Some weird physics questions I'd like answering please
In summary, there are many weird and intriguing questions in the field of physics that remain unanswered. These questions range from the nature of dark matter and energy to the possibility of time travel and parallel universes. While scientists continue to explore and study these phenomena, the answers still remain elusive. Some of the most intriguing questions include the existence of wormholes, the behavior of particles at the quantum level, and the true nature of gravity. With ongoing research and advancements in technology, we may one day have a better understanding of these mysteries of the universe.
Gondur
25
Hello there physicists!
Here are two questions I'd like you to answer please.
If the population keeps increasing and if we keep building infrastructure, could the Earth's diameter decrease? In other words, could we crush the Earth like crushing a tin can in the palm of our hands?
Surely the net mass of the Earth is constant; it's just that we have rearranged its minerals and ores into structures like buildings for our usage and they in fact both have the same mass.
What about people? Do they add to the mass of the Earth or does a person's existence decrease another 'resource', so everything balances out?
Does density matter? Is it possible to make something more dense and increase the mass of the Earth without decreasing something else in the process?
___________________________________________________________________________
If another planet slowly got closer to the Earth such that the Earth's atmosphere was touching the planet's atmosphere, would there be a reaction of some kind? Would heat be generated even if it moved at a rate of 1 cm per minute towards the Earth?
Is is possible for the Earth's atmosphere to connect to the other planets atmosphere such that a symbiotic relationship could exist between both planets? Would both atmosphere mix together and produce a different kind of 'diluted' atmosphere shrouding both planets like adding orange juice to water?
Thanks!
Approximately. Meteoroids add a bit.
You never noticed that people eat stuff?
I believe you are correct. Basically we just keep rearranging stuff.
Overall it seems the planet is loosing mass. Explanation here..
http://science-beta.slashdot.org/story/12/02/02/1844205/is-the-earth-gaining-or-losing-mass
The above article suggests that global warming is increasing the mass of the earth. Does that count?
Taking something on Earth and making it more dense doesn't increase the mass of the earth.
I suppose that article implies if you were to split the world oceans into hydrogen and oxygen then perhaps more hydrogen would leak into space making the Earth lighter. However that would cause other problems and effects.
Two planets orbiting each other in close proximity would cause strong tidal effects. I'm not an expert on this but I imagine that alone would heat up the planets as happens on Io...
http://www.planetaryexploration.net/jupiter/io/tidal_heating.html
Depending on how one defines the limit of the atmosphere, the distance between the surfaces of the planets would be in the 100-1000 km range. That is (much) less than the radius of the Earth, and so the planets would exert a very strong gravitational force onto each other. So strong, that the planets would have to move at a very high speed with regard to each other to keep the separation - otherwise they would collide in a matter of minutes, if not seconds. Either way, this will be highly disruptive to everything on the Earth - including life, too.
The main problem would be the tidal forces:
http://en.wikipedia.org/wiki/Roche_limit
1. What are some examples of weird physics questions?
Some examples of weird physics questions are: "What would happen if we could travel faster than the speed of light?", "What is the universe expanding into?", and "Is time travel possible?"
2. Why do some people believe in parallel universes?
Some people believe in parallel universes because of theories like the multiverse theory, which suggests that there are infinite parallel universes that exist alongside our own. This idea also comes from concepts in quantum mechanics, such as the many-worlds interpretation.
3. Can energy be created or destroyed?
According to the law of conservation of energy, energy cannot be created or destroyed, it can only be transformed from one form to another. This is known as the first law of thermodynamics and is a fundamental principle in physics.
4. What is dark matter and why is it important?
Dark matter is a type of matter that does not emit or absorb light, making it invisible to traditional telescopes. It is thought to make up about 85% of the total matter in the universe and is important because it helps explain the observed gravitational effects on galaxies and galaxy clusters.
5. Are there any proven theories about the existence of aliens?
There are many theories and hypotheses about the existence of aliens, but there is currently no concrete evidence or proof that they exist. Some scientists believe that it is possible for there to be extraterrestrial life in the universe, but until we have more evidence, it remains a mystery.
  • Other Physics Topics
