- #71
DrStupid
- 2,167
- 502
xox said:You are "calculating" the rest mass of a system (rest energy) as the sum of the rest masses of the components.
No, I don't. Did you miss the γ in my equation?
xox said:There is no argument that:
[tex]m_{0i}=m_p+\gamma_{ei}(v_e) m_e-u_i[/tex] (for ONE atom)
DrStupid said:I guess you mean [itex]m_0=\gamma m_p+\gamma m_e-u[/itex]
DrStupid said:No, I don't. Did you miss the γ in my equation?
If you agree with this equation for a single atom why not for any system? What makes an atom so special compared to other systems?
PeterDonis said:I'm confused; this is exactly the formula (including binding energy) that you said I had not derived rigorously,
[tex]M=\Sigma{\gamma'_i m_i}[/tex]
and
From the above, it DOES NOT follow that, for a system of atoms:
[tex]M=\Sigma{\gamma'_i m_i}-U[/tex]
xox said:Because there is absolutely no justification to do the addition.
xox said:you applied [itex]\gamma[/itex] to the whole atom. You need to apply it only to the electron.
xox said:I am not objecting to your formula for a single atom, I am objecting to you attempt at generalizing it for a system of atoms:
PeterDonis said:And my question is, *why* are you not objecting to the formula for a single atom?
DrStupid said:No, I applied it to every individual particle no matter what kind of particle it is.
xox said:I find your formula for a single atom just as objectionable.
xox said:derive the formula for a single atom from base principles
PeterDonis said:I did that in an earlier post for the hydrogen-1 atom; that's how I got the result ##M_0 = m_p + \gamma_e m_e - k e^2 / r## (in the frame in which the proton is at rest). I can fill in more details since I only really sketched the derivation in that post, but first I'd like to know whether that's worth doing. Would that count as a derivation "from base principles"? If not, why not?
xox said:Putting results by hand doesn't count as derivation from base principles.
xox said:What we know for a fact (as I demonstrated in post 5) is that in the frame of the center of momentum:
[tex]m_0=\gamma_p(v_p) m_p+\gamma_e(v_e) m_e[/tex]
xox said:1. What makes you think that in the CoM frame [itex]v_p=0[/itex] as you chose it?
xox said:2. What makes you think that there is a CoM frame given the fact that the slectron describes orbitals?
xox said:3. What makes you think that in the CoM frame the binding energy is [itex]\frac{ke}{r}[/itex]
xox said:4. How do you generalize the MASS formula above to the case of the mass of multiple atoms, all moving at different speeds, with various makeups in terms of the number of protons, neutrons and electrons?
PeterDonis said:Using the standard Coulomb potential for a two-body system of charges is not "putting results by hand".
No, we do not know that, because you derived that formula under the assumption that no binding energy was present. In other words, the proton and electron cannot be in a bound state if this formula is true. So the hydrogen-1 atom could not exist.
It isn't exactly zero in the CoM frame, but it's very close to zero because ##m_p## is so much larger than ##m_e##. I already explained that I was using this approximation in the previous post. I already said that that post was only a sketch, and asked you whether it was worth expanding on it. It would really be nice to get a plain yes or no answer to a simple question instead of a bunch of further questions that don't tell me whether you consider this whole line of discussion to even be moving towards your desired goal.
If we're going to bring in QM, then please start a separate thread in the Quantum Physics forums.I've been talking about an idealized "classical" hydrogen-1 atom in which, in the proton's rest frame, the electron is following a classical circular orbit at the Bohr radius.
I entirely agree that that's not what a real hydrogen-1 atom is like, but remember that this thread is in the SR forum and is supposed to be about how the rest mass of a composite system is determined from the properties of its constituents, in the classical (non-quantum) case.
I don't even want to consider this case until we have the case of a single atom worked out. You still haven't told me whether, if I gave a more detailed derivation of the formula I gave for the hydrogen-1 atom, that would even count as a "derivation from base principles". If it wouldn't, this whole subthread is pointless.
Also, I would really like a simple, straightforward answer to the physics question I posed in post #81.
xox said:you cannot apply classical, macroscopic SR to a problem that really belongs in the realm of QED.
xox said:Less than.
PeterDonis said:No argument. But what if we made the problem legitimately classical by considering macroscopic objects bound together by some interaction?
Ok, good, at least we agree on the actual physical observable.
xox said:We could
xox said:I am really sorry for being so tough but I do not like derivations that lack rigor. I appreciate all your efforts and your perseverance.
PeterDonis said:Ok, then we would need to find a macroscopic example to consider.
Unfortunately the only ones that I can think of involve gravitational binding, things like planets orbiting the Sun, and using gravity raises other issues since we can't really model gravity with SR.
Thanks! I agree rigor is highly desirable in derivations (although physicists and mathematicians often disagree on what constitutes rigor ).
xox said:There must be some literature on this subject, why don't we try finding it and returning to the subject when we can find a rigorous treatment.
xox said:I am an applied mathematician :-)
xox said:The individual particles have different "gammas". I already pointed out this mistake.
xox said:[tex]m_{0i}=m_p+\gamma_{ei}(v_e) m_e-u_i[/tex] (for ONE atom)
