Is Mass Dependent on Temperature According to Mass-Energy Equivalence?
In summary, the conversation revolves around the question of whether mass is temperature-dependent or not. While the original poster believes that kinetic energy can alter the apparent mass of a system, others argue that the rest mass remains constant and only the total rest mass of the system increases. This is due to the relationship between energy, momentum, and rest mass, which shows that the total rest mass of a system is always greater than or equal to the sum of the rest masses of its individual components. Ultimately, the conversation raises further questions about the definition of atomic mass units and their potential dependence on temperature.
  • #36
Caledon said:
Thank you both for your insights. Xox, I know exactly what you mean about linguistics being a relatively (haha) inferior means of describing these properties; it seems like conflicting definitions of mass and energy are the source of many of the contrary opinions I've been reading. Unfortunately I have to rely heavily on linguistics in my classroom because our district prefers to make math terrifying.
On this subject, let me extend another line of inquiry; this is what I meant in my original post by "mass defined at a particular temperature". If atoms are always in motion, i.e. they have some amount of kinetic energy, I assume that energy cannot be easily quantified, per Uncertainty, nor can it be removed, per thermodynamics. Thus there will always be some baseline rest mass M that is in fact the aggregate of particle mass m and baseline energies k and U, perhaps analogous to something like Planck's constant.
Is this the state at which an atom's atomic mass is calculated? Meaning, is it extrapolated as opposed to directly observed? Or are we just working with empirical measurements that include some ambient temperature, such as room temp, and the nuanced differences are too small for us to really care about in terms of anything except, say, the LHC? The SI definition of the mole says nothing about energy or temperature considerations.
Measure the energy and the magnitude of the momentum:
[tex]E=\gamma m_0 c^2[/tex]
[tex]p=|\vec{p}|=\gamma m_0 v[/tex]
From the above, the speed is :
[tex]v=\frac{E}{pc^2}[/tex]
Armed with this, we calculate :
[tex]\gamma=\frac{1}{\sqrt{1-(v/c)^2}}[/tex]
and finally
[tex]m_0=\frac{E}{\gamma c^2}[/tex]
or
[tex]m_0=\frac{p}{\gamma v}[/tex]
  • #37
xox said:
We know that rest mass isn't additive (nor is its equivalent, rest energy), so why would the above be correct?
Um, because it doesn't just include rest masses, but also kinetic energies in the center of mass frame, and binding energies?
  • #38
Yet, according to your earlier post, the LHS is the rest mass, [itex]M_0[/itex].
  • #39
Caledon said:
So a mole is just a number, and that number coincides with the atoms in 12g of C12 at rest
More precisely, it is the number of atoms in 12 g of C12 assuming that all of the atoms are at rest. (And also, to be precise, assuming that the binding energies between the atoms are insignificant.) In other words, it is 12 g divided by the mass number of the carbon-12 nucleus.
Caledon said:
The connection I'm having trouble making is, how can this be used to stoichiometrically calculate the atoms in a given sample that is not at rest
First of all, once again, don't confuse the individual atoms being in motion with the sample being in motion. Do you do stoichiometry on samples that are flying around your lab? I'm betting the samples are sitting at rest on a table in your lab.
The fact that the individual atoms in the sample are not at rest does introduce a (very small) inaccuracy into the calculation of the number of atoms in the sample, yes. (So do the binding energies between the atoms.) But for practical purposes this inaccuracy is much too small to matter.
For example, suppose I have a lump of pure coal that is exactly 12 grams of carbon-12 atoms, as measured while it's sitting at rest in the lab. How many atoms will there be in the lump? It won't be exactly Avogadro's number (12 grams divided by the mass number of carbon-12); it will be a bit smaller, because the sample is at some finite temperature and there are binding energies associated with the covalent bonds between the carbon atoms. How much smaller? (That is, how much error am I making if I assume there are exactly one Avogadro's number of atoms in the sample?) Well, we just write down an equation similar to what I wrote above:
M_0 = N \left( m_{12} + T \right) - U
where ##M_0 = 12## is the rest mass of the sample (note that I'm using units in which ##c = 1##, so mass and energy have the same units), ##N## is the actual number of atoms in the sample, ##m_{12}## is the mass number of carbon-12, ##T## is the absolute temperature of the sample (measured in energy units), and ##U## is the total of all the chemical bond energies. Rearrange this as follows:
N = \frac{M_0 + U}{m_{12} + T} = \frac{M_0}{m_{12}} \left( \frac{1 + U / M_0}{1 + T / m_{12}} \right)
So the size of the error is just the factor in parentheses on the right. How big is that? Let's plug in some numbers.
