New Reply
mass of the moon?
Share Thread Thread Tools
Dec30-12, 06:53 AM   #1
mass of the moon?
hi, i can calculate the distance of moon from the earth and its diameter - but i could't get the formula by which i can calculate the mass of the moon - although i can calculate the mass of the moon by assuming it has same average density that of earth -
PhysOrg.com
PhysOrg
astronomy news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> Detection of the cosmic gamma ray horizon: Measures all the light in the universe since the Big Bang
>> Scientists work out way to use pulsars to provide self navigation to spacecraft in solar system
Dec30-12, 08:11 AM   #2
mfb
Mentor
The orbital period of the moon depends on its distance and the sum of masses of earth and moon - if you can determine this sum with sufficient precision, you can subtract the mass of earth and get the mass of moon.
Satellites orbiting the moon are a better way to determine its mass - they give direct access to the gravitational acceleration at a specific distance, together with the gravitational constant this can be used to calculate its mass.
Jan2-13, 11:37 AM   #3
but how do i calculate the sum of earth and moon mass?
Jan2-13, 11:59 AM   #4
mfb
Mentor
mass of the moon?
Measure distance, orbital period and the gravitational constant.
##M+m=\frac{4\pi^2a^3}{GT^2}## with the semi-major axis a (for a circular orbit, this would be the distance)
Jan4-13, 07:28 PM   #5
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
I'm curious as to how you calculated the distance between the Moon and Earth. That distance might not be the semi-major axis of the Moon's orbit. It might be the sum of the Moon's semi-major axis and the Earth's semi-major axis, as measured from their combined center of mass. (The 'a' in the previous equation is actually the sum of the semi-major axes, or the distance you most likely calculated.)
In practice, calculating the mass and the semi-major axis of planets was an almost impossible task even after Newton turned Kepler's Third Law into a formula. You had a formula containing three unknown variables (the universal gravitational constant, the mass, and the semi-major axis) and the only known was the orbital period.
In fact, that's why the Earth's semi-major axis for it's orbit around the Sun was measured in astronomical units, with one AU being the distance between the Sun and the Earth. You could measure Jupiter's semi-major axis in AU's, but had no way to convert that into a more traditional measure such as kilometers.
New Reply
Thread Tools
Similar Threads for: mass of the moon?
Thread Forum Replies
Mass of man-earth vs moon Introductory Physics Homework 1
Moon Mass Concentrations Astrophysics 1
Center of mass of the earth and the moon Classical Physics 18
Mass of the moon Introductory Physics Homework 4
