On a point of logic in the Higgs vs strong force origin of mass
In summary, the conversation centered around the Higgs field and its role in giving mass to particles. The author of a Scientific American blog criticized Time Magazine for their science reporting, specifically their statement that without the Higgs, there would be no mass. The blog points out that most mass in the universe is actually due to the strong force, not the Higgs. However, the question remains whether the strong force could act on massless particles, and some argue that without the Higgs, there would be no particles for the strong force to act on. Additionally, the Higgs field is electrically neutral, which explains why it does not give mass to photons even though it breaks symmetry in the electroweak theory. The conversation also del
nomadreid
203
Recently, in the Scientific American blog
http://blogs.scientificamerican.com...with-errors/?WT_mc_id=SA_CAT_physics_20121130
the author criticizes Time Magazine for its science reporting, which of course is nothing new, but one of the criticisms is that Time's author wrote that without Higgs there wouldn't be any mass around (Sentence 1), and the blog counters by pointing out that most mass in the universe is due to the strong force, not Higgs. I am not sure that the blog's counter, although correct, actually destroys Time's contention, in that without Higgs, the elementary particles would not have mass, including the gluons and quarks upon which the strong force acts -- and therefore the question is whether the strong force could act on massless particles. If not, then there would be nothing around (without Higgs) for the strong force to act on, and hence nothing would have mass. (Whereupon Time's contention would be correct, even if it does give the wrong impression.)
I would be happy to be corrected on this; I would not want to be seen as a defender of Time magazine.
The Higgs is an essential part of nature, and so asking what nature would be like without it is a bit meaningless. However regarding the strong force, its action doesn't depend on quarks and gluons having mass. Gluons, in fact, ARE massless. And the two most common quarks, the up and down, nearly so.
just a question:why not photon interact with higgs field to get a mass?
In a single sentence, because the Higgs field is electrically neutral. :smile:
In more detail... electroweak theory has the symmetry group SU(2) x U(1) (Isospin T x Hypercharge Y) with four generators, and corresponding to each generator is a gauge boson (the W's, the Z and the photon).
The Higgs field breaks this symmetry by acquiring a vacuum expectation value. Each symmetry transformation that is broken results in a mass for the corresponding boson. But if the vacuum is still left invariant by some subgroup of gauge transformations, the gauge bosons associated with that subgroup will remain massless.
The generator corresponding to electric charge is Q = T3 + Y/2. So we make the simplest choice and assume the Higgs field to be an isospin doublet, T = 1/2, with hypercharge Y = 1, and assume that its vacuum expectation value φ0 = (0 v) has only a T3 = -1/2 component.
Then Qφ0 = (T3 + Y/2)φ0 = 0, the vacuum is invariant under electromagnetic gauge transformations ("electrically neutral"), and the photon remains massless!
Thanks very much, Bill K. That helped me understand these issues quite a lot.
(If you ever quit whatever profession you are in, you should go into popular science writing. Most explanations about Higgs etc. are either oversimplified or too technical, with nothing in between for those with a moderate physics background.)
with neutrino?
in a single sentence, because the Higgs field is electrically neutral.
what has this to do with mass?Even U(1) gauge symmetry is not broken,how can one conclude that photon is massless?
The gauge symmetry is a local symmetry, a position-dependent phase change, ψ → eiα(x)ψ, which we want to be a symmetry of the Lagrangian. But the Lagrangian contains derivative terms, so we must prevent derivatives of α(x) from appearing by using a modified derivative: Dμ = ∂μ - ieAμ where Aμ is the gauge field and transforms as Aμ → Aμ + (1/e)∂μα.
Then the gauge field must be massless because a mass term m2AμAμ would not be gauge invariant.
I already know it, defining covariant derivative gives the required form,also used in non abelian gauge theory.I just want to know why spontaneous symmetry braking does not give mass to photons.(or only something like goldstone bosons appear?)
In [itex]SU(2)_{L}\times U(1)_{Y}[/itex] theory, we have two coupling constants [itex]g_{L}[/itex] and [itex]g_{Y}[/itex], and four MASSLESS gauge fields: [itex]W_{\mu}^{a}, \ a = 1,2,3[/itex] and [itex]B_{\mu}[/itex]. We can redefine these fields by introducing two electrically charged fields
[tex]W^{\pm}_{\mu} = \frac{1}{\sqrt{2}}( W^{1}_{\mu} \mp i W^{2}_{\mu}),[/tex]
and two neutral fields
[tex]Z_{\mu} = W^{3}_{\mu}\cos \theta - B_{\mu} \sin \theta[/tex]
[tex]A_{\mu} = W^{3}_{\mu} \sin \theta + B_{\mu} \cos \theta[/tex]
We still have no photon in here, because the gauge group is not [itex]U(1)_{em}[/itex], all fields are still massless and (more important) the two couplings [itex]g_{L}[/itex] and [itex]g_{Y}[/itex] are unrelated.