##U / M_0## can be estimated from the heat of combustion of coal, which varies with the type of coal; the highest value I've found online is 32 kilojoules per gram, which equates to 32,000 times 10,000,000 ergs per Joule, divided by ##c^2## to get "grams per gram" of binding energy. This is a very small number, about ##3.6 \times 10^{-10}##.
##T## is just the absolute temperature in mass units, which for ##T## in Kelvins is just ##k_B T / c^2##, where ##k_B = 1.38 \times 10^{-23}## is Boltzmann's constant (again in SI units, so we have to correct for that as well to get ##T## in grams). For an ordinary temperature of 300 K, this gives ##T = 4.6 \times 10^{-35}## in grams.
##m_{12}## is exactly 12 atomic mass units, by definition, and an a.m.u is ##1.66 \times 10^{-24}## grams. This gives another very small number for ##T / m_{12}##, about ##2.3 \times 10^{-12}##. This is less than 1 percent of ##U / M_0##, so it will, at best, reduce the error slightly (since it appears in the denominator) compared to the effect of ##U / M_0##. So the total error involved in not counting the kinetic temperature or binding energy when estimating the number of atoms in the sample is at most a few parts in ten billion, i.e., way too small to matter in practical terms.
  • #40
The rest mass of the *system*, yes. And the formula therefore explicitly says that the rest mass of the system is *not* the sum of the rest masses of its constituents, since additional terms appear for the kinetic energies and binding energies.
  • #41
No, what you state is that it is "the rest mass of the atom", I am interested in the extension of the formula from one atom to a system of atoms:
PeterDonis said:
Yes, this is true, and it means that the rest mass of the atom includes the kinetic energy of the particles that constitute it, *in addition to* the binding energy between those particles. So, for example, in the simplest case of a hydrogen atom, we would have
M_0 = m_p + m_e + k_p + k_e - U
where ##M_0## is the rest mass of the atom, ##m_p## is the rest mass of a proton, ##m_e## is the rest mass of an electron, ##k_p## and ##k_e## are the kinetic energies of the proton and electron (in the center of mass frame of the atom), and ##U## is the binding energy. In general, ##k_p + k_e - U## will not be zero, so the rest mass of the atom won't be equal to the sum of the rest masses of its constituents.
I have no argument with that, what I find confusing is the way you plan to extend the formula from one atom to a system of atoms moving wrt. each other. To fix the ideas, could you please write the total (rest) mass of two atoms moving wrt. each other with speed v?
  • #42
For the case where the "system" is one atom, which was the case under discussion when I defined the formula. For the case where the "system" contains many atoms, the LHS is the rest mass of the system. Sorry if that wasn't clear.
In the center of mass frame, atom #1 is moving to the left at speed ##u## and atom #2 is moving to the right at ##u##, where
v = \frac{2 u}{1 + u^2}
implicitly gives ##u## in terms of ##v##. Then, assuming both atoms have rest mass ##m## and that ##k## is the kinetic energy of an object with rest mass ##m## moving at speed ##u##, we have
M_0 = 2 \left( m + k \right) = 2 \gamma m
where ##\gamma = 1 / \sqrt{1 - u^2}## (assuming there is no significant interaction between the atoms and therefore no binding energy involved).
  • #43
I am sorry if I were unclear, I was asking for the generalization (for two atoms) of the case you explained in post 21, that is for the case when binding energy IS significant. I know very well how to treat the case in the absence of binding energy. As an aside, I disagree with what you wrote above, [itex]2 \gamma mc^2 [/itex] is not the rest mass, it is the total energy. We seem to keep having this disagreement. The moment [itex]\gamma[/itex] appears in the formula, you cannot longer claim to be talking about "rest" mass.
