Register to reply
Addition of sine waves
by Maths dunce
Tags: addition, sine, waves
Share this thread:
Maths dunce
#19
Mar11-14, 03:54 PM
P: 11
I have seen this identity and if I insert my figures it does confirm that my addition of the points is correct. It is the simplifying / putting it back into the original form that I cannot understand. I will look into this further and get back to you.
Thank you for your patience.
arildno
#20
Mar11-14, 05:35 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Can you please post what you have done further?
Honestly, I do not see what problems you have reached into, and I am actually inclined to believe you have misunderstood the right answer as somehow not being what you were asked for.
ehild
#21
Mar12-14, 01:55 AM
HW Helper
Thanks
P: 10,660
Quote Quote by DrewD View Post
So as it stands, your problem is finding how to rewrite
##2\sin(314.5t)+2\sin(314.5t-120)##
as a single term? If that is the case, there is an identity that allows you to combine such terms. It is near the bottom of the page http://="http://www.sosmath.com/trig...ig5.html"]here. If that is not what you are looking for, or you are still struggling to find the identity on that page, mention it.
PS this should probably be in "homework help"
You have to write the sum of two sine (cosine) functions of form Va(t)=Asin(wt) and Vb(t)=Bsin(wt+β) as Vc(t)=C sin(wt+γ). For that, expand both Vb and Vc, using the identity
sin(a+b)=sin(a) cos(b) + cos(a) sin(b)
(or cos(a+b)=cos(a)cos(b)-sin(a)sin(b))
You get :
Vb= B [sin(wt)cos(β)+cos(wt)sin(β)] and Vc=C sin(wt+γ)=C[sin(wt)cos(γ)+cos(wt)sin(γ)].
With those, the equation Va+Vb = Vc becomes
Asin(wt)+B sin(wt)cos(β)+Bcos(wt)sin(β)=Csin(wt)cos(γ)+Ccos(wt)sin(γ).
Collect all the sin(wt) terms and also the cos(wt) terms:
sin(wt)[A+Bcos(β)-Ccos(γ)] + cos(wt)[Bsin(β)-Csin(γ)]= 0
You have to find the unknown C and γ so that the equation holds at any time t.
For t=0, sin(wt)=0 cos(wt)=1, so Bsin(β)-Csin(γ)=0.
If wt=pi/2 radian (t=pi/(2w) cos(wt)=0 and sin(wt)=1, so A+Bcos(β)-Ccos(γ)=0.
You have to solve the system of equation in bold.
Bsin(β)=Csin(γ)
A+Bcos(β)=Ccos(γ)
Square both equations and add them together.
(Bsin(β))2+(A+Bcos(β))2=C2(sin2(γ)+C2cos2(γ)=C2
You can expand and simplify the left hand side:
A2+B2+2AB cos(β)=C2.
Knowing C, sin(γ)=B/C and cos(γ)=(A+Bcos(β))/C.
Apply to your problem: A=B=2, β=-120 degrees. (:Edited)
ehild
Maths dunce
#22
Mar12-14, 04:15 AM
P: 11
OK think I have finally understood. The answer I have come up with is:
Vc = 2.0007sin(314.2t-59.99)
Thank you all for your help and if someone would confirm my answer for my peace of mind that would be great.
ehild
#23
Mar12-14, 06:38 AM
HW Helper
Thanks
P: 10,660
It is correct but the rounding errors. Vc=2.000 sin(314.2t - 60.00)
(I had an error in my previous post, beta was -120 instead of 120.)
ehild
Maths dunce
#24
Mar12-14, 08:58 AM
P: 11
Thank you ehild
arildno
#25
Mar12-14, 01:51 PM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Going the path along with the half angle product formula would have given you precisely the same expression.
Maths dunce
#26
Mar12-14, 02:05 PM
P: 11
Thank you arildno I understand that now. It took a while but I got there in the end.
DrewD
#27
Mar12-14, 06:17 PM
P: 446
Quote Quote by arildno View Post
With a lot less work!
ehild
#28
Mar13-14, 01:36 AM
HW Helper
Thanks
P: 10,660
Yes, it is a lot less work if you remember that such formula exists.
The other method uses the basic addition laws of Trigonometry, taught and explained in detail in highschools.
You can also find the "ready" formulae for addition of two sinusoidal function of time, and it is also taught, why not use those? http://www.google.com/url?sa=t&rct=j...62922401,d.bGQ
ehild
arildno
#29
Mar13-14, 09:45 AM
Sci Advisor
HW Helper
PF Gold
P: 12,016
Quote Quote by Maths dunce View Post
However, I would like to say that ehild's scheme, although apparently clunky, is a VERY important technique in many other fields as well, i.e, understanding and using the concept of linearly independent functions in order to solve particular problems.
It is, in a manner of speaking, a generally more powerful tool than trig identity tables that you'll gradually learn to appreciate.
Register to reply
Related Discussions
Use LabView to simulate 2 Sine Waves and then Filter Waves above 50Hz Engineering, Comp Sci, & Technology Homework 0
Addition of Sine & Cosine Precalculus Mathematics Homework 4
Rules governing the creation of complex waveforms through addition of sine waves General Math 2
Sine Wave Addition General Physics 6
Square waves sine waves etc(signal propagation) Electrical Engineering 9