To break [itex]SU(2)_{L}\times U(1)_{Y}[/itex] down to [itex]U(1)_{em}[/itex], we need to introduce a set of scalar fields [itex]\Phi[/itex] which has [itex]U(1)_{em}[/itex] invariant non-zero vacuum expectation value [itex]< \Phi > = v[/itex], i.e. it vanishes under the action of the [itex]U(1)_{em}[/itex] generator (the electric charge)
[tex]Q_{em}< \Phi > = 0. \ \ \ \ (1)[/tex]
Next, we introduce a small perturbation [itex]H(x)/ \sqrt{2}[/itex] around the VEV of the scalar field [itex]< \Phi >[/itex]. This will provides masses to ALL four gauge fields [itex]W^{\pm}_{\mu}, Z_{\mu}[/itex] and [itex]A_{\mu}[/itex]. So, in order to satisfy eq(1) one of the neutral fields must remain massless, so that it can be identified with the gauge field of the (unbroken) [itex]U(1)_{em}[/itex] group, i.e. the photon. This happens for [itex]A_{\mu}[/itex] provided that we CHOOSE the couplings such that
[tex]g_{Y} = g_{L} \sin \theta[/tex]
Sam
oh nice way,can I get some reference for it.thank you, sam.
samalkhaiat said:
...This happens for [itex]A_{\mu}[/itex] provided that we CHOOSE the couplings such that
Surely the couplings have already already determined by nature/more fundamental physics we haven't yet discovered. Isn't the real point that, for the field configuration of the GWS theory, there exists a θ for which the Aμ remains massless?
We measure its value experimentally.
Yes, that is true. In a self-consistence theory, that does not change the fact that the photon was introduced by that particular choice of the [itex]SO(2)[/itex] parameter.
Sam
All textbooks on Weinberg-Salam theory go through the details. After introducing the perturbation [itex]H(x)/ \sqrt{2}[/itex] and performing local gauge transformation on all the fields in the theory, the rest is just an algebra. The vector mesons masses are contained in the [itex]|D_{\mu}\Phi |^{2}[/itex] part of the Lagrangian:
[tex]
D_{\mu}\Phi = \left( \partial_{\mu} + i \frac{g_{L}}{2}\tau_{a} W^{a}_{\mu} - i \frac{g_{Y}}{2}B_{\mu} \right) \left( \begin{array}{c} 0 \\ (v + H/ \sqrt{2}) \end{array} \right)
[/tex]
[tex]
V( \Phi ) = - \mu^{2} H^{2}(x) + \mathcal{O}^{3}(H) + \mathcal{O}^{4}(H) + \mbox{const.} \ \ \ (1)
[/tex]
So,
[tex]
( D_{\mu}\Phi )^{\dagger}( D^{\mu} \Phi ) = \frac{1}{2} ( \partial_{\mu}H )^{2} + \frac{g_{L}^{2}v^{2}}{4} \left[ ( W_{\mu}^{1})^{2} + (W_{\mu}^{2})^{2} + ( W_{\mu}^{3} - \frac{g_{Y}}{g_{L}} B_{\mu})^{2}\right] + \mbox{interaction terms} \ (2)
[/tex]
From (1) and (2) we read off the mass of the Higgs field: [itex]M_{H}= \sqrt{2 \mu^{2}}[/itex].