  • #44
Forget about the term "rest mass". All it does is confuse people. Do what Real Physicsists (TM) do, and call it just "mass", or if you want to make a point of distinguishing it from the so-called "relativistic mass", call it "invariant mass."
The ("rest") mass of a system equals the total energy of the system, divided by c2, in the reference frame in which the total momentum of the system is zero. It is in that sense that we use the word "rest" here, even though in that frame the individual particles are still moving.
Or more generally, calculate the mass of the system using
$$mc^2 = \sqrt{(\Sigma E_i)^2 - (\Sigma \vec p_i c)^2}$$
which works in any inertial reference frame.
  • #45
I already showed how this is done, early in the thread.
Peter and I are discussing a different situation, how to extend the calculations in the case of presence of binding energy. Can you shed some light?
  • #46
Ok, then it would be ##M_0 = 2 \gamma m - U##, where ##U## is the binding energy due to the interaction between the atoms.
Since the system as a whole is at rest (because we are in the center of mass frame of the system), its total energy *is* its rest mass. Don't confuse the system with its constituents. The system as a whole is at rest even though its constituents are not.
Yes, you can, as long as you're clear about *what* is at rest and what isn't. See above.
  • #47
Doing this in the general case, i.e., in an arbitrary reference frame, raises some issues, because the definition of "binding energy" is the energy that would be required to break the system up and make each of its constituents a free object "at infinity" relative to all the others. This definition presupposes that there is in fact an "infinity" available, i.e., that the system is isolated; and if the system is isolated, it must pick out a definite center of mass frame, in which the binding energy is calculated.
Once the calculation is done, and a total 4-momentum for the system is obtained, that 4-momentum can be treated as an ordinary Lorentz-covariant 4-vector. But if binding energy is involved, there is no longer any Lorentz-invariant way to obtain that 4-vector by adding up 4-vector contributions from each constituent of the system, which is what jtbell's formula is equivalent to.
Another way of putting this is that binding energy works like potential energy, i.e., it's a function of position; but "position" is frame-dependent. In any system where a well-defined potential energy exists, it is only well-defined as a function of position in a particular frame, the system's center of mass frame. In other words, potential energy is not a Lorentz scalar, nor can it be modeled in general as a 4-vector or any other Lorentz-covariant mathematical object.
  • #48
Do you have a reference for this?
Then you cannot have any [itex]\gamma[/itex] in the expression of energy for the mere reason that...[itex]\gamma=1[/itex].
I am not confusing anything but I am sorry to say that your presentation is very poor.
  • #49
In other words, the previous post:
has no justification.
  • #50
I see that I should have used the term "potential energy" to describe ##U## rather than binding energy. Does that make it clearer? All I'm saying is that the system as a whole is described by a 4-momentum vector whose invariant length is ##M_0##; and that invariant length is determined by summing up the rest masses, kinetic energies, and potential energies of the constituents, all evaluated in the center of mass frame of the system. You have to do it in that particular frame because potential energy as a function of position is only well-defined in that frame, as I said in my last post.
Sigh. I specifically said that ##\gamma = 1 / \sqrt{1 - u^2}##, and ##u## is not zero in the center of mass frame of the system (I defined what it was in an earlier post).
xox said:
I am not confusing anything.
Well, you certainly seem to be, since you are evidently misinterpreting what ##\gamma## means. See above.
That may be; feel free to re-state what you believe to be correct in terms that seem to you to be appropriate. But nothing I've said contradicts the point you seemed most concerned about, that rest mass is not additive.
  • #51
Sure it does; I specified that I was doing that calculation in the center of mass frame, where it *is* valid.
  • #52
No, it doesn't since all you are doing is waving your arms without being able to present a complete , coherent argument. If you were to do all the calculations accompanying your prose, then we could have a discussion.
Once again, could you please put this prose into math? Two atoms would be sufficient. If you have a reference, that is even better, I can go and read on my own.
This is a strawman, I never said that rest mass is additive, quite the opposite. On the other hand, the manipulations that you have posted are all over the map, so I am trying to see if you could write one coherent, non-contradictory, complete , mathematical treatment on the subject. I wrote one for the case of absent binding energy, can you write one for the case of binding energy being present? I am interested in the answer , if you cannot produce it , just say so and we are done.
