- #71
- 8,595
- 4,620
I had given a link to Wikipedia where both the subjective and the objective variant are mentioned.skippy1729 said:PPS I would appreciate any reference to "objective" Bayesian probability theory.
DaleSpam said:Yes, Bayesian statistics can be applied to an ensemble, but they can also be applied to other situations. It is more general. From the wikipedia link and your comments I still can't tell exactly what you are referring to specifically when you say _subjective_ probability and why you think it is not relevant in physics. Are you just concerned about making bad subjective assessments in the prior probability?
A. Neumaier said:If there is only a single event, it depends on what is actually the case whether switching is a better option, and no risk analysis will help you if your choice was wrong.
A risk analysis is based upon the assumption that the distribution of the prize is uniform, so that you gain something from the disclosed information. This assumes an ensemble of multiple repetitions of the situation.
If the probabilities depend on the person it is a subjective probability.harrylin said:For a correct probability estimation beforehand, no "multiple" (infinite?!) repetitions of the situation are required. The subject can make an objective analysis based on the given information, even though for the quiz master the chance is 0 or 1 because he already knows the result.
I disagree. The Kolmogorov axioms for a probability space are satisfied.harrylin said:As a matter of fact, the "probability" of what actually is, is always 1 - That's not really "probability". :tongue2:
Any subjective estimations by that person don't play a role; only the available information. It's objective (although not "invariant") in the sense that the calculation is according to standard rules of probability calculus and everyone (except you?) agrees about that calculation.A. Neumaier said:If the probabilities depend on the person it is a subjective probability.
For the person doing the analysis, though the interest may be in predicting a single case, the objective probability refers to the probability in the ensemble analyzed, and not to the single unknown case. For in the latter case, the probability of a future event would depend on the particular past data set used, which (a) is strange and (b) would make it again a subjective probability. [...]
Thanks, now I clearly understand what you mean by subjective. You are correct that specifying a good prior can be a tricky business and that different users will often make different choices in priors which makes it subjective in your terminology.A. Neumaier said:Objective = independent of any particular observer, verifiable by anyone with the appropriate understanding and equipment.
Subjective = degree of belief, and such things, which cannot be checked objectively.
Bayesian statistics with an unspecified prior to be chosen by the user according to his knowledge is subjective statistics. It doesn't make user-independent predictions.
Bayesian statistics with a fully specified model, including the prior, is objective statistics.
On any sufficiently large sample the prior is irrelevant and only the data matters. So over an ensemble, even with subjective priors, the Bayesian approach gets user-independent (objective) posteriors.A. Neumaier said:One can check its predictions on any sufficiently large sample. Of this kind is the statistics in physics. The ensemble is always completely specified (apart from the parameters to be estimated).
Specifying the prior defines the ensemble and hence makes the probabilities objective - no matter whether the prior is good or poor. The quality of the prior is a measure not of objectivity but of matching reality.DaleSpam said:Thanks, now I clearly understand what you mean by subjective. You are correct that specifying a good prior can be a tricky business and that different users will often make different choices in priors which makes it subjective in your terminology.
Frequentist statistical tests often reduce to a Bayesian test with an ignorance prior. In your definition Bayesian statistics with an ignorance prior would be objective since it is user-independent.
However, what if we are not completely ignorant at the beginning? What if we have some knowledge that is not shared with other users? Why should the user-dependent (subjective) state of knowledge not lead to user-dependent priors and therefore user-dependent predictions about the outcome of some physical experiment?
But your ''sufficiently large'' may have to be far larger than mine.DaleSpam said:On any sufficiently large sample the prior is irrelevant and only the data matters. So over an ensemble, even with subjective priors, the Bayesian approach gets user-independent (objective) posteriors.
Bayesian techniques need both available information _and_ a prior. If the prior is not specified, it may depend on the persons subjective estimate, and calculations need not agree.harrylin said:Any subjective estimations by that person don't play a role; only the available information. It's objective (although not "invariant") in the sense that the calculation is according to standard rules of probability calculus and everyone (except you?) agrees about that calculation.
OK, I am fine with all of this. Your stance is even more acceptable to me than I had thought previously since you allow specified non-ignorance priors to encode available knowledge.A. Neumaier said:Specifying the prior defines the ensemble and hence makes the probabilities objective - no matter whether the prior is good or poor. ... This objectivity is the strength of scientific practice in general, and of physics in particular. It allows anyone with access to the necessary information and equipment check the quality of any particular model with respect to the application it is supposed to describe.
The model probabilities depend on the model, not on knowledge. Given the defintion of an ideal gasDaleSpam said:O
I don't see how it supports your claim that probability (in physics) does not depend on knowledge, but I agree with what you are saying.
