If energy/matter deforms spacetime in three dimensions
In summary, the formation of galaxies and the emission of radiation from black holes in a single plane cannot solely be attributed to the effects of gravity. In the case of spiral galaxies, other factors such as the rotation of gas and stars play a role. Additionally, the spin of a black hole also affects the behavior of matter and can cause it to remain in a single plane. This can be seen in the example of the Earth's equatorial bulge, which is caused by the planet's rotation.
cowmoo32
122
If energy/matter deforms spacetime in three dimensions...
Then why do we get galaxies in (relatively) flat discs and black holes that emit radiation in a single plane?
Well, electric charge acts in 3D, but we can still get 2D materials like graphene.
You have assumed gravity is the unique and direct cause of such phenomena..it isn't .
Spiral galaxy formation:
http://en.wikipedia.org/wiki/Spiral_galaxies#Origin_of_the_spiral_structure
Kip Thorne: BLACK HOLES AND TIME WARPS:
black hole radiation: a spinning black hole behaves like a gyroscope...near the hole the disk
remains in the black hole equatorial plane. gas accreting into the hole from its disk makes the hole spin faster and anchors the disk.
Maybe a crude analogy is the equatorial bulge of the earth...if gravity is symmetrical around a sphere of approximate unuiform mass density, why should such a mass "bulge"..
because of the spin of Earth about its axis.
What is the concept of energy/matter deforming spacetime?
The concept of energy/matter deforming spacetime is a fundamental concept in Einstein's theory of general relativity. It states that the presence of energy or matter in a region of space causes a curvature in the fabric of spacetime, resulting in the warping of the geometry of space.
How does energy/matter deform spacetime in three dimensions?
In three dimensions, energy/matter can be thought of as creating a dip in the fabric of spacetime, like placing a heavy object on a stretched rubber sheet. The heavier the object, the deeper the dip, and the more it distorts the surrounding space.
Does all energy/matter deform spacetime in the same way?
No, different types of energy/matter have different effects on the curvature of spacetime. For example, a massive object like a planet will have a greater effect on the warping of spacetime compared to a lighter object like a star.
What are some observable effects of energy/matter deforming spacetime?
One of the most well-known effects is gravitational lensing, where the path of light is bent by the curvature of spacetime around a massive object. This can result in the appearance of distorted or multiple images of distant objects. Another effect is the slowing down of time near massive objects, known as gravitational time dilation.
Can energy/matter cause spacetime to curve in the opposite direction?
Yes, according to Einstein's theory of general relativity, energy/matter can cause both positive and negative curvature of spacetime. Positive curvature is associated with gravity, while negative curvature is associated with repulsive forces, such as dark energy. However, the overall curvature of spacetime is determined by the total amount and distribution of energy/matter in the universe.