  • #53
Let me explain this to you:
We can always find [itex]\vec{V}[/itex] such that:
[tex]E=\gamma(V) M c^2[/tex]
[tex]\vec{p}=\gamma(V) M \vec{V}[/tex]
[tex]\vec{V}=\frac{\Sigma {\gamma_i m_i \vec{v_i}}}{\Sigma {\gamma_i m_i }}[/tex]
and
[tex]M=\frac{\Sigma{\gamma_i m_i}}{\gamma(V)}[/tex]
There is a frame, called "center of momentum" (not "center of mass") where [itex]\vec{V}=0[/itex].
In that frame the mass of the system is :
[tex]M=\Sigma{\gamma'_i m_i}[/tex]
where
[tex]\gamma'_i=\frac{1}{\sqrt{1-(v'_i/c)^2}}[/tex]
and [itex]v'_i[/itex] are the speeds of the system constituents in the "center of momentum" frame.
  • #54
I'll agree that "center of momentum" frame is a more accurate term. I've encountered both plenty of times, though.
where
Which is exactly what I wrote down for the 2-particle case with zero binding energy; I specified ##| v_1 | = | v_2 | = u## and ##m_1 = m_2 = m##. (I used units where ##c = 1##.)
Now please tell me how you would modify what you wrote for the case of nonzero binding energy.
  • #55
And I never said you said that. You keep on appearing to read me as saying exactly the opposite of what I said. I am quite aware that you said that rest mass is *not* additive, and I agree with you on that point.
  • #56
"Center of mass" doesn't make any sense, "center of momentum" obviously does.
It was your use of "center of mass" and your use of "rest mass" that threw me off, now we are in clear.
I have no idea, this is precisely I was hoping that you would clarify. Once again, can you write down an explanation (math, please) or give a pertinent reference?
  • #57
Apparently it does to a lot of people who write physics textbooks and articles.
Then I'm confused, because you appeared to think there was something wrong with what I already wrote down, whereas to me it seems obvious. If, in the absence of binding energy (i.e., if the system as a whole is not in a bound state--there are no interactions between the constituents), we have
M_0 = \Sigma \gamma'_i m_i
then isn't it obvious that, in the presence of binding energy (i.e., if the system as a whole is in a bound state), we must have
M_0 = \Sigma \gamma'_i m_i - U
where ##U## is some positive number? All this is saying is that it would take some input of energy to convert the system from its current bound state to a state in which all the constituents were free.
We could also define a "constituent mass" ##M_c = \Sigma m_i##, i.e., the simple sum of the constituent rest masses, and say that, for any real bound system, we must have ##M_0 < M_c##, i.e., ##M_0 = M_c - V##, where ##V## is some positive number--i.e., we are now saying it would take some input of energy to convert the system from its current bound state (i which some constituents may be moving) to a state in which all the constituents were free *and at rest*. (For any real bound state, we would expect this to be true.) This is obviously a more stringent condition on ##M_0## than the above; it requires that the ##U## in the formula I gave above is larger than ##V##, possibly significantly larger (if the constituents of the system in the CoM frame are moving at significant velocities). Is this what you were trying to get at?
If you're looking for a more specific form for ##U## or ##V##, that's going to depend on the specific system. I wasn't trying to go into that kind of detail since it didn't seem like the OP needed it. Is that what you're interested in?
  • #58
No, it isn't obvious at all. While [itex]M= \Sigma \gamma'_i m_i[/itex] was derived from base principles, you put by hand [itex]M= \Sigma \gamma'_i m_i-U[/itex]. What allows you to do that? Why not [itex]M= \Sigma \gamma'_i m_i-U_i[/itex]? Do you have a reference to either formula?
No, not at all, I am trying to find a derivation of the mass of a system of particles from base principles, like I did it in post 5, for the case when binding energy is not zero. I see no reason why the binding energies of the constituents can be represented by a single variable, U, as you did it above.
No, I am not looking at this level of detail, I am simply looking at a consistent, coherent methodology for driving the mass of the system in the presence of binding energies.
  • #59
Because energy is additive.
What do you mean with [itex]U_i[/itex]?
  • #60
He's not adding energy, he's adding mass (with binding energy divided by [itex]c^2[/itex]). I have no idea what allows him to do that. Moreover, not any energy is additive, total energy is additive.
