New Reply
bubble's velocity
Share Thread Thread Tools
Jan29-13, 12:09 PM   #1
bubble's velocity
I would like to ask question and open a discussion about the relation between the impeller speed (RPM) of a mixer and particles velocity (bubbles). Thanks
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> As chaos celebrates its 50th birthday, biophysicist develops a new method to visualize it
>> Novel features of helium-3 superfluidity discovered with new SQUID detector chip
>> Physics of 'green waves' could make city traffic flow more smoothly
Jan30-13, 02:49 AM   #2
If you think of an impeller/propeller as being like a wood screw screwed into some wood then you can calculate how far it should move for each revolution. From that and the rpm you can work out how fast it should move through the material...or how fast the material should move through it.
The above give a rough estimate of the maximium speed that an impeller/propeller can move material, however it could be less than that due to "slip".
If you think of a propeller blade as being like a wing then without slip the pitch of the blades would have zero angle of attack relative to the material they are moving through. Wings are generally more efficient at a slightly positive angle of attack.
I'm sure there are people out there who know more then me but that's my take on the issues.
Jan30-13, 09:07 PM   #3
Recognitions:
Gold Membership Gold Member
Quote by thegeant View Post
thegeant, Welcome to Physics Forums!
Will you please be more specific? Are you referring to gas bubbles induced by cavitation of the impeller blades? Or are you referring to gas bubbles entrained from the surroundings by the impeller? The hydrodynamics literature normally contains studies of the terminal velocity of rising bubbles. Is this what you are asking about?
Cheers,
Bobbywhy
New Reply
Thread Tools
Similar Threads for: bubble's velocity
Thread Forum Replies
Hard to find bubble rise paper/bubble shape determination Classical Physics 4
The ultimate bubble: Treasuries (T) bubble coming? Social Sciences 1
Air Bubble Velocity General Physics 0
measuring tube velocity with air bubble? Introductory Physics Homework 8
Air Bubble Introductory Physics Homework 2
