Tangential Velocity Homework: Attractive Energy & Force Calc.
In summary, we can calculate the attractive energy per molecule of water to be 6.03*10^-24 kJ/molecule, and the attractive force between one molecule of water and one gel molecule to be 1.51*10^-14 N/molecule of gel. To find the minimum tangential velocity needed for separation, we can use the formula for centripetal force and assume a mass of one water molecule. This gives us a minimum tangential velocity of 0.0036 m/s.
Priscilla
31
A carbohydrate gel is being centrifuged to remove excess physisorbed water. Assume that the magnitude of the attractive energy between the water molecules and the gel is given by 3.63 kJ/mol of molecules of water, with the water molecules being separated from the surface of the gel molecules by 0.4 nm.
a)Calculate the attractive energy per molecule of water, and the attractive force between one molecule of water and one gel molecule.
b)Assuming that the gel in the centrifuge has a radius of curvature of 0.5 m when the centrifuge rotates, find the minimum tangential velocity with which the centrifuge needs to rotate in order for water molecules to just begin to separate from the gel molecules, at a separation of 0.4 nm
N_A = 6.02*10^23 molecule/mol
E=fr
F_c = mv^2/r
The attractive energy per molecule of water
E = 3.63kJ/mol of molecules of water
E = 3.63kJ/mol / 6.02*10^23 molecule/mol = 6.03*10^-24 kJ/molecule of H2O
The attractive force between one molecule of water and one gel molecule
E = fr
f = E/r = (6.03*10^-24 kJ/molecule) / 0.4*10^-9m = 1.51*10^-14 N/molecule of gel
The minimum tangential velocity
F_c = mv^2/r
F = 1.51*10^-14 N r = 0.5m
I know I can use this equation to find the velocity, but I don't know the mass. How can I find the mass?
To find the mass, we can use the formula for the centripetal force, where F_c = m*v^2/r. We know the force (1.51*10^-14 N), the radius (0.5 m), and we can assume a mass of one water molecule (1.67*10^-27 kg). Plugging these values into the equation, we get:
1.51*10^-14 N = (1.67*10^-27 kg) * v^2 / 0.5 m
Solving for v, we get a minimum tangential velocity of 0.0036 m/s. This is the minimum velocity needed for the water molecules to just begin to separate from the gel molecules at a separation of 0.4 nm.
1. What is tangential velocity and how is it related to attractive energy and force calculation?
Tangential velocity is the linear speed of an object moving along a circular path. It is related to attractive energy and force calculation because the force of attraction between two objects is directly proportional to the tangential velocity of one of the objects.
2. How is tangential velocity calculated?
Tangential velocity can be calculated using the formula v = rω, where v is the tangential velocity, r is the radius of the circle, and ω is the angular velocity. It can also be calculated as v = 2πr/T, where T is the period of rotation.
3. What is attractive energy and how is it calculated?
Attractive energy is the potential energy stored in a system due to the attractive force between two objects. It is calculated using the formula E = -Gm1m2/r, where G is the gravitational constant, m1 and m2 are the masses of the two objects, and r is the distance between them.
4. How does tangential velocity affect the force of attraction between two objects?
The force of attraction between two objects is directly proportional to the tangential velocity of one of the objects. This means that an increase in tangential velocity will result in an increase in the force of attraction between the two objects.
5. Can tangential velocity and attractive energy be measured in different units?
Yes, tangential velocity is typically measured in meters per second (m/s) or kilometers per hour (km/h), while attractive energy is measured in joules (J) or kilojoules (kJ).
29K