Each atom has its own binding energy, hence the [itex]U_i[/itex].
  • #61
xox said:
He's not adding energy, he's adding mass.
According to his original statement you would be right because he defined the kinetic energy of the particles "(in the center of mass frame of the atom)". But if I understand the following discussion correctly he changed that to the rest frame of the total assembly of all atoms. In that case he is actually adding energies. Maybe the term "rest mass" for "rest energy" is confusing at this place but that's the current convention.
If the energies are related to the same frame of reference they should be additive.
And what about the potential energy related to interactions between different atoms (e.g. the binding energy of H2)?
  • #62
No, he's not adding energies. Let me explain this to you in more detail: in post 5 I have shown that the mass of a system of particles can be calculated, from base principles, as:
where:
Later on, I showed that in the "center of momentum" (not "center of mass") the mass of the system is:
by virtue of the fact that [itex]\vec{V}=0[/itex] in the center of momentum frame. In the above:
where [itex]v'_i[/itex] represent the speeds of the particles transformed into the "center of momentum" frame.
There is NO justification to simply write :
[tex]M=\Sigma{\gamma'_i m_i}-U[/tex]
in the case of a system with non-null binding energy. One cannot slap the binding energy onto the formula of mass derived (from base principles) for a system with null binding energy and declare that the correct answer. The approach is unacceptable on many levels:
1. There is no derivation from base principles
2. There is no reason to combine mass with binding energy (the formula isn't even dimensionally correct, U should appear divided by c^2)
3. There is no clear understanding of what is U, (the total binding energy? )
4. Is U frame invariant? Or is it frame variant?
And the list can go on. This is not a proper derivation, it is just some stuff carelessly slapped together.
This is not true.
No idea, this is why I am objecting to the whole approach.
  • #63
If that happens to be the case, we would just write ##U = \Sigma U_i##. I didn't say anything about the form of ##U##; it doesn't have to be a single number or a single function.
In the case where a well-defined potential energy as a function of position exists, the form of ##U_i## will be ##U_i = \Phi(x_i)##, where ##\Phi## is the potential energy function. So the total invariant mass of the system will be ##M_0 = \Sigma \left( \gamma'_i m_i - \Phi ( x_i ) \right)##.
But, as I noted in a previous post, you won't be able to transform this expression into an arbitrary frame, because the potential energy function won't transform correctly, since its argument is a 3-vector in a particular frame, not a 4-vector. You can define a total 4-momentum vector for the system whose norm is ##M_0##, but that's all.
To give a concrete example, consider a hydrogen-1 atom, i.e., a proton and an electron in a bound state. For concreteness, assume it's the ground state. As an approximation to the actual CoM frame, we'll work in a frame in which the proton is at rest, and we'll define the potential energy function ##\Phi## in this frame using the proton's field only, i.e., it's only nonzero for the electron. (This is a pretty good approximation because the proton's rest mass is so much higher than the electron's.) So we have ##\Phi = k e^2 / r##, where ##k## is the Coulomb constant, ##e## is the magnitude of the charge on the electron (and the proton), and ##r## is the distance between them. That gives
M_0 = m_p + \gamma_e m_e - k e^2 / r
If we take ##r## to be the Bohr radius and calculate ##\gamma_e## using the classical formula for the orbital velocity at radius ##r## in an inverse square field, we get ##\gamma_e \approx 1 + 2.66 \times 10^{-5}##, i.e., the kinetic energy of the electron is about ##2.66 \times 10^{-5}## times its rest mass, or 13.6 eV. For ##k e^2 / r##, with ##r## the Bohr radius, we get 27.2 eV, so the overall result is M_0 = m_p + m_e + 13.6 eV - 27.2 eV = m_p + m_e - 13.6 eV. 13.6 eV is, of course, the usually quoted binding energy of the hydrogen atom.
I'll defer discussion of how to derive all this from "first principles" to a separate post.
It's not a "single variable"; it's just a placeholder for whatever the total of the binding energies in the system turns out to be. Again, I made no assumptions whatever about the form of ##U##. Its specific form will depend on the system.
