Heat of Formation and Heat of Reaction Difference
In summary: Therefore, ΔH°rxn and ΔH°f are different because they measure different types of enthalpy changes.In summary, ΔH°rxn is the enthalpy change of a reaction, while ΔH°f is the enthalpy change of the formation of a substance from its elements. ΔH°rxn takes into account all enthalpy changes of formation for both the reactants and products, while ΔH°f only considers the enthalpy change of formation of the specific substance. Therefore, they are different and serve different purposes in thermodynamics.
Bcranger 0
Take for example the problem given below:
C + O2 → CO2 ΔH°f = -393.5 kJ/mol
2CO + O2 → 2CO2 ΔH°rxn = -566.0 kJ/mol
To determine the ΔH°f of CO from the reaction of C graphite and O2 given those equations, one would solve it as: -393.5 kJ/mol + 1/2(566.0)= -110.5 kJ/mol
I realize that ΔH°rxn must be flipped since the reaction must be flipped.
However, why is it expressed as ΔH°rxn rather than ΔH°f? Is there a difference between the two?
Homework Equations ΔH°rxn = ΣΔH°f (products) - ΣΔH°f (reactants) The Attempt at a SolutionI think the difference between ΔH°rxn and ΔH°f is that ΔH°rxn is the enthalpy change of the reaction whereas ΔH°f is the enthalpy change of the formation of one mole of a substance from its elements in their standard states. For example, if we were to calculate the enthalpy change of the reaction C + O2 → CO2, we would use the equation ΔH°rxn = ΣΔH°f (products) - ΣΔH°f (reactants). This equation takes into account all of the enthalpy changes of formation for both the reactants and products. On the other hand, if we were to calculate the enthalpy change of formation for CO2, we would use the equation ΔH°f = ΔH°f (CO2). This equation only takes into account the enthalpy change of formation for CO2 and ignores the enthalpy changes of formation of the reactants.
What is the difference between heat of formation and heat of reaction?
Heat of formation is the energy released or absorbed when one mole of a compound is formed from its constituent elements in their standard states. Heat of reaction, on the other hand, is the energy released or absorbed during a chemical reaction. Heat of formation is a specific type of heat of reaction that only applies to the formation of a compound.
How are heat of formation and heat of reaction measured?
Both heat of formation and heat of reaction are measured in units of energy per mole (kJ/mol or kcal/mol). These values can be experimentally determined using calorimetry, which measures the heat flow of a reaction. Alternatively, they can be calculated using Hess's law, which states that the total enthalpy change of a reaction is equal to the sum of the enthalpy changes of its individual steps.
What factors can affect the values of heat of formation and heat of reaction?
The values of heat of formation and heat of reaction can be affected by temperature, pressure, and the physical state of the reactants and products. Changes in these factors can alter the enthalpy of a reaction and thus, the values of heat of formation and heat of reaction.
Can the heat of formation and heat of reaction be negative?
Yes, both the heat of formation and heat of reaction can be negative. A negative value indicates that the reaction is exothermic, meaning it releases energy. This can occur when the bonds formed in the products are stronger than the bonds broken in the reactants, resulting in a net release of energy.
Why are heat of formation and heat of reaction important in chemistry?
Heat of formation and heat of reaction are important in chemistry because they provide insight into the energy changes that occur during a chemical reaction. This information can be used to determine the feasibility of a reaction, as well as to predict the conditions under which a reaction will occur. Additionally, these values are often used in chemical equations and calculations, making them essential for understanding and predicting chemical reactions.
13K
