Force of impact on a human body falling into water
In summary, the conversation discusses the case of a 50kg man jumping off an 80m high bridge into choppy salt water and the goal is to determine the force sustained by the body upon impact and the depth of penetration. The known figures and equations are provided, but the calculation of velocity and force is not conclusive. The conversation also mentions the potential survival of such a fall and the suggestion to look for accounts of similar cases for a better understanding.
aleiss
A 50lg man jumps off a bridge 80m high. He lands in choppy salt water feet first. Each foot has an area of 75cm^2. The goal is to find out
a) What is the force sustained by the human body while hitting then decelerating in the water.
b) depth of penitration
Because this is to check the safety of the jump, ie safe, harmful, or deadly, we can simplify it by ignoring the temperature of the water and air.
known figures.
Salt water = 1.027 g/cm^3
bridge = 80m
total penetration area = 150cm^2
weight of man = 50kg
from the bridge to the water in time
9.8m*s^2 = h
force in a fluid
f= 1/2p*v^2*c*a
because I did not know what the drag coefficient of a human is (a flailing human) I ignored it, and it is unitless.
I did not know how to calculate the velocity so I calculated the speed
9.8m*s^2=h
9.8m*s^2=80m
s^2=8.15
s=2.85
I read that at 3 seconds an object has 29.2m/s so I guessed (not very scientific I know) and said 2.85 would be 28m/s
f= 1/2p*v^2*c*a
we nix the c
f=1/2*1.027g/cm^3*2800cm/s^2*150cm^2
f=6*10^8 g*cm^4*s^2/cm^3
f=6*10^8g*cm*s^2
thats ergs right?
Anyway, this is a rough figure but ok for my purposes. I do not know what do to with this figure not though as I want to calculate the amount of force sustained on the body when it hits and as it decelerates as well as how far down it can go.
I have this other equation
Vf^2 = Vo^2 + 2*a*y
but I do not really know what to do with it.
this is not for any scholastic or commercial project (I am a high school drop-out). Rather there is a bridge near me (the sunshine skyway) which is famous for people jumping off it to commit suicide. I am arguing that they survive the fall and then drown.
Thanks for any help given.
The potential suicide will land at velocity of about 40m/s, ignoring air friction. That's about 90mi/hr. Air friction will reduce that somewhat, but you are probably in the right ballpark for velocity. Beyond that the question gets much harder. Force isn't measured in ergs. That's energy. What will kill you is the acceleration. How long does it take the water to brake you to a halt and what does that translate into g's of acceleration, and for how long is that applied. That's fluid dynamics. And then you have to figure out the mortality rate given those parameters. I don't know how to do either. I would guess a belly flop would do serious damage. Entering feet first would probably be survivable. But that's a guess. I think your best bet is to look for accounts of falls from such a distance and what was the outcome. Physical calculation may not be the best way of answering this. But kudos to you for trying.
1. How does the height of the fall affect the force of impact on a human body falling into water?
The higher the fall, the greater the force of impact on the human body. This is because the body has more time to accelerate due to the pull of gravity.
2. Does the surface area of the body affect the force of impact on a human body falling into water?
Yes, the surface area of the body does have an impact on the force experienced upon hitting the water. A larger surface area will create more drag, which can help slow down the body's acceleration and lessen the force of impact.
3. Is the force of impact different for different body positions while falling into water?
Yes, the force of impact can vary depending on the position of the body. A vertical or pencil position will experience a greater force of impact compared to a horizontal or spread-out position.
4. Does the speed of the body upon hitting the water affect the force of impact?
Yes, the speed of the body at impact has a direct impact on the force experienced. The faster the body is moving, the greater the force of impact will be.
5. What factors can lessen the force of impact on a human body falling into water?
The force of impact can be lessened by factors such as reducing the height of the fall, changing the body position to increase drag, and entering the water at an angle rather than straight down. Wearing protective gear such as a life jacket can also help lessen the force of impact.
  • Classical Physics
  • Mechanics
  • Biology and Medical