Sorry about this, I wasn't clear in my point above. My point is that the prior contains the knowledge, so if you are specifying the prior you are fixing the knowledge.A. Neumaier said:The model probabilities depend on the model, not on knowledge. Given the defintion of an ideal gas
(say) and specified values of P,, V, T, everything is determined - independent of the knowledge of anyone.
The application probabilities depend on the application, not on knowledge. Given the definition of the experimental arrangement specifying the application, everything is determined - independent of the knowledge of anyone.
So all probabilities encountered in physics are objective and knowledge independent.
What depends on knowledge is the assessment of how well a model fits an application, and hence the choice of a particular model to predict in a particular application. But this has nothing to do with probability, since it holds as well for deterministic models.
DaleSpam said:Sorry about this, I wasn't clear in my point above. My point is that the prior contains the knowledge, so if you are specifying the prior you are fixing the knowledge.
You claim that probability does not depend on knowledge, but knowledge is contained in the prior, and you require a specified prior. Similarly, when you said "anyone with access to the necessary information and equipment" you are fixing the knowledge.
I have worked with structural engineers and am familiar with FORM and SORM techniques for limit state analysis, and with variations and alternatives for the assessment of reliability. This has no bearing on the theme.Studiot said:Your response to my structural engineering examples clearly indicate you have no idea what a bridge assessment or limit state design theory involves.
In both cases, the answer is 0 or 1, and can be known only after the fact.Studiot said:What is the probability that the Higgs will be discovered before the end of 2011?
Suppose I had asked a similar question in 1933
What is the probability that the positron will be discovered before the end of 1933?
a subensemble of all conceivable bridges with characteristics matching the concrete bridge in question,
Studiot-
limit state design
A.Neumaier-
Studiot said:One of the direct consequences of this statement, if true, has deep philosophical implications because it implies determinism.
That is that any point in time the future is completely determined with a probability of either 1 or 0.
No reason, except that the deterministic case is off topic and obvious.A. Neumaier said:By the same argument, deterministic models would depend on knowledge. So if you insist on the correctness of your argument, why emphasize it in the probabilistic case but not in the determinstic case?
Certainly, you could also make arithmetic errors or typographical errors, or you could misapply a formula, or you could use wrong formulas. Any time you use misinformation or misuse information in physics you will get nonsense. I don't think that is terribly interesting other than pedagogically.A. Neumaier said:Moreover, a model may have a very unrealistic prior. In this case, probabilities depend - according to your view - on arbitrary assumptions or on misinformation rather than knowledge.
Yes, but your definition is not the only valid and accepted definition of probability. Your claim is only true if you require probabilities to be defined only over ensembles. In that case I agree that the posterior probability does not depend on the prior so in that case you are indeed correct that probability does not depend on knowledge. Under the more general definition of probability the posterior can depend on the prior in any case where you do not have a sufficiently large number of observations.A. Neumaier said:On the other hand, with my usage of the terms, everything is clear and unambiguous.
A. Neumaier said:Bayesian techniques need both available information _and_ a prior. If the prior is not specified, it may depend on the persons subjective estimate, and calculations need not agree.
Thus if one gives strict rules for how to determine the prior from prior information (this is the case in the bayesian applications to animal breeding I had cited before), the calculated Bayesian estimates are objective.
In all other cases, the calculated Bayesian probabilities are subjective.
This is different from the fixed-prior case. Here, instead of having a fixed prior you have a family of priors with some hyper-parameters which are uniquely specified by available information. Note that in this case the probabilities are objective (user independent), but they do depend on knowledge.A. Neumaier said:Thus if one gives strict rules for how to determine the prior from prior information (this is the case in the bayesian applications to animal breeding I had cited before), the calculated Bayesian estimates are objective.
You misunderstood what I said. Saying that a particle has a fuzzu position means that it actually _has_ this position independent of any measurement, but that its value is meaningful only up to an accuracy determined by the uncertainty relation. The position is given not by |psi|^2 but by xbar=psi^*x psi, with an absolute uncertainty of sqrt(psi^*(x-xbar)^2 psi).SpectraCat said:You are the one who started telling Varon (on the interpretations poll thread I think) about how the position of a particle does exist, but is not well-defined (you used the term fuzzy) until a measurement is made. What do you use to describe the existence of the particle position prior to the measurement if you don't use |psi|^2?
Whether you answer ''with 75% probability'' or ''with 10% probability'', nobody can verify whether your answer was correct when the bridge collapsed, or didin't collapse, upon driving the lorry over it.Studiot said:You are presented with a specific bridge over a ravine. [...]
As the Engineer you are asked
Will the bridge collapse if I drive my lorry over it?
As far as it is applied to a particular situation, you always have a subjective probability, which is not verifiable by checking against reality.Studiot said:This represents a one off unique situation and you have to make an assessment ie a subjective decision to allow for the fact that all the facts are not ( and probably cannot be ) known.