Now, we write eq(2) in terms of the fields [itex]W^{\pm}_{\mu}, Z_{\mu}[/itex] and [itex]A_{\mu}[/itex] given in my previous post. The relevant terms become (I):
[tex]
\frac{g_{L}^{2}v^{2}}{4}[ ( W_{\mu}^{1})^{2} + ( W_{\mu}^{2})^{2}] = \frac{g_{L}^{2}v^{2}}{2} W_{\mu}^{+} W^{\mu -}
[/tex]
This gives the mass term for the [itex]W^{\pm}[/itex] bosons: [itex]M_{W}= \frac{g_{L}v}{\sqrt{2}}[/itex]
And (II):
[tex]
\frac{g_{L}^{2}v^{2}}{4}( W_{\mu}^{3} - \frac{g_{Y}}{g_{L}}B_{\mu} )^{2} = \frac{g_{L}^{2}v^{2}}{4}[( \sin \theta - \frac{g_{Y}}{g_{L}}\cos \theta ) A_{\mu} + ( \cos \theta + \frac{g_{Y}}{g_{L}} \sin \theta ) Z_{\mu}]^{2}
[/tex]
Now, if we make the choice
[tex]g_{Y} = g_{L} \tan \theta ,[/tex]
the above reduces to
[tex]
(0) A_{\mu}^{2} + (0) A_{\mu}Z^{\mu} + \frac{g_{L}^{2}v^{2}}{2 \cos^{2}\theta}Z_{\mu}^{2}.
[/tex]
This means that the [itex]A_{\mu}[/itex] is massless; there is no e-m interaction between the A and the Z fields and the mass of the neutral boson Z is given by [tex]M_{Z}= \frac{vg_{L}}{\sqrt{2}\cos \theta} = \frac{M_{W}}{\cos \theta}.[/tex]
Sam
CORRECTION: The correct form is
[tex]g_{Y} = g_{L} \tan \theta .[/tex]
Until this point θ is arbitrary, is it not? So is it fair to say that we choose θ in our definition of the A field to satisfy this relation and give us massless photon? Or am I missing something more fundamental here?
No, you are not missing anything. This is what I said in post #13. The point is this: in the unbroken [itex]SU(2)_{L}\times U(1)_{Y}[/itex] that choice of [itex]\theta[/itex] does not give you photon. Only when [itex]<\Phi >:SU(2)_{L}\times U(1)_{Y}\rightarrow U(1)_{em}[/itex], we identify the A-field with the massless photon.
Sam
so it seems that coupling constants are chosen in a way so as not to give photon a mass.zero mass of photon must be confirmed by some other ways like receiving how much valid is inverse square law,or directly giving a limit based on some approach as used by schrodinger etc.right?
The coupling constants are parameters of the theory. Whatever their values, there will exist a value of θ that yields a massless photon.
They are also related to the electromagnetic coupling constant [itex]e[/itex] by the relation
[itex]e = g_L\ sin (\theta) = g_Y\ cos (\theta)[/itex]
So by measuing [itex]e[/itex] and [itex]\theta[/itex] we can immediately determine their values.
this reminds me a previous thread where I defended the idea that the electric charge (as g and g') was defined before symbreaking. (and that theta value was given before it)
But surely the thing that isn't defined until symmetric breaking is the "direction" within the SU(2) "space" along which it breaks. Isn't this analogous to the difference between empty space where there is no magnetic field, when there is no preferred direction, and when a magnetic field is present in which case it introduces a "preferred" direction namely that of the field?
In choosing three basis generators T1/T2/T3 for an SU(2) space, we are implicitly defining a set of arbirary "axes" within it. Without symmetry breaking, we could if we wanted then rotate those into a different set, say T'1/T'2/T'3, with no change to the resulting physics. When the symmetry breaks we find there is a "direction" within the SU(2) space in which the weak isospin assignments of particles - which ab initio is an orientation defined by a pair of complex numbers, cf electron spin - now contributes to something we observe as the particles' electric charges.
1. How do the Higgs and strong force theories explain the origin of mass?
The Higgs theory proposes that mass arises from the interaction between particles and the Higgs field, while the strong force theory suggests that mass is generated through the binding energy of quarks within protons and neutrons.
2. Which theory is currently accepted by the scientific community?
Currently, the Higgs theory is the most widely accepted explanation for the origin of mass. This is based on evidence from experiments at the Large Hadron Collider, which have detected the Higgs boson particle.
3. Can both theories coexist and complement each other?
Yes, it is possible for both the Higgs and strong force theories to coexist and complement each other. While the Higgs theory explains the mass of fundamental particles, the strong force theory plays a crucial role in the formation of atoms and the binding of protons and neutrons within the atomic nucleus.
4. What is the significance of determining the origin of mass?
Understanding the origin of mass is important for our understanding of the fundamental laws of physics and the structure of the universe. It also has practical applications in fields such as particle physics and cosmology.
5. Are there any ongoing research or experiments related to this topic?
Yes, there is ongoing research and experimentation to further study and validate the Higgs and strong force theories. This includes studying the properties of the Higgs boson and its interactions with other particles, as well as exploring the strong force at high energies using particle accelerators.
  • Beyond the Standard Models
