(CHEM) Which of the following compounds can exist as cis and trans isomers ?
In summary: Your Name]In summary, using average bond enthalpy values, we can estimate ΔH for the gas phase reaction between CH2=CH2 and Br2 to produce CH2BrCH2Br. After identifying the bonds broken and formed, we calculate the total bond enthalpy for each and then find the difference to get ΔH. The estimated value for ΔH is 1422 kJ/mol.
miss.strw
Using average bond enthalpy values estimate ΔH (kJ/mol) for the following gas phase r
Using average bond enthalpy values estimate ΔH (kJ/mol) for the following gas phase reaction.
CH2=CH2 + Br2 --> CH2BrCH2Br
I followed this topic: http://answers.yahoo.com/question/index?qid=20080306194402AAtIc63
and I got the wrong answer.
I came up with 129 which is wrong.
Here is my work :
C-H = 4x416 = 1664
C=C = 1x598 = 598
Br-Br = 2x193 = 386
1664+598+386 = 2648
C-H = 4x416 = 1664
c-Br = 3x285 = 855
1664+2519 = 2519
2648-2519 = 129 (which is wrong.) Please Help Me! Thank you!
Thank you for your question. Your approach to using average bond enthalpy values to estimate ΔH for this reaction is correct, but there are a few errors in your calculations. Let's go through the steps together to ensure we get the correct answer.
Step 1: Write out the balanced chemical equation for the reaction:
Step 2: Identify the bonds broken and formed in the reaction. In this case, we have 4 C-H bonds and 1 C=C bond broken, and 2 C-Br bonds formed.
Step 3: Look up the average bond enthalpy values for each bond. These can be found in a table, such as the one in the link you provided.
C-H = 416 kJ/mol
C=C = 598 kJ/mol
C-Br = 285 kJ/mol
Step 4: Calculate the total bond enthalpy for the bonds broken and formed.
Bonds broken: 4(416 kJ/mol) + 1(598 kJ/mol) = 1992 kJ/mol
Bonds formed: 2(285 kJ/mol) = 570 kJ/mol
Step 5: Calculate ΔH for the reaction by subtracting the total bond enthalpy of the bonds formed from the total bond enthalpy of the bonds broken.
ΔH = 1992 kJ/mol - 570 kJ/mol = 1422 kJ/mol
Therefore, the estimated ΔH for this gas phase reaction is 1422 kJ/mol. I hope this helps and clarifies any confusion. Keep up the good work in your studies!
I would first like to clarify that the question is asking for the enthalpy change for the reaction, not the isomers of a compound. The two isomers mentioned in the question, cis and trans isomers, are different arrangements of the same compound (CH2BrCH2Br) and do not affect the enthalpy change of the reaction.
To calculate the enthalpy change of the reaction, we need to use the bond enthalpy values for each bond broken and formed in the reaction. The bond enthalpy values that you have used for C-H and C=C bonds are correct, but the value for the Br-Br bond is incorrect. The correct value for Br-Br bond enthalpy is 193 kJ/mol, not 285 kJ/mol.
Using the correct values, the calculation would be as follows:
Bond enthalpies for bonds broken:
2 C-H bonds = 2 x 416 kJ/mol = 832 kJ/mol
1 C=C bond = 1 x 598 kJ/mol = 598 kJ/mol
1 Br-Br bond = 1 x 193 kJ/mol = 193 kJ/mol
Bond enthalpies for bonds formed:
2 C-Br bonds = 2 x 285 kJ/mol = 570 kJ/mol
ΔH = (832 + 598 + 193) - (570) = 1053 kJ/mol
Therefore, the enthalpy change for the reaction is 1053 kJ/mol. I hope this helps clarify your confusion. Remember to always double check your values and units to ensure accurate calculations.
1. What are cis and trans isomers?
Cis and trans isomers are two types of stereoisomers, which are compounds that have the same chemical formula but differ in the spatial arrangement of their atoms. Cis isomers have similar groups on the same side of the molecule, while trans isomers have similar groups on opposite sides of the molecule.
2. How do cis and trans isomers differ in their physical properties?
Cis and trans isomers have different physical properties due to their different spatial arrangements. For example, cis isomers tend to have lower melting and boiling points, and higher polarity compared to trans isomers.
3. Can all compounds exist as cis and trans isomers?
No, not all compounds can exist as cis and trans isomers. Compounds that have restricted rotation around a double bond or a ring structure are more likely to exhibit cis and trans isomerism.
4. What is the significance of cis and trans isomers in biological systems?
In biological systems, cis and trans isomers can have different effects on biological processes. For example, trans fats are known to have negative effects on health, while cis isomers of certain compounds may have beneficial effects.
5. How can you determine if a compound exists as cis or trans isomers?
The spatial arrangement of atoms in a compound can be determined using techniques such as X-ray crystallography, NMR spectroscopy, or computational methods. By analyzing the structural data, it is possible to determine if a compound exists as cis or trans isomers.
9K