My intent all along was to work in the rest frame of the *system*. If the system is a single atom, that frame is the rest frame of the atom. If the system is composed of multiple atoms, that frame is the rest frame of the total assembly of all the atoms. There's no fundamental difference between these cases, because the atom itself is composed of multiple particles in relative motion, i.e., it's a "system", not just a single particle.
That's what it amounts to, yes. But note that, as I said above, in the case where binding energy is present, you can only add energies this way in a particular frame, the frame in which potential energy is a well-defined function of position. The potential energy function won't transform correctly into an arbitrary frame.
Yes, that's why I was careful to specify that I was doing all this in one particular frame.
  • #64
I said I was using units in which ##c = 1##. This is standard procedure in relativity physics: mass and energy have the same units, since they're just different forms of the same thing.
I tried to clarify this in my previous post.
xox said:
This is not true.
Sure it is: energies that are all relative to the same frame are additive. They may not all transform correctly into another frame, but that's a different issue.
Deferring that to a separate post since it raises further issues (one of which is the issue of how to do all this in a Lorentz invariant way when binding energy is present).
  • #65
Doesn't matter, there is still no justification for your formula. More correctly, there is no derivation, you just put it by hand.
What justifies that? How do you know that binding energy is additive?
I see absolutely no reason why the above would be true since I see no derivation, you are just putting a formula by hand. It might be wrong, it might be right, you are simply tacking the binding energy to the formula of mass that I have derived in a rigorous fashion from base principles. What entitles you to do that? How do you even know that binding energy is additive? The fact that you can calculate the mass of an atom by adding (subtracting) its binding energy doesn't mean that you can do the same thing to a system of atoms.
Total energy is the one that is additive (by virtue of being a component of the energy-momentum four-vector). The other forms of energy are not. You know very well that rest energy, for example, is NOT additive. I have no idea about the case of binding energy but I see no reason why it should be additive.
Ok, I'll wait...
  • #66
and than in #23
PeterDonis said:
It works the same for N particles: just add up the N rest masses and kinetic energies (in the center of mass frame of the system), and all of the applicable binding energies. In general there could be N(N−1)/2 of the latter, since each pair of particles could have an interaction
with an additional explanation in #42
To my understanding this means replacing "atom" by "system" in the entire text resulting in
[tex]M = \sum\limits_{i = 1}^N {m_i } + \sum\limits_{i = 1}^N {k_i } - U[/tex]
where ##M## is the rest mass of the system, ##m_i## are the rest masses of the particles, ##k_i## the kinetic energies the particles (in the rest frame of the system), and ##U## the sum of the up to N(N−1)/2 binding energies for each particle pair. With c=1 this is identical to
[tex]M = \sum\limits_{i = 1}^N {m_i } + \sum\limits_{i = 1}^N {\left( {\gamma _i - 1} \right) \cdot m_i } - U = \sum\limits_{i = 1}^N {\gamma _i \cdot m_i } - U[/tex]
All summands in this equation are energies even though the current convention requires the term mass for the rest energy. I cannot see why you disagree in this point, the more so as you already agreed with the result without binding energy.
If you have not idea, how can you make the proposal above? In PeterDonis' equation U includes the sum of all binding energies (see his explanation above) whereas you include the inner binding energies of the particles only. What was your intention behind this approach?
  • #67
There is no reason to believe that this is correct, since you are putting it together by hand, just the same way as he's been doing it for quite a while.
I made no proposal, I made a rigorous derivation for the case of absent binding energy, see post5. I am objecting to the way he (and now you) are trying to extend it to the case of non-null binding energy. Let me make it clearer:
There is no argument that:
and
[tex]m_{0i}=m_p+\gamma_{ei}(v_e) m_e-u_i[/tex] (for ONE atom)
From the above, it DOES NOT follow that, for a system of atoms:
  • #68
As I have no reason not do believe that this is correct, please teach me what I might have miss here.
  • #69
Read the whole post, until the end. You are "calculating" the rest mass of a system (rest energy) as the sum of the rest masses of the components. That is known to be false. Not to mention that you are using the wrong kinetic energy ...
  • #70
I was talking about this:
To my taste that sounds like a proposal including binding energy.
If you agree with this equation for a single atom why not for any system? What makes an atom so special compared to other systems?
  • Classical Physics
