Special Relativity Energy Problem a little confused
In summary, at Earth's location, the intensity of sunlight is 1.5kW/m^2 and if no energy escaped Earth, the mass would increase by 1.83x10^5kg in 1 day. This can be calculated by integrating over the cross sectional area of the hemisphere and taking into account the angle of incidence for each location.
Engineergirl2
At Earth's location, the intensity of sunlight is 1.5kW/m^2. if no energy escaped earth, by how much would Earth's mass increase in 1 day?
ΔE=Δmc^2+ΔKE
Rearth=6.378x10^3
I know that the change in kinetic energy does not change, so that value can go to 0. But I'm not sure what exactly I'm supposed to start with. The answer is supposed to be 1.83x10^5kg/day. Any help would REALLY be appreciated.
You need to calculate how much energy is received in 1 day by the entire Earth.
You know how much is received in one second (kW is energy per second) by 1 m^2 of the surface.
Do I use cross sectional area?
You can use the cross sectional area and assume the radiation is normal on it.
Integrating over the area of the (hemi-)sphere and taking into account the angle of incidence for each location will produce the same result.
As a scientist, it is important to approach problems with a clear understanding of the relevant equations and concepts. In this case, the problem is related to special relativity and the relationship between energy and mass.
The first step is to understand the concept of mass-energy equivalence, as described by Einstein's famous equation, E=mc^2. This equation shows that energy and mass are equivalent and can be converted into one another.
In this problem, we are given the intensity of sunlight at Earth's location, which is a measure of energy per unit area. We also know that the Earth is not losing or gaining any energy, so we can assume that the change in kinetic energy is negligible. This means that the change in mass is due to the change in energy.
Using the formula ΔE=Δmc^2, we can calculate the change in mass by rearranging the equation to Δm=ΔE/c^2. Plugging in the given values, we get Δm=(1.5kW/m^2)(1 day)/(c^2). The speed of light, c, is equal to 299,792,458 m/s, so c^2=8.988x10^16 m^2/s^2. Plugging this in, we get Δm=(1.5x10^3 J/m^2)(1 day)/(8.988x10^16 m^2/s^2)=1.67x10^-14 kg.
However, this is the change in mass per second. To get the change in mass per day, we need to multiply by the number of seconds in a day. There are 86,400 seconds in a day, so the final answer is 1.83x10^5 kg/day.
In summary, by understanding the concept of mass-energy equivalence and using the relevant equations, we can calculate the change in mass of Earth due to the intensity of sunlight at its location. This type of problem highlights the intricate relationship between energy and mass, as described by special relativity.
1. What is the Special Relativity Energy Problem?
The Special Relativity Energy Problem refers to the discrepancy between the laws of Special Relativity and classical mechanics when it comes to calculating kinetic energy of a moving object. According to Special Relativity, the kinetic energy of an object should increase to infinity as it approaches the speed of light, which contradicts the principle of conservation of energy.
2. How did Einstein address the Special Relativity Energy Problem?
Einstein addressed the Special Relativity Energy Problem by introducing the concept of relativistic mass. According to the theory of Special Relativity, the mass of an object increases as its velocity approaches the speed of light. This means that the kinetic energy of an object also increases, but the total energy (kinetic + rest mass energy) remains constant.
3. What is the formula for calculating relativistic mass?
The formula for calculating relativistic mass is m = mo/√(1-v^2/c^2), where m is the relativistic mass, mo is the rest mass, v is the velocity of the object, and c is the speed of light.
4. How does the Special Relativity Energy Problem impact our understanding of the universe?
The Special Relativity Energy Problem has a significant impact on our understanding of the universe. It challenges our traditional understanding of energy conservation and raises questions about the nature of space and time. It also has practical implications in fields such as particle physics and astrophysics, where objects can reach speeds close to the speed of light.
5. Are there any other solutions to the Special Relativity Energy Problem?
There are other proposed solutions to the Special Relativity Energy Problem, such as the concept of "invariant mass" and the use of quantum mechanics. However, the concept of relativistic mass remains the most widely accepted solution to the problem.
