Thermochemistry : What happens when too much hea tis added to a reaction?
In summary, the conversation discusses the concept of applying heat to a reaction in order to increase its rate, and whether there is a maximum amount of heat that can be applied before it becomes detrimental to the reaction. It is also mentioned that there is a risk of competing reactions becoming faster or changing something in the system that could prevent the desired reaction from occurring.
mballaz
I need to find out whether there is a maximum amount of heat that one can apply to a certain reaction in order to increase its rate, as described by the collision theory. In other words, is there such thing as too much heat when referring to speeding up the reaction in question? Can enough heat "kill" a reaction and prevent it from occurring?
btw nice site, looks very promising :smile:
There is always a risk that competing reactions will become faster than the one you need, or that you will change something in the system, making the reaction impossible - like boiling out the water if reaction takes place in the solution.
1. What is thermochemistry?
Thermochemistry is the study of the energy changes that occur during chemical reactions and processes.
2. How does adding heat affect a reaction?
Adding heat to a reaction can increase the rate of the reaction, but it can also change the equilibrium point and affect the products formed.
3. What happens when too much heat is added to a reaction?
If too much heat is added to a reaction, it can cause the reaction to proceed too quickly, leading to an uncontrollable release of energy and potential explosion.
4. Can adding heat to a reaction ever be harmful?
Yes, adding heat to a reaction can be harmful if it is not done carefully and in controlled conditions. As mentioned before, too much heat can cause an explosion, but it can also produce toxic byproducts or damage equipment.
5. How can the effects of heat on a reaction be controlled?
The effects of heat on a reaction can be controlled by carefully monitoring the temperature and adding heat in small increments. It is also important to have safety measures in place, such as using a fume hood and wearing protective gear.
16K
  • Biology and Medical
18K
  • Mechanical Engineering
14K
  • Materials and Chemical Engineering
