there is a change in direction as the distance stays the same.
I though geodesics are just abstract mathematical concept and so that it's all just a matter of perspective and how you set up coordinate system.
No. Both of these are related to the metric. Geodesics are a generalization of the concept of shortest curve connecting two points. If distance between two points is given by d² = x² + y² + z², the shortest path is always a straight line. When you talk about gravity, you also want to consider time in all of this, which is why Geodesics are a bit more general, but the concept is the same.
So for example, let's say you consider object motion in polar coordinates r = R, θ = ωt. That does look likes "straight line" motion, because one coordinate doesn't change, and the other changes at uniform rate. But let's look at distance element. ds² = dr² + r²dθ². This is what tells you that things are going to be a little more complicated.
Specifically, when you have a metric that depends on coordinates, you can't just define a=dv/dt, because you are comparing velocity vectors at two different times at two different locations. This metric doesn't depend on time, so that's not a problem, but it does on location. So you have to take a covariant derivative which takes into account the different locations.
The derivation is not that complicated, but it's a bit messy because it involves Christoffel symbols. Once you account for the above metric, you can derive the expression for acceleration vector.
ar = dvr/dt - vθ²r
aθ = dvθ/dt + 2 vθvr/r
In our case, velocity vector is given by v=(0, ω). From the above, the acceleration vector is given by a=(-ω²R, 0). The acceleration is non-zero, and is, in fact, the correct centripetal acceleration. Note that in no part of this did I ever have to consider conversion to (x, y) coordinate system.
The moral is that while coordinate systems and velocities are all relative, the accelerations are absolute because we can define a metric. General relativity deals with this rather heavily, but as you can see above, you can use all of these concepts in classical mechanics and get the same results.
Interesting.
- "velocities are relative, accelerations are absolute..."
Do you have some link that talks specifically about absoluteness of acceleration?
I don't really know any good references. I think, pretty much any GR text will discuss it, but only as it relates to other things.
Basically, it comes down to the fact that you can measure acceleration directly. If you are in a completely closed room, you can still measure acceleration of that room using a mass and a spring. You can't tell acceleration from gravity, of course, but in GR, gravity is just a frame acceleration. It arises the same way centrifugal effect arises in the example above. The motion that causes it, however, is motion through time. So the math is more complex, but idea is exactly the same. You have something that looks like "straight line" in x, y, z, t, but because of the curvature of space-time, it's not, and you end up experiencing acceleration even if you stand still.
What's interesting is that the whole idea behind GR came from an attempt to treat accelerations as relative. Specifically, to adhere to Mach's Principle. That article might actually give you more insight into nature of acceleration, even though it talks specifically about it being relative.
Hope that doesn't leave you more confused.
Confused as before, but certainly more curious. Thanks for the info, I think I know now what to google for.
Geodesics are an abstract mathematical concept, but none of the rest follows from that. By design, geodesics do not depend on coordinate systems or perspective. A geodesic is a path which is locally straight at every point, regardless of what funky things the coordinate system may be doing.
So, in regular Euclidean geometry y=mx+b gives a straight line. You can express the same line in polar coordinates as r=b/(sin(θ)-m cos(θ)). The polar equation no longer looks like a straight line equation, but in both coordinate systems the path is a geodesic.
tris_d said:
Interesting.
There are definitely two acceleration,one is coordinate acceleration and other is proper acceleration.you should be able to distinguish between the two.it is proper acceleration which does not depend on coordinate system.
1. Why do electrons lose energy while orbiting the nucleus?
Electrons lose energy while orbiting the nucleus because they are constantly moving and interacting with the positively charged protons in the nucleus. This interaction causes the electrons to experience a force called electrostatic attraction, which pulls them towards the nucleus. As a result, the electrons lose energy as they move closer to the nucleus.
2. Can you explain the concept of energy levels in an atom?
Energy levels refer to the different energy states that electrons can occupy within an atom. The electrons closest to the nucleus have the lowest energy level, while those further away have higher energy levels. When an electron loses energy, it moves to a lower energy level. Similarly, when an electron gains energy, it moves to a higher energy level.
3. How is the energy of an electron related to its orbit around the nucleus?
The energy of an electron is directly related to its orbit around the nucleus. The closer an electron is to the nucleus, the lower its energy level and the less energy it has. As an electron moves further away from the nucleus, its energy level increases. This is because the electron has to overcome the electrostatic attraction force from the nucleus, which requires energy.
4. Why do electrons have a maximum energy level in an atom?
Electrons have a maximum energy level in an atom because of the laws of quantum mechanics. According to these laws, electrons can only occupy certain energy levels within an atom. These energy levels are known as orbitals and each orbital can only hold a specific number of electrons. Once all the orbitals are filled, the electrons have reached their maximum energy level in the atom.
5. How does the loss of energy by electrons affect an atom?
The loss of energy by electrons can have different effects on an atom. If an electron loses enough energy, it can be completely removed from the atom, resulting in an ion. This can affect the atom's chemical properties and reactivity. Additionally, the loss of energy by an electron can also cause it to move to a different energy level, which can result in the emission of light or heat energy, leading to phenomena like fluorescence or incandescence.
  • Classical Physics
  • Astronomy and Astrophysics