I am familiar with it. But the bridge example is one of analysis, not of design. And though I know about limit state design, I was not directly involved in that. Thus I deliberately changed the wording. However, it is not _so_ different from limit state analysis, as it involves the latter as a constraining design condition. So it is part of the total optimization problem to be solved. I have been involved in the design of devices facing uncertainty by other methods; see, e.g., p.81ff of my slides http://arnold-neumaier.at/ms/robslides.pdfStudiot said:You did not read my post correctly either.
Are you not familiar with the difference between analysis and the more difficult process of synthesis (or design)?
It doesn't imply determinism, since no dynamical law is involved in it. It only implies (or assumes, depending on what you regard as given) that after something happened, it is a fact, independent of the future.Studiot said:One of the direct consequences of this statement, if true, has deep philosophical implications because it implies determinism.
It is not off-topic since it serves to clarify the issue, and it is as obvious in the probabilisitc case as in the deterministc case, hence there is no reason to emphasize it in the latter case. It doesn't add any useful insight into the nature of probability.DaleSpam said:No reason, except that the deterministic case is off topic and obvious.
But in that case, the probability is subjective, and not checkable by anyone.DaleSpam said:Yes, but your definition is not the only valid and accepted definition of probability. Your claim is only true if you require probabilities to be defined only over ensembles. In that case I agree that the posterior probability does not depend on the prior so in that case you are indeed correct that probability does not depend on knowledge. Under the more general definition of probability the posterior can depend on the prior in any case where you do not have a sufficiently large number of observations.
DaleSpam said:This is different from the fixed-prior case. Here, instead of having a fixed prior you have a family of priors with some hyper-parameters which are uniquely specified by available information. Note that in this case the probabilities are objective (user independent), but they do depend on knowledge.
As far as it is applied to a particular situation, you always have a subjective probability, QUOTE]
Loud applause all round.
That is the point everyone has been trying to make to you. Subjective probability has a place in physical science.
Further there exist a range of probabilities, useful in science, between the values 0 and 1.
which is not verifiable by checking against reality.[/
You test your assessment by driving over the bridge.
My specific examples separately addressed two different points. (1) Uncertainty and (2)objective v subjective.
Limit State theory (analysis or design) is a real world example of applied science attempts to allow for inevitable uncertainty in an objective way. There is no subjectivism whatsoever in this theory. It has been highly successful in increasing design eficiency.
Bridge assessment contains a specific subjective component as a formal part of the process. An extra factor is introduced called the condition factor. This is a subjective derating factor, not present in normal limit state or other analysis methods. (Assessment does not necessarily use limit state theory.)
No, since it is not testable.Studiot said:Subjective probability has a place in physical science.
Studiot said:You test your assessment by driving over the bridge.
In the art of using science, not in science itself. Subjective probability is a guide to action in single instances, but not a scientific (testable) concept.Studiot said:You have not disgreed that there is room, even a necessity, for a subjective component to probability in applied science.
Studiot said:You mentioned several times that a probability value exists for something whether the observer knows this value or not.
Similarly a probability value exists whether the observer tests, or can test or not.
Fra said:Umm... I'd say physics (and natural science in general) is ALL about us learning ABOUT nature, what we can say about nature.
A. Neumaier said:''us learning'' is the subject of psychology, not of physics.
A. Neumaier said:Originally Posted by Studiot
lalbatros said:It is testable: humans are testable!
In the case of a machine, it is a matter of artificial intelligence, not of physics.Fra said:In the case of and observer = human scientist, that's of course correct. I agree.
The myth that probability depends on knowledge is the belief that the likelihood of an event occurring can be affected by what we know or believe about it. This is often used to justify superstitious or irrational beliefs, but in reality, probability is based on objective factors and cannot be influenced by subjective knowledge or beliefs.
This myth is misleading because it implies that our beliefs or knowledge can somehow alter the likelihood of an event occurring, when in fact, probability is determined by objective factors such as chance and randomness. Our knowledge or beliefs may influence our perception of probability, but they do not actually affect the outcome of events.
There is ample evidence from various fields such as mathematics, statistics, and psychology that disproves this myth. For example, the laws of probability, such as the law of large numbers and the law of averages, are based on objective principles and are not influenced by our knowledge or beliefs. Additionally, studies have shown that people's perception of probability is often biased and can be easily manipulated, further disproving the idea that probability depends on knowledge.
This myth can have a significant impact on decision making, as people may make choices based on their subjective beliefs about probability rather than objective factors. This can lead to poor decision making and can also perpetuate superstitious or irrational thinking. It is important to understand that probability is not influenced by our knowledge or beliefs in order to make informed and rational decisions.
To combat this myth, it is important to educate ourselves and others about the principles of probability and how it is determined by objective factors. We can also practice critical thinking and question our own biases and beliefs when making decisions. Additionally, promoting scientific literacy and critical thinking skills in education can help combat this and other myths that can lead to misinformation and irrational thinking.
