Wireless power (using resonance induction a.k.a. evanescent waves coupling)
In summary, the use of resonance induction in energy transfer applications allows for the distance between primary and secondary coils to be increased by utilizing the evanescent wave coupling phenomenon. This is supported by the theoretical basis of an electromagnetic field in the near field region of a resonator being a combination of propagating and evanescent waves. The coupling of the evanescent wave allows for a larger air gap distance to be achieved.
mukrajat
Hello,
I have read a lot of literature in this area and am really confused. I need help.
There is a drive today towards increasing the distance over which energy transfer is feasible.
Currently, mutual induction is used commercially for a whole bunch of applications, but each of them requires that the air gap between the primary and secondary coils be small.
Enter resonance induction: a special kind of induction that uses resonance; I have read that this phenomenon allows for the distance to be increased to a few times the size of the coils. The phenomenon that facilitates the transfer of energy is highly theoretical - "evanescent wave coupling." Literature compares this physics to http://en.wikipedia.org/wiki/Total_internal_reflection#Frustrated_total_internal_reflection" that occurs in wave-media interactions.
In energy transfer applications, this evanescent field is seen in the "near field" region of a resonator (e.g., LC coil)
My question is: what is the theoretical basis that supports the existence of such a wave in the vicinity of a resonator? and why does coupling of the evanescent wave allow for the air gap distance to be increased?
Thank you for your help. The theoretical basis for the existence of an evanescent wave in the vicinity of a resonator is based on the fact that an electromagnetic field in the near field region of a resonator can be expressed as a combination of propagating and evanescent waves. The evanescent wave is a result of the wave being partially reflected at the boundaries of the resonator, causing its amplitude to decay exponentially with distance. The coupling of the evanescent wave allows for the air gap distance to be increased because the wave is able to travel further without decaying significantly, allowing it to reach the secondary coil even over a large distance.
Hello,
Thank you for your question. I can understand your confusion about wireless power and resonance induction. Let me try to provide some clarification and address your questions.
Firstly, the theoretical basis for the existence of evanescent waves in the vicinity of a resonator lies in the principles of electromagnetism. When an alternating current is applied to a resonator (e.g. an LC coil), it produces an oscillating magnetic field around it. This magnetic field has a specific frequency, which is determined by the resonance frequency of the resonator. When this frequency matches the natural frequency of the resonator, it produces a strong electric field in the vicinity of the resonator. This electric field is known as the evanescent wave.
Now, why does coupling of the evanescent wave allow for the air gap distance to be increased? This is because evanescent waves are highly localized and decay rapidly as you move away from the resonator. However, when two resonators are placed close to each other, their evanescent waves can interact and transfer energy between them. This allows for the distance between the two resonators to be increased without significant loss of energy.
In summary, the theoretical basis for resonance induction and evanescent wave coupling lies in the principles of electromagnetism. By utilizing these principles, we can increase the distance over which energy transfer is feasible. I hope this helps to clarify the concept for you. Let me know if you have any further questions.
What is wireless power and how does it work?
Wireless power refers to the transmission of electrical energy from a power source to an electronic device without the use of physical wires. Resonance induction, also known as evanescent waves coupling, is a method of wireless power transfer that uses magnetic fields to transfer energy between two objects. This process involves creating a resonance between two objects, allowing energy to be transferred between them without the need for direct contact.
What are the advantages of using wireless power?
One of the main advantages of wireless power is convenience. With wireless power, there is no need for cords or cables, making it easier to charge electronic devices. It also eliminates the risk of damage to cords or ports. Additionally, wireless power allows for more flexibility in device placement, as there is no need to be in close proximity to a power source.
What are the limitations of wireless power?
One limitation of wireless power is the distance over which energy can be transmitted. While resonance induction can allow for power transfer over short distances, it is not yet capable of long-range power transmission. Another limitation is the efficiency of energy transfer, as some energy may be lost during the process.
Is wireless power safe?
There is ongoing research and debate about the safety of wireless power. While the magnetic fields used in resonance induction are generally considered safe for human exposure, there are concerns about potential health risks with prolonged exposure to high-frequency magnetic fields. More studies are needed to fully understand the potential health effects of wireless power.
What are the potential applications of wireless power?
Wireless power has the potential to revolutionize the way we charge electronic devices, making it more convenient and efficient. It can also be used in industries such as automotive, healthcare, and manufacturing, where the ability to transfer power without physical contact can be beneficial. Additionally, wireless power can be used to power remote or hard-to-reach devices, making it useful in a variety of settings.
  • Electrical Engineering
12K
  • Quantum Physics
